Suche zuverlässige Buchsenleiste für NANO
ich verwende Präzisionsfederleisten
http://www.segor.de/#Q=FLLAB1x36-180G&M=1
http://www.segor.de/bilder/00002286.jpg?SEGOR=%5B%27S3112%27%2C%27FLLAB%201x36-180G%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27FLLAB36-180_alteBez.%27%2C%27Federl.36pol%20180%B0%20RM2%2C54%27%2C%27einreihig%20h%3D7mm%20Zinn/Gold%27%2C%271%27%2C%271%27%2C%271%27%2C%271%27%2C%271%27%2C%272400%27%2C%272020%27%2C%2710%27%2C%271920%27%2C%271610%27%2C%2725%27%2C%271680%27%2C%271410%27%2C%27100%27%2C%271440%27%2C%271210%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%272286%27%2C%276%27%2C%27%27%2C%270%27%2C%278838%27%5D
habe mir sogar Footprints für PCB erstellt 1,6mm damit ich die versenken
kann
oder ich nehme SIL Sockel und löte kurzen Schaltdraht ein
http://www.segor.de/#Q=SILLAB32%252FETEC&M=1
http://www.segor.de/bilder/0000dcd4.jpg?SEGOR=%5B%27S3520%27%2C%27SILLAB32/ETEC%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27SIL-Sockelstreifen%2032p%27%2C%27Kontakt%20vergoldet%27%2C%274%27%2C%271%27%2C%271%27%2C%271%27%2C%271%27%2C%271200%27%2C%271010%27%2C%275%27%2C%27960%27%2C%27810%27%2C%2710%27%2C%27840%27%2C%27710%27%2C%2750%27%2C%27720%27%2C%27610%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27dcd4%27%2C%278%27%2C%27%27%2C%270%27%2C%2718942%27%5D
oder versenkte, auch für 1,6mm Bohrung
http://www.segor.de/#Q=SILCAR5&M=1
http://www.segor.de/bilder/0000ebaf.jpg?SEGOR=%5B%27S0613%27%2C%27SILCAR%205%27%2C%27%27%2C%27%27%2C%27Einbettungsfassung/5pol%27%2C%27%27%2C%27%27%2C%27%27%2C%27SIL-Carrier%20Pin%3A1%2C2x3%2C2mm%27%2C%27Platineneinbettung%2C%205Stck%27%2C%274%27%2C%271%27%2C%271%27%2C%271%27%2C%271%27%2C%27250%27%2C%27210%27%2C%2710%27%2C%27200%27%2C%27170%27%2C%2725%27%2C%27180%27%2C%27150%27%2C%27100%27%2C%27150%27%2C%27130%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27%27%2C%27ebaf%27%2C%270%27%2C%27%27%2C%270%27%2C%2717407%27%5D
(Firma: Schweigstill IT) Persönliche Seite
Natürlich gibt es auch entsprechend hochwertige Stiftleisten und
Buchsenleisten etlicher Markenhersteller. Man sollte eben bloß nicht den
letzten Schrott kaufen, weil er so schön billig ist... z.B. bei dubiosen
Händlern bei Ebay oder Alibaba.
Harwin stellt z.B. sehr hochwertige Produkte her:
https://www.harwin.com/filter/?level=2&code=C20&tlcode=C
Auch mit ept oder MPE Garry habe ich noch nie Probleme gehabt:
https://www.ept.de/index.php?Board-to-Board-Steckverbinder-Leiterplattenverbindung
https://www.mpe-connector.de/index.php?lang=de&menu=16&product_group[]=6&action=Search
Und dann gibt es natürlich noch TE, Molex, usw..
MPE Garry ist z.B. bei Reichelt erhältlich, die anderen Marken über die
üblichen Händler wie Digi-Key, RS, Mouser, Farnell. Auf den
Herstellerseiten befinden sich üblicherweise irgendwo die Listen mit den
offiziellen Distributoren.
Für besonders hochwertige Verbindungen solltest Du aber ggf. von den
"normalen" Stiftleisten mit quadratischen Stiften in 0,64mm^2 aus sog.
"gedrehte Kontakte" mit runden Stiften und den exakt dazu passenden
Buchsenleisten wechseln. Auf keinen Fall dürfen diese unterschiedlichen
Bauformen miteinander kombiniert werden.
Meine Erfahrung ist gegenteilig. Die teuren, gedrehten Präzesionsbuchsen
sind schrottiger als die billigen simplen. Die teuren brechen leichter,
leiern schneller aus und sind dann nicht mal mehr zu flicken. Hat man in
billige mal einen zu dicken Pfosten rein gezwungen, kommt man noch mit
einer Stecknadel dran und kann die Kontaktfedern wieder richtig biegen.
Aber wenn das überhaupt erforderlich war, dann lag es stets an einer
Fehlbedienung meinerseits (Pfosten in Buchsen für IC-Beinchen).
Hi
Das kenne ich von meinem, mittlerweile 15 Jahre altem, STK500. Die AVRs
lassen sich immer noch nur unter massiven Zwang aus den Sockeln
entfernen. Bei irgend welchen Präzessionssockel könnte ich die
wahrscheinlich durch kräftiges Pusten vom STK herunter holen.
MfG spess
Persönliche Seite
Gute Erfahrungen habe ich mit diesen Präzisionsbuchsenleisten gemacht:
https://www.reichelt.de/?ARTICLE=119957
Da die teurer sind als die üblichen Stiftleisten, löte ich die in die
Experimentierplatinen ein (nach unten weisend), so daß ich die
Experimentierplatinen auf eine mit normalen (und günstigeren)
Stiftleisten versehene Lochrasterträgerplatine setzen kann.
Herbört schrieb:
> kommt man noch mit
Genau so. Ich werde in Zukunft vor dem Löten den Nano zupfen.
Mache ich bei Röhren ja auch nicht anders.
@ Andere:
Was soll das Buchsenleisten für die dünneren dip-Stifte
zu empfehlen? Wollt Ihr das die Leser hier unbrauchbare
Buchsenleiten kaufen?
LG
old.
Jetzthabensieihn I. schrieb:
> @ Andere:
??? wen meinst du denn, es gibt viele Wege nach ROM und noch mehr
Möglichkeiten.
Nicht alle nano werden schon mit Stiftleisten geliefert und da kann ich
einlöten was MIR passt von dünnen Schaltdraht bis dünne Pins und diese
durchaus in IC Sockelstreifen versenken, ich kann natürlich auch
Stiftleisten und Federleisten nehmen, sogar verkehrtrum!
Also gehe bitte aus der Hitze bevor dich der Schlag trifft, oder lese
genauer!
> Nach den ersten Wackelkontakten am arduino nano ...
> Welche Buchsenleisten sind Empfehlenswert
Da landet man schnell bei Herstellern wie Berg und AMP. Die
Fernost-Billigteile haben Gabelfedern, Berg kann komplette Hülse mit
Blattfeder. Die Frage ist nur, wo man sie als Heimwerker in kleiner
Menge bekommt.
Häh?
Der Chinano kommt mit losen Stiftleisten. Die kommen erstmal in eine
Lochrasterplatte und werden sauber rechtwinklig mit dem Nano verlötet.
Später kommen die Buchsenleisten auf den Nano und werden mit diesem
gemeinsam in die Zielplatte gelötet - nur so bekomme ich das winkelig
hin.
Den Weiterbau der Lochrasterplatte mache ich dann meist ohne Nano drauf.
Auch bei den Markenprodukten ist zu beachten, dass derartige
Steckverbinder nur für eine niedrig zweistellige Anzahl von Steckzyklen
ausgelegt sind!
