Hard Fault STM32F103 beim Takteinstellen
Gast #5048322
ich versuche den Takt von einem STM32F103 µController auf 48MHz
einzustellen. Es klappt leider nicht.
Wenn ich die Funktion System_Clock_Setup() bei der Initialisierung
aufrufe, geht das in die Hard Fault. Weiss jemand zufällig woran es
liegt?
Danke im Voraus.
Debugger Ausgabe:
Hello ARM World!
[HardFault]
Stack frame:
 R0 =  00000000
 R1 =  40061020
 R2 =  40021000
 R3 =  080018F9
 R12 = 01010101
 LR =  08000BAB
 PC =  08000A8E
Der Quellcode:
#include <stdio.h>
#include <stdlib.h>
#include "diag/Trace.h"
#include "stm32f10x.h"
#include "cortexm/ExceptionHandlers.h"
#define GPIOB_LED GPIO_Pin_2
#define GPIOC_BZZ GPIO_Pin_13
#define TIMER_FREQUENCY_HZ (1000u)
volatile uint32_t timer_delayCount;
void Delay(uint32_t ticks);
void TimingDelay_Decrement(void);
void System_Clock_Setup(void);
#pragma GCC diagnostic push
23
#pragma GCC diagnostic ignored "-Wunused-parameter"
24
#pragma GCC diagnostic ignored "-Wmissing-declarations"
25
#pragma GCC diagnostic ignored "-Wreturn-type"
26
27
void System_Clock_Setup(void) {
28
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2, RCC_PLLMul_12); // 48MHz
29
  RCC_PLLCmd(ENABLE);
30
31
  while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) {
32
33
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
34
35
  /* Set HCLK, PCLK1, and PCLK2 to SCLK (these are default */
36
  RCC_HCLKConfig(RCC_SYSCLK_Div1); // 48 MHz
37
  RCC_PCLK1Config(RCC_HCLK_Div2);  // APB1 24MHz, max 36MHz
38
  RCC_PCLK2Config(RCC_HCLK_Div1);  // APB2 48MHz
39
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);  // 48MHz/4 = 12MHz
40
41
  RCC_ClocksTypeDef clocks;
42
  RCC_GetClocksFreq(&clocks);
43
  SysTick_Config(clocks.SYSCLK_Frequency / 100000); //10us
44
45
46
int main(int argc, char* argv[]) {
47
48
  trace_puts("Hello ARM World!");
49
50
51
  //SysTick_Config(SystemCoreClock / TIMER_FREQUENCY_HZ);
52
  System_Clock_Setup();
53
54
  trace_printf("System clock: %u Hz\n", SystemCoreClock);
55
56
  // Enable GPIO Peripheral clock
57
  /* GPIOA GPIOB and GPIOC clock enable */
58
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
59
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
60
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
61
62
  GPIO_InitTypeDef GPIO_InitStructure;
63
64
  /* PB2 LED configuration */
65
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
66
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
67
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
68
  GPIO_Init(GPIOB, &GPIO_InitStructure);
69
70
  /* PC13 Buzzer configuration */
71
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
72
73
74
  GPIO_Init(GPIOC, &GPIO_InitStructure);
75
76
  uint32_t seconds = 0;
77
78
  GPIO_SetBits(GPIOB, GPIOB_LED);
79
  GPIO_SetBits(GPIOC, GPIOC_BZZ);
80
  // Infinite loop
81
  while (1) {
82
    Delay(100);
83
84
    GPIOC->ODR ^= GPIOC_BZZ; // Toggle Buzzer
85
    GPIOB->ODR ^= GPIOB_LED; // Toggle LED
86
87
    Delay(100);
88
89
    ++seconds;
90
91
    // Count seconds on the trace device.
92
    trace_printf("Second %u\n", seconds);
93
94
95
96
void Delay(uint32_t ticks) {
97
  timer_delayCount = ticks;
98
  while (timer_delayCount != 0u)
99
100
101
102
void TimingDelay_Decrement(void) {
103
  if (timer_delayCount != 0u) {
104
    --timer_delayCount;
105
106
107
108
void SysTick_Handler(void) {
109
  TimingDelay_Decrement();
110
111
112
#pragma GCC diagnostic pop
