SRV05 Ultraschallsensor
OP #4499583
Ich versuche mich gerade daran einen Ultraschallsensor vom Typ SRV05 an
einem ATmega328 zum laufen zu bringen. Folgender Code ist für das
Handling des SRV05 zuständig:
 * SRF05.c
 * Created: 08.03.2016 11:36:49
 *  Author: Admin
#include "SRF05.h"
#include "global.h"
#include "EDIP.h"
#include "uart.h"
#include <avr/io.h>
#include <util/delay.h>
#include <stdio.h>
#include <string.h>
#define TRIGGER PB1
#define MEASURE PD3
volatile unsigned int microseconds = 0; // to save pulse length
volatile uint8_t INT1_interrupt = 0; // to indicate whether an INT1 interrupt has already occurred
23
volatile uint8_t measurement_complete = 0; // is used to indicate that the measurement is complete
24
25
// Function to initialize the SRF05-Interface
26
void SRF05_init(void)
27
28
  // Setup timer 1
29
  TCCR1A = (1<<WGM12); // CTC Mode of Timer 1
30
  // (8000000 / 8 ) / 10 = 1000 -> Every 1ms
31
  OCR1A = 10 - 1; // Interrupt fires every 10us
32
  TIMSK1 |= (1<<OCIE1A); // Enable compare interrupt
33
34
  DDRB |= (1<<TRIGGER); // set trigger pin to output
35
36
  DDRD &= ~(1<<MEASURE); // set INT1 as input
37
  EICRA |= (ISC10) | (ISC11);
38
  EIMSK |= (1<<INT1);
39
40
41
42
// Check distance
43
void SRF05_Measure(void)
44
45
  uint16_t dist = 0;
46
  char distanceBuf[20];
47
48
  dist = 0; // Reset distance
49
  microseconds = 0; // Reset ms counter
50
  TCNT1 = 0; // Set timer 1 to 0
51
52
  // Trigger the SRF05 measurement
53
  PORTB |= (1<<TRIGGER);
54
  _delay_ms(1); // 1ms trigger signal
55
  PORTB &= ~(1<<TRIGGER);
56
  uart_send("Trigger\n\r", 9);
57
58
  while(measurement_complete != 1); // wait until measurement is complete
59
60
61
  measurement_complete = 0; // Reset
62
63
  dist = microseconds / 29  ;
64
65
  // Print distance to LCD
66
  sprintf(distanceBuf, "Distanz: %ucm", dist);
67
  LCD_clearLine(0x11);
68
  LCD_Puts(distanceBuf, strlen(distanceBuf), 0x00, 0x11, 'L');
69
70
71
72
// Interrupt for signal from SRF05
73
ISR(INT1_vect)
74
75
   // Only if there hasn't been triggered on a rising edge yet
76
  if(INT1_interrupt == 0)
77
78
    TCCR1B |= (1<<CS11); // Start timer with prescaler 8
79
    EICRA |= (1<<ISC11); // Set INT1 to trigger in falling edge
80
    EICRA &= ~(1<<ISC10);
81
82
    INT1_interrupt = 1; // To indicate, that an interrupt has already occurred
83
84
  else
85
86
    TCCR1B &= ~(1<<CS11); // Stop Timer
87
88
    INT1_interrupt = 0; // Reset variable
89
    measurement_complete = 1; // Variable to indicate end of measurement
90
91
92
93
  EIFR = (1<<INTF1);
94
95
96
97
//Interrupt every 10µs
98
ISR(TIMER1_COMPA_vect)
99
100
  microseconds += 10;
101
Leider funktioniert es nicht so richtig. Auf dem LA sehe ich, dass der
SRV05 sein Startsignal bekommt und brav darauf antwortet. Der µC zeigt
mir nur einmal 0cm an, beim zweiten Aufruf der Funktion sendet er das
Startsignal und hängt sich auf. Auf dem LA sehe ich, dass aber auch die
zweite antwort vom SRV05 korrekt gesendet wird
Persönliche Seite #4499611
ein Tipp von mir:
der SRF05 gibt ja pro cm 58us high zurück, also: lass einen Timer alle
58us ein hoch zählen (ab einfachsten im CTC-mode)
Ich würde die PCInts nehmen (nehme ich generell lieber). Diese reagieren
auf jeden Flankenwechsel.
