Verbindungsprobleme Atmega328
OP #4805076
ich habe mehrere kleine Platinen mit einem Atmega328 herstellen lassen.
Sie basieren auf einem Design welches ich schon mal hab herstellen
lassen und welches auch wunderbar funktionierte.
Die Neuen machen jedoch Ärger. Bei der Eingabe von:
[code]avrdude -c stk500 -P com6 -p atmega328p -n -v[code]
kommt Folgendes:
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is
"C:\WinAVR-20100110\bin\avrdude.conf"
         Using Port                    : com6
         Using Programmer              : stk500
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page
      Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages
MinW  Max
W   ReadBack
           eeprom        65     5     4    0 no       1024    4      0
3600  36
00 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256
4500  45
00 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0
4500  45
00 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0
4500  45
00 0x00 0x00
           efuse          0     0     0    0 no          1    0      0
4500  45
00 0x00 0x00
           lock           0     0     0    0 no          1    0      0
4500  45
00 0x00 0x00
           calibration    0     0     0    0 no          1    0      0
0
 0 0x00 0x00
           signature      0     0     0    0 no          3    0      0
0
 0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel STK500
         Programmer Model: STK500
         Hardware Version: 10
         Firmware Version Master : 2.10
avrdude: stk500v2_command(): command failed
avrdude: stk500v2_getparm(): failed to get parameter 0x9a
         Topcard         : Unknown
         Vtarget         : 5.0 V
         SCK period      : 2.2 us
         Varef           : 5.0 V
         Oscillator      : Off
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100%
0.03s
avrdude: Device signature = 0x1e9514
avrdude: safemode: lfuse reads as 62
avrdude: safemode: hfuse reads as D9
avrdude: safemode: efuse reads as 7
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Sieht soweit ganz gut aus. Bei der nächsten Eingabe des gleichen Befehls
kommt zum Schluss:
0.02s
avrdude: Device signature = 0x000102
avrdude: Expected signature for ATMEGA328P is 1E 95 14
         Double check chip, or use -F to override this check.
... und bei jedem weiteren Versuch bleibt die Device Signature bei
0x000102 bis ich den Programmer entferne und wieder anschließe. Manchmal
meldet er auch einfach nur, dass er nicht verbinden kann.
Ich habe die Kabellängen der Programmierkabel schon gekürzt und alle
Verbindungen überprüft. Auch funktioniert der Programmer (Diamex-USB)
bei anderen Boards einwandfrei.
MOSI, MISO, SCK sind auch korrekt mit dem Chip verbunden.
Könnt ihr mir vielleicht aus der Patsche helfen? Ich wäre euch mega
dankbar.
Beste Grüße,
     Marian
OP #4805682
Hey Oliver,
vielen Dank für die Info.
Aus irgenden einem Grund hat sich mein Problem verschärft. Über Nacht
haben nun alle µCs entschieden ihren Geist auf zu geben und mir noch
nicht mal die Signatur 0x000102 zu senden. Jetzt bekomme ich überhaupt
keine Verbindung mehr. Habe nun auch das Verbindungskabel komplett neu
gelötet, aber das bringt auch keine Besserung.
Deinen Tip hab ich folgendermaßenangewendet:
avrdude -c stk500 -P com4 -p atmega328p -n -B20
Ist das korrekt?
ich habe es auch mal mit -i20 probiert worauf sich der µC plötzlich
korrekt gemeldet und mich in den folgenden Versuchen mit der bekannten
Signatur 0x000102 geärgert hat. Irgendwann hat er die Verbindung wieder
ganz eingestellt.
Dieses Verhalten ist einfach überhaupt nicht zu reproduzieren. Ich bin
soweit mit meinem Latein am Ende. Liegt es vielleicht an den verbauten
selbst? Habe gehört es schwirren auch gerne Imitate rum.
Mit verzweifeltem Gruß,
     Marian
#4805702
Nu ja, wenn die Signatur beim Lesen nicht richtig ankommt, ist
irgendetwas faul. entweder falsch verbunden, keine richtigen Pegel auf
den ISP-Leitungen oder kein passender Takt.
