Android + MSP430 + HM 10 Bluetoothadapter
Gast #4715075
Hallo ich wollte oben genannte Konstellation zum Laufen bekommen.
Das momentane Problem ist, dass beim Aufruf von socket.connect() eine
Exception ausgelöst wird: "read failed, socket might closed or timeout,
read ret: -1"
code ist erst einmal folgender:
package com.example.rpeglow.bttest;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.bluetooth.BluetoothSocket;
import android.content.BroadcastReceiver;
import android.content.Context;
import android.content.Intent;
import android.content.IntentFilter;
import android.os.ParcelUuid;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.ArrayAdapter;
import android.widget.Button;
import android.widget.TextView;
import android.widget.Toast;
import java.io.IOException;
import java.util.UUID;
import java.util.Vector;
public class MainActivity extends AppCompatActivity {
    TextView textView;
    Button button;
    BluetoothAdapter bluetoothAdapter;
    BluetoothDevice device;
    Vector<BluetoothDevice> vector = new Vector<BluetoothDevice>();
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        textView = (TextView) findViewById(R.id.tv1);
        bluetoothAdapter = BluetoothAdapter.getDefaultAdapter();
        bluetoothAdapter.enable();
        BroadcastReceiver receiver = new BroadcastReceiver() {
            @Override
            public void onReceive(Context context, Intent intent) {
                String action = intent.getAction();
                if (BluetoothDevice.ACTION_FOUND.equals(action)) {
                    device =
intent.getParcelableExtra(BluetoothDevice.EXTRA_DEVICE);
                    bluetoothAdapter.cancelDiscovery();
                    textView.setText(device.getName() + " " +
device.getAddress());
// Register the BroadcastReceiver
        IntentFilter filter = new
IntentFilter(BluetoothDevice.ACTION_FOUND);
        registerReceiver(receiver, filter); // Don't forget to
unregister during onDestroy
        bluetoothAdapter.startDiscovery();
    public void click(View v) {
        BluetoothSocket socket=null;
        try {
            socket = device.createRfcommSocketToServiceRecord(new
UUID(0xFFE1, 0x0815));
        } catch (IOException ex) {
            try {
              socket.connect();
                //socket.close();
                textView.setText(ex.getLocalizedMessage());
            //bluetoothAdapter.disable();
was läuft da falsch? über die benutzeroberfläche zu verbinden klappt
super.
Das hier ist Bluetooth Classic:
Das HM 10 ist aber AFAIR ein Bleutooth Low Energy Modul, da braucht man
das entsprechende Android API ab 4.3 oder 5. Das sieht dann ganz anders
aus.
achso. ich hab eben mal gesucht und bekomme da was von gatt-servern
erzählt. ist es das?
und wie funktioniert das beim msp430g2553? ich hab mir da auf die
schnelle was mit grace gebaut, weil die register im manual ganz anders
heißen, als in der headerdatei. aber da passiert nichts, wenn ich was
nach UCA0RXBUF schreibe.
