stm32f303RE - initialisierungen verbeissen sich
Gast #5044943
Hi @all
Es sieht mehr aus als es ist, so bitte lasst euch nicht vom langen Code
abschrecken.
Ich habe ein kleines Problem und zwar habe ich definiert:
typedef struct TIMxPIN{
  GPIO_TypeDef* port;
  uint16_t pin;
} TIMxPIN_t;
// ADC definitions
#define ADC1_Channel_IN1                        (TIMxPIN_t){GPIOC, GPIO_PIN_0}
#define ADC1_Channel_IN2                        (TIMxPIN_t){GPIOC, GPIO_PIN_1}
#define ADC1_Channel_IN3                        (TIMxPIN_t){GPIOC, GPIO_PIN_2}
#define ADC1_Channel_IN4                        (TIMxPIN_t){GPIOC, GPIO_PIN_3}
#define ADC1_Channel_IN7                        (TIMxPIN_t){GPIOA, GPIO_PIN_2}
#define ADC1_Channel_IN8                        (TIMxPIN_t){GPIOA, GPIO_PIN_3}
#define ADC1_Channel_IN9                        (TIMxPIN_t){GPIOA, GPIO_PIN_4}
#define ADC1_Channel_IN10                       (TIMxPIN_t){GPIOA, GPIO_PIN_5}
#define ADC1_Channel_IN11                       (TIMxPIN_t){GPIOA, GPIO_PIN_6}
#define ADC1_Channel_IN12                       (TIMxPIN_t){GPIOA, GPIO_PIN_7}
#define ADC1_Channel_IN16                       (TIMxPIN_t){GPIOB, GPIO_PIN_1}
// Board Button Definition
#define PushButton                              (TIMxPIN_t){GPIOC, GPIO_PIN_13}
dazu habe ich eine Funktion geschrieben, die mir ein Array nach dem
Drücken des Buttons ausliest:
void ReadOutIntArray()
  if (HAL_GPIO_ReadPin(PushButton.port, PushButton.pin)==0){
    for (uint16_t i = 0; i <= 1027; i++)
      adcValue = dma0_buffer[i];
      USART_Transmit_Int(adcValue);
      USART_sendChar('\n');
      for (count = 0; count <= 50000; count++);
   /**ADC1 GPIO Configuration  */
    GPIO_InitStruct.Pin = ADC1_Channel_IN1.pin;
    GPIO_InitStruct.Mode = GPIO_MODE_ANALOG_ADC_CONTROL;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    HAL_GPIO_Init(ADC1_Channel_IN1.port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = ADC1_Channel_IN2.pin;
    HAL_GPIO_Init(ADC1_Channel_IN2.port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = ADC1_Channel_IN3.pin;
    HAL_GPIO_Init(ADC1_Channel_IN3.port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = ADC1_Channel_IN4.pin;
    HAL_GPIO_Init(ADC1_Channel_IN4.port, &GPIO_InitStruct);
//    GPIO_InitStruct.Pin = ADC1_Channel_IN7.pin ;
//    HAL_GPIO_Init(ADC1_Channel_IN7.port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = ADC1_Channel_IN8.pin;
    HAL_GPIO_Init(ADC1_Channel_IN8.port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = ADC1_Channel_IN9.pin;
23
    HAL_GPIO_Init(ADC1_Channel_IN9.port, &GPIO_InitStruct);
24
25
    GPIO_InitStruct.Pin = ADC1_Channel_IN10.pin;
26
    HAL_GPIO_Init(ADC1_Channel_IN10.port, &GPIO_InitStruct);
27
28
    GPIO_InitStruct.Pin = ADC1_Channel_IN11.pin;
29
    HAL_GPIO_Init(ADC1_Channel_IN11.port, &GPIO_InitStruct);
30
31
    GPIO_InitStruct.Pin = ADC1_Channel_IN12.pin;
32
    HAL_GPIO_Init(ADC1_Channel_IN12.port, &GPIO_InitStruct);
33
34
    GPIO_InitStruct.Pin = ADC1_Channel_IN16.pin;
35
    HAL_GPIO_Init(ADC1_Channel_IN16.port, &GPIO_InitStruct);
Ich verstehe jetzt nicht, warum das Auslesen durch Drücken des Buttons
nicht mehr funktioniert, wenn lediglich der
ADC1_Channel_IN7 aktiv ist. Wenn ich diesen im ADC_init auskommentiere,
funktionierts wieder.
Könnte mir jemand weiterhelfen. Die Ports PA2 und PC13 haben miteinander
auch nichts zu tun. Ich zumindest sehe keinen Fehler.
Gast #5044959
Hi
zum Lösen des Problems denke ich ist das noch nützlich
void activateReadOutButton()
   GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
   /*Configure GPIO pin : B1_Pin */
  GPIO_InitStruct.Pin = PushButton.pin;
  GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  HAL_GPIO_Init(PushButton.port, &GPIO_InitStruct);
Der Buffer ist 1027 lang
#define DataLength                                 1027
uint16_t dma0_buffer[DataLength];
Gast #5044961
Glaubst du nicht dass der Code für die DMA und ADC Initialisierung dafür
relevant wäre?