Bevor weitergemacht wird, muss das halt stimmen. Aber ISP alleine ist
doch nur ein Teilproblem, das man durch probieren in den Griff bekommen
kann.
Am Kontroller liegt es eigentlich nie.
Gast #4805743
Problem wegen alter Version?
Kenne den STK500 nicht, muss da irgendwo ein Bootloader sein?
Der vielleicht nicht richtig funktioniert?
OP #4807849
@Grübler:
Vielen Dank für den Hinweis. Ich habe jetzt die neueste Version
installiert, nur leider ohne besseres Ergebnis.
@Peter:
Du hast recht. Irgendwas ist faul. Ich habe die Schaltung noch mal
überprüft und es stimmt alles. Am Freitag ist mir jedoch aufgefallen,
dass ich reproduzierbar einmal eine korrekte Verbindung zum µC aufbauen
kann wenn ich mit einer bestimmten Anzahl an Veruchen den folgenden
Befehl eingebe:
avrdude -c stk500 -P com6 -p atmega328 -n
Ich bekomme dann genau einmal die korrekten Daten vom µC und danach nur
Müll. Versuche ich es weiter habe ich irgendwann keine Verbindung mehr,
bis ich nach einer gewissen Anzahl an Versuchen wieder einmalig eine
Verbindung habe.
Ich muss dazu sagen, dass ich einen externen Quarz angeschlossen habe,
den ich über die Fuses aber noch nicht aktivieren konnte. Kann mir
dieser Quarz den Kommunikationstakt versauen??
Ich habe das Gefühl das es wirklich an einem falschen Takt liegt. Was
kann ich in diesem Fall tun??
Vielen Dank euch,
     Marian
Gast #4807857
Hallo, nur eine kleine Anmerkung von mir.
Ich hatte neulich ein ähnliches Problem. Ich wollte auch einen 328 zum
flashen bekommen. Und habe keine Verbindung zum dem Chip aufbauen
können. Ich habe keinen stk500 sondern nur einen usbasp.
Auch mit anderen Chips wie dem Atmega8 funktionierte es nicht mehr. Naja
was soll ich sagen. Ich hab lange probiert, Treiber neuinstalliert und
und und...
Das Problem lag am Ende an einem Windows 10 Update. Ich weiß nicht was
du für ein Betriebssystem benutzt aber probiers mal auf nem Älteren. Ich
hatte zum glück noch einen Windos 7 Rechner rumliegen, da geht alles
einwandfrei.
#4807869
Eigentlich schalten die fuses zuverlässig zwischen "interner Oszillator"
und extern angeschlossenem Quarz um. Der Quarz dürfte also keinen
Einfluss haben.
Wenn aber der Takt "tröpfelt", dh.ein Oszillator läuft nicht stetig
sondern liefert sein Signal mit kurzen Unterbechungen, könnte so etwas
passieren. (z.B. beim Lesen der Signatur bricht die Spannung wegen einem
zu niederohmigen MISO-Eingang kurzzeitig zusammen und stört den internen
Taktoszillator)
Eine andre Ursache könnte die Spannungsversorgung sein: Wenn diese
Einbrüche hat, kommt der Kontroller evtl. schon beim Lesen der Signatur
ins Stolpern.
Also, versuchsweise die Stützkondensatoren vergrößern, ob sich dadurch
etwas ändert.
Der aber am häufigsten vorkommende Fehler ist doch der, dass die
ISP-Verbindung mit zu hoher Taktfrequenz läuft. Der Kontroller hat für
ISP 125kHz mit über 10% Toleranz, wenn der interne RC-Oszillator
verwendet wird.
Wenn da beim PC 125 kHz oder 100kHz eingestellt ist, klappt das dann
unzuverlässig, besonders wenn die Spannungsversorgung des IC grenzwertig
ist.
Also auch versuchsweise den Takt des ISP herabsetzen.
Beschränke Dich vorerst ausschließlich auf das Signatur-lesen. Wenn das
klappt, gehts dann mit dem Programmieren sowieso.
