Fading in Schleife
OP #4889913
ich habe folgendes Problem. Ziel ist es, eine LED-Fading zu realisieren.
Klar habe ich die Artikel dazu gelesen. Mein Code führt dazu das die LED
ehr unkoordiniert flackert.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdint.h>
#include <stdbool.h>
#define LED_DDR (DDRD)
#define LED_PORT (PORTD)
#define LED (1<<3)
static const uint16_t pwmtable_16[256] PROGMEM =
  0, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 3,
  3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 4, 5, 5, 5, 5, 5, 6, 6, 6, 6, 7,
  7, 7, 8, 8, 8, 9, 9, 10, 10, 10, 11, 11, 12, 12, 13, 13, 14, 15,
  15, 16, 17, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29,
  31, 32, 33, 35, 36, 38, 40, 41, 43, 45, 47, 49, 52, 54, 56, 59,
  61, 64, 67, 70, 73, 76, 79, 83, 87, 91, 95, 99, 103, 108, 112,
  117, 123, 128, 134, 140, 146, 152, 159, 166, 173, 181, 189, 197,
  206, 215, 225, 235, 245, 256, 267, 279, 292, 304, 318, 332, 347,
  362, 378, 395, 412, 431, 450, 470, 490, 512, 535, 558, 583, 609,
  636, 664, 693, 724, 756, 790, 825, 861, 899, 939, 981, 1024, 1069,
  1117, 1166, 1218, 1272, 1328, 1387, 1448, 1512, 1579, 1649, 1722,
23
  1798, 1878, 1961, 2048, 2139, 2233, 2332, 2435, 2543, 2656, 2773,
24
  2896, 3025, 3158, 3298, 3444, 3597, 3756, 3922, 4096, 4277, 4467,
25
  4664, 4871, 5087, 5312, 5547, 5793, 6049, 6317, 6596, 6889, 7194,
26
  7512, 7845, 8192, 8555, 8933, 9329, 9742, 10173, 10624, 11094,
27
  11585, 12098, 12634, 13193, 13777, 14387, 15024, 15689, 16384,
28
  17109, 17867, 18658, 19484, 20346, 21247, 22188, 23170, 24196,
29
  25267, 26386, 27554, 28774, 30048, 31378, 32768, 34218, 35733,
30
  37315, 38967, 40693, 42494, 44376, 46340, 48392, 50534, 52772,
31
  55108, 57548, 60096, 62757, 65535
32
33
34
35
void setup()
36
37
  //Port
38
  LED_DDR |= LED;
39
  LED_PORT |= LED;
40
  //Timer
41
  TIMSK1 = ((1<<OCIE1A) | (1<<TOIE1));
42
  TCCR1B |= (1<<CS10);
43
  //Interrupt
44
  sei();
45
46
47
void loop(void)
48
49
  static uint8_t u8I = 0;
50
  OCR1A = pwmtable_16[u8I++];
51
  delay(400);
52
53
54
ISR(TIMER1_COMPA_vect)
55
56
  LED_PORT |= LED; // switch led off
57
58
59
ISR(TIMER1_OVF_vect)
60
61
  LED_PORT &= ~LED; // switch led on
62
Ich habe es auch mit for-Schleife in der loop-Funktion probiert, was
ebenso nicht funktioniert. Was allerdings funktioniert, wenn ich das
Fading manuell mache, also wie folgend.
void loop(void)
  uint16_t u16Delay = 400;
  OCR1A = pwmtable_16[1];
  delay(u16Delay);
  OCR1A = pwmtable_16[2];
  delay(u16Delay);
  OCR1A = pwmtable_16[3];
  delay(u16Delay);
  OCR1A = pwmtable_16[4];
// Und so weiter
Für mich ist das Verhalten rätselhaft. Als wenn die loop nicht korrekt
Kompiliert wird.
#4889943
@Tim S. (timer)
Hmm. Was hindert dich daran, einfach mal de  Originalquelltext
unverändert auf deinen AVR zu laden? Das minimiert die Fehlerquellen.
Wo wird OCRx freigeschaltet? COMxy Bits.
Das LED-Fading im Artikel benutzt die Hardware-PWM, was vor allem bei 16
Bit PWM auch gar nicht ander geht. Du versuchst hier ein Software-PWM.
Glaub ich nicht so recht, das ist eher ein Dreckeffekt, der dir ein
funktionierendes Programm vorgaukelt.
>Kompiliert wird.
OP #4889978
Weil ich Soft-PWM benötige, der Fading-Artikel verwendet Hardware-PWM.
Der Code aus dem Soft-PWM Artikel realisiert PWM auf nen ganzen Port,
ich brauche ihn für einen speziellen Pin.
Wegen Soft-PWM brauche ich die Pins nicht.
Ja, das versuche ich.
Dreckeffekt? Warum sollte es nicht funktionieren?
#4889997
@ Tim S. (timer)
Leg lieber einen Draht auf deiner Platine zum passenden PWM-Pin, das
geht deutlich schneller und ist einfacher.
Hast du schon mal einen Gedanken daran verschwendet, warm man in
bestimmten Situationen KEIN Software-PWM verwenden will/kann. Und wo die
Grenzen von Soft-PWM liegen?
#4890007
Hi
void loop(void)
  delay(400);
Wenn ich den Code richtig verstehe, wird die Variabel u8I auf 0 gesetzt
und danach der Wert 1 (u8I + 1, oder Wert 0 und u8I um Eins erhöht) des
Array in das Match-A-Register des Timer 1 geladen.
Und Das immer wieder - da ich das '=0' so interpretiere, daß der
Variabel JEDES MAL der Wert 0 zugeteilt wird.
Wenn NICHT, also diese Zuweisung nur 1x ausgeführt wird - gehört die
Zeile eher in den Init-Bereich.
OP #4890012
Die sind alle schon belegt.
Verschwendet ist hier vielleicht der richtige Ausdruck. Eine LED zu
dimmen sollte wohl kein Problem darstellen. Zu mal es ja bei manueller
Programmierung funktioniert.
OP #4890016
> MfG
Die Variable ist statisch, dass heißt, sie wird nur einmalig
initialisiert. Ich kann sie natürlich auch global deklarieren und dann
im setup-Bereich initialisieren. Kommt aber auf's gleiche heraus.