Warum benutzt du kein Array für die ganzen TIMxPIN Instanzen, durch
welches du dann einfach iterieren kannst anstatt den selben Code Zig mal
zu kopieren?
Gast #5044970
> dafür
> relevant wäre?
> zu kopieren?
Hi Dr. Sommer
Ich dachte, dass dies nicht relevant wäre. Entschuldigen Sie mich für
den Irrtum. Die Dateien habe ich angehängt.
> Dann sollte dir hier was auffallen:
Gleich nach deiner Frage habe ich den Fehler korrigiert und es zu i <
1027 abgeändert. Leider kein Erfolg
Gast #5044986
> dafür
> relevant wäre?
> zu kopieren?
Uebrigens, ich finde deinen Ansatz eine sehr gute Idee, aber wenn ich
bereits eine Schleife drin gehabt hätte, hätte ich wahrscheinlich nicht
einmal erkannt, dass der Fehler am ADC Kanal IN7 liegt.
Ich optimiere den Code aber gerne, wenn dieser funktioniert.
Gast #5045029
Welche deiner drei ADC-Initialisierungen ist denn jetzt relevant,
Init_ADC1 oder Init_ADC1_Test_single oder Init_ADC1_Test_differential?
sConfig.Channel = ADC1_Channel_IN1.pin | ADC1_Channel_IN2.pin | ADC1_Channel_IN3.pin | ADC1_Channel_IN4.pin | ADC1_Channel_IN7.pin | ADC1_Channel_IN8.pin | ADC1_Channel_IN11.pin | ADC1_Channel_IN12.pin;
Das ist doch verkehrt. Du kannst hier einen einzelnen Channel
übergeben, also z.B. ADC_CHANNEL_1. Das ist eine Channel -Nummer, und
keine Pin -Nummer. Wo ist dein DMA-Interrupt wo du auf Fertigstellung
reagierst?
 ADC1->CFGR &= ~ADC_CFGR_DMACFG;
Du schaltes den Continuous Mode aus, d.h. es werden alle Channels nur
einmal konvertiert? Warum greifst du überhaupt direkt auf die
Konfigurations-Register zu, wenn du vorher die HAL genutzt hast?
ADC1->SQR1 &= ~ADC_SQR1_L_0;
Du stellst 2 Channels ein, wo du doch vorher offensichtlich (aber
falsch) versuchst 8 Channels zu nutzen? Aber du setzt dennoch
hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
 um doch nur einen Channel zu konvertieren?
ADC1->CR &= ~ADC_CR_ADSTART;
Du schaltest den ADC aus aber nicht wieder an?
Deine ADC-Konfiguration ist derart vermurkst, es ist ein Wunder dass da
überhaupt was passiert. Das hat auf jeden Fall nichts mit eventuellen
Problemen in deinem Anfangs-Code zu tun. Vielleicht solltest du dir
erstmal Gedanken machen was du genau machen willst, welche Abläufe dein
Programm nimmt, und das hier genau erläutern.
Gast #5045106
Hallo Dr. Sommer
> reagierst?
Sie haben völlig Recht. Ich habe die Änderungen vorgenommen und das File
nochmals angehängt.
>  ADC1->CFGR &= ~ADC_CFGR_DMACFG;Du schaltes den Continuous Mode aus,
Ich hatte etwas probiert und war mir nicht sicher warum die Bits nicht
gesetzt wurden. Das Problem hat sich danach irgendwie selbst gelöst.
Ich habe die Zeilen auch nun entfernt.
Jedoch, um zB die Länge im SQR1 Register festzulegen, müsste ich auf
Registerebene zurückgreifen, auch wenn ich die HAL zuvor verwendet habe.
Dafür gibt es ja keine Funktion.
> ADC1->SQR1 &= ~ADC_SQR1_L_0;Du stellst 2 Channels ein, wo du doch vorher
> dennochhadc1.Init.ScanConvMode = ADC_SCAN_DISABLE; um doch nur einen
> ADC1->CR &= ~ADC_CR_ADSTART;Du schaltest den ADC aus aber nicht wieder
> an?
Ich benötige den One Shot mode. Ich konvertiere immer nur einen Wert.
Der ADC wird getriggert, da ich diesen nur zu bestimmten Zeiten
benötige.
Stimmt die Länge benötige ich nicht, da Scanconvmode disabled ist.
Ich habe den Code entsprechend angepasst.
Den ADC starte ich später, wenn ich ihn benötige. Dies geschieht anfangs
im Main und später in den jeweiligen Interrupts etc.
Kurz: Der ADC wird getriggert, nach jeder einzelnen Conversion sollte
die DMA die Daten wegschaufeln. Das funktioniert soweit.
Ich weiss schon was ich möchte, ich kann Ihnen leider nicht die ganze
Story erklären. Ich denke, es ist einfacher, wenn Sie mir die Fragen
direkt stellen. Ansonsten wird das hier nur eine Prosa.
Ich weiss schon, was ich tue und benötige. Die Einstellungen des ADC
jedoch ist eine andere Sache, aber ich habe da auch wieder dazugelernt.
Obwohl ich aber die Änderungen vorgenommen habe, scheint das mit dem
Button immer noch nicht zu funktionieren.
