Optimierung eines Schieberegisters
OP #5062743
Hallo zusammen
Ich habe 3 Zähler des Typs unsigned(9 to 0)...
Diese möchte ich seriell auslesen können.
Dazu habe ich folgendes Konstrukt gemacht:
SCLK_Int ist das externe Clock signal
MISO ist der Ausgangsport
Shiftcount ist ebenfalls ein Zähler des Typs unsigned.
  process(SCLK_Int, SHCLR)
  begin
    if(rising_edge(SCLK_Int)) then
      if(ShiftCount = "00000") then MISO <= CounterA(0); end if;
      if(ShiftCount = "00001") then MISO <= CounterA(1); end if;
      if(ShiftCount = "00010") then MISO <= CounterA(2); end if;
      if(ShiftCount = "00011") then MISO <= CounterA(3); end if;
      if(ShiftCount = "00100") then MISO <= CounterA(4); end if;
      if(ShiftCount = "00101") then MISO <= CounterA(5); end if;
      if(ShiftCount = "00110") then MISO <= CounterA(6); end if;
      if(ShiftCount = "00111") then MISO <= CounterA(7); end if;
      if(ShiftCount = "01000") then MISO <= CounterA(8); end if;
      if(ShiftCount = "01001") then MISO <= CounterA(9); end if;
      if(ShiftCount = "01010") then MISO <= CounterB(1); end if;
      if(ShiftCount = "01011") then MISO <= CounterB(2); end if;
      if(ShiftCount = "01100") then MISO <= CounterB(3); end if;
      if(ShiftCount = "01101") then MISO <= CounterB(4); end if;
      if(ShiftCount = "01110") then MISO <= CounterB(5); end if;
      if(ShiftCount = "01111") then MISO <= CounterB(6); end if;
      if(ShiftCount = "10000") then MISO <= CounterB(7); end if;
23
      if(ShiftCount = "10001") then MISO <= CounterB(8); end if;
24
      if(ShiftCount = "10010") then MISO <= CounterB(9); end if;
25
26
      if(ShiftCount = "10011") then MISO <= CounterR(1); end if;
27
      if(ShiftCount = "10100") then MISO <= CounterR(2); end if;
28
      if(ShiftCount = "10101") then MISO <= CounterR(3); end if;
29
      if(ShiftCount = "10110") then MISO <= CounterR(4); end if;
30
      if(ShiftCount = "10111") then MISO <= CounterR(5); end if;
31
      if(ShiftCount = "11000") then MISO <= CounterR(6); end if;
32
      if(ShiftCount = "11001") then MISO <= CounterR(7); end if;
33
34
      ShiftCount <= ShiftCount + 1;
35
36
37
        ShiftCount <= "00000";
38
      end if;
39
    end if;
40
41
      if(SHCLR = '1') then
42
43
      end if;
44
  end process;
Sieht hier jemand optimierungs potential?
Wegen 4 Makrozellen, müsste ich sonst den grösseren CPLD nehmen.
Abgesehen davon, möchte ich auch noch was lernen, und sehen, ob man dies
optimieren kann.
Danke
OP #5063024
Lothar M. schrieb:
> Das ist kein Schieberegister. Das ist ein Multiplexer.
Das ist ein Problem.
Ich habe leider kein Schieberegister hinbekommen.
Wäre froh um Inputs.
Hatte es zuerst noch so versucht:
signal CounterA : unsigned(9 downto 0) := "0000000000";
signal CounterB : unsigned(9 downto 0) := "0000000000";
signal CounterR : unsigned(7 downto 0)  := "00000000";
signal CounterC : unsigned(27 downto 0);
CounterC <= CounterA & CounterB & CounterR;
Dann wollte ich mit
CounterC <= CounterC srl 1;
MISO <= CounterC(0);
Schieben uns ausgeben.
Leider kamen da  Errors wie:
ERROR:Xst:528 - Multi-source in Unit <main> on signal <CounterB<4>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <main> on signal <CounterB<3>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <main> on signal <CounterB<2>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <main> on signal <CounterB<1>>; this signal is connected to multiple drivers.
ERROR:Xst:528 - Multi-source in Unit <main> on signal <CounterB<0>>; this signal is connected to multiple drivers.
Wie du siehst sind nur CounterA und B 10 Bittig, der andere ist 8 Bit.
Lothar M. schrieb:
>> Wegen 4 Makrozellen
> Von wieviel insgesamt? Weniger als 33 wirst du nicht schaffen. Denn
> soviel brauchen deine 4 Zähler...
36 Hätte das CPLD und jetzt sind es halt halt 40.
Ich bin mir noch nicht sicher, ob ich ein CPLD von Altera (Max II Serie)
oder eines von Xilinx nehmen soll. Da ich gerade erst mit VHDL begonnen
habe, fehlt es mir an Erfahrung. Mit dem ISE von Xilinx bin ich bisher
aber recht zufrieden. Die xilinx CPLDs kosten einfach fast das doppelte.
Danke
Moderator (Firma: Titel) Persönliche Seite #5063067
Du wirst mit CPLDs ständig an solche Grenzen stoßen.
Ist das relevant? Welche Stückzahlen hast du und wie ist der Preis
verhandelt?
Mein Tipp: CPLDs sind tot, nimm Lattice MachXO2.
Ein Schieberegister ist in VHDL recht einfach beschrieben, aber das
hilft hier eh nichts, weil Schieberegister nur auf FPGAs elegant zu
implementieren sind. Denn mit Schieberegister brauchst du jedes
Zählerbit doppelt: einmal als Zählerregister und einmal im
Schieberegister.
Beim CPLD ist der Multiplexer eleganter, denn die Mikrowellen können
eine mächtige Logik abbilden.
Ja, und der Multiplexer-Zähler hat nochmal 5 Bits.
Klar, weil keinerlei "Ladelogik" für das Schieberegister vorgesehen ist:
du willst immer gleichzeitig Laden und Schieben. Zeichne dir das mal
auf.
Steig auf FPGAs um. Dann ist Schaltungsbeschreibung mit VHDL tatsächlich
schön...
OP #5063202
> verhandelt?
Nein, ist nicht relevant. Hast du schon recht.
MachX02 sind in der Tat günstige Chips.
Vermutlich werde ich das jetzige Design noch mit den restlichen CPLDs
machen.
Der XC9572XL-10 lebt übrigens noch etwa 5 Jahre lang.
  • [vhdl]VHDL-Code[/vhdl]