D.h. bei der Steigenden Flanke speicherst du dir den 58us-Timerwert ab.
Bei einer fallenden Flanke ziehst du den aktuellen Timerwert vom
gespeicherten ab.
UND: das ist deine Distanz in Zentimetern.
Denke allerdings dran, dass wenn du den Mode mit nur einem
Auslöse-/Echo-Pin nimmst, du vor dem Start-Signal die PCInts abschalten
musst und danach wieder ein.
Zu deinem Code:
warum nutzt du Interrupts, wenn du sowieso auf das Ergebnis wartest?
Dann könnte man einfach pollen und dein Problem würde wahrscheinlich
einfacher zu lösen sein.
//liefert die Entfernung zum Objekt in cm
void srf05_get_distance(void) {
    PORT_START_PIN |= (1 << START_PIN);
    _delay_ms(1);
    while (! (PIN_MEASURE_PIN & (1 << MEASURE_PIN))) ; //auf steigende Flanke warten
    uint16_t starttime = currentTick58us(); //den aktuellen Timer-wert speichern
    while (PIN_MEASURE_PIN & (1 << MEASURE_PIN)) ; //auf fallendeFlanke warten
    return currentTick58us() - starttime; //das ist dann schon die Distanz
OP #4499993
Habe den COde jetzt mal wie folgt abgeändert:
 * SRF05.c
 *  Author: Admin
#include "SRF05.h"
#include "global.h"
#include "EDIP.h"
#include "uart.h"
#include <avr/io.h>
#include <stdio.h>
#include <string.h>
#define TRIGGER PB1
#define MEASURE PD3
uint16_t timerCNT = 0;
24
25
26
  // Setup timer 1
27
  TCNT1 = 65478; // Preload
28
  TCCR1B |= (1<<CS11); // Prescaler 8
29
  TIMSK1 |= (1<<TOIE1); // Enable overflow interrupt
30
31
32
33
34
35
// Task, which periodically checks the distance
36
37
38
  uint16_t dist = 0;
39
40
41
42
43
44
45
46
47
48
49
  while(!(PIND & (1<<MEASURE))); // Wait for rising edge
50
  timerCNT = 0; // Reset timer 1
51
  while(PIND & (1<<MEASURE)); // Wait for falling edge
52
53
  dist = timerCNT;
54
55
56
  sprintf(distanceBuf, "Distanz: %dcm", dist);
57
  LCD_clearLine(0x32);
58
  LCD_Puts(distanceBuf, strlen(distanceBuf), 0x00, 0x32, 'L');
59
60
61
62
//Interrupt every 58µs
63
ISR(TIMER1_OVF_vect)
64
65
  timerCNT++;
66
Jetzt funktioniert die Messung zwar dauerhaft, aber leider kommt immer
nur 0cm raus. Ein test zeigt, dass er in der Wartezeit garnicht
hochzählt.
Persönliche Seite #4500001
Hallo nochmal,
dein Timer stimmt leider noch nicht.
volatile fehlt, sonst kriegt der Compiler das ändern in der ISR nicht
mit, bzw. er optimiert es, da er denkt, dass die Variable nie geändert
wird.
Jens K. schrieb:
> // Setup timer 1
der Preload ist zwar gut gemeint, gilt aber leider nur bis zum ersten
Overflow, ab da zählt der Timer wieder schön von 0 hoch.
>   timerCNT++;
Du müsstest dann hier auch einen Preload machen.
Aber warum das? Setze dich mal mit dem CTC mode auseinander.
Dieser setzt den Timer beim erreichen der ISR automatisch auf 0 zurück.
Ein Beispiel:
TIMSK5 = (1 << OCIE5A);
TCCR5B = (1 << CS51) | (1 << WGM52);  //prescaler 8, CTC
OCR5A = 58 * 2; //58us@16MHz
Aber eigentlich sollte mit einem richtigen Timer der Code klappen
