gcc-avr Fehlermeldung wenn math.h inc.
OP #5160181
gcc version 7.2.0 (GCC)
ich habe die letzten zwei drei Wochen nicht an meinem Projekt
weitergearbeitet. Dies wollte ich heute machen und bekomme folgende
Fehlermeldung:
avr-gcc -Os -Wall -mmcu=atmega16m1 -DF_CPU=16000000UL -I../_gemeinsam -I../16_6 -I/usr/include -c ../_gemeinsam/25AA512.c -o obj/Release/_gemeinsam/25AA512.o
In file included from /usr/avr/include/util/delay.h:46:0,
                 from ../_gemeinsam/25AA512.h:7,
                 from ../_gemeinsam/25AA512.c:1:
/usr/include/bits/mathcalls-helper-functions.h:21:36: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __fpclassify,, (_Mdouble_ __value))
/usr/include/bits/mathcalls-helper-functions.h:25:33: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __signbit,, (_Mdouble_ __value))
/usr/include/bits/mathcalls-helper-functions.h:30:31: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __isinf,, (_Mdouble_ __value)) __attribute__ ((__const__));
/usr/include/bits/mathcalls-helper-functions.h:33:32: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __finite,, (_Mdouble_ __value)) __attribute__ ((__const__));
/usr/include/bits/mathcalls-helper-functions.h:36:31: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __isnan,, (_Mdouble_ __value)) __attribute__ ((__const__));
/usr/include/bits/mathcalls-helper-functions.h:39:33: error: '_Float128' is not supported on this target
 __MATHDECL_1 (int, __iseqsig,, (_Mdouble_ __x, _Mdouble_ __y));
/usr/include/bits/mathcalls-helper-functions.h:39:48: error: '_Float128' is not supported on this target
24
25
26
/usr/include/bits/mathcalls-helper-functions.h:42:37: error: '_Float128' is not supported on this target
27
 __MATHDECL_1 (int, __issignaling,, (_Mdouble_ __value))
28
29
Process terminated with status 1 (0 minute(s), 0 second(s))
30
8 error(s), 0 warning(s) (0 minute(s), 0 second(s))
Diese Fehler tritt auf, wenn irgendwo die <math.h> eingebunden wird. In
diesem Fall weil in der delay.h die math.h eingebunden wird (Zeile 46)
Nun weiß ich aber leider nicht, wie ich den "Fehler" lösen kann. Es
scheint bei einem der letzten Updates dazu gekommen zu sein. (Habe einen
Projektstand von Mai 2017 compiliert und dort die gleiche Fehlermeldung)
Würde mich sehr über Hilfestellung freuen.
