Bosch BME680 Luftgütesensor, Verständnisproblem
Gast #5226692
Hallo!
Anhand des unter
https://github.com/BoschSensortec/BME680_driver
geliefeten Codes von Bosch versuche ich den o.g. Sensor zum Leben zu
erwecken.
Die Datei README.md liefert eine Schritt-für-Schritt-Anleitung, dessen
Schritte mir leider zu groß sind.
Beispiel:
## Usage guide
### Initializing the sensor
To initialize the sensor, you will first need to create a device structure. You can do this by creating an instance of the structure bme680_dev. Then go on to fill in the various parameters as shown below
#### Example for I2C
  struct bme680_dev gas_sensor;
  gas_sensor.dev_id = BME680_I2C_ADDR_PRIMARY;
  gas_sensor.intf = BME680_I2C_INTF;
  gas_sensor.read = user_i2c_read;         <-----------!!!
  gas_sensor.write = user_i2c_write;       <-----------!!!
  gas_sensor.delay_ms = user_delay_ms;     <-----------!!!
  int8_t rslt = BME680_OK;
  rslt = bme680_init(&gas_sensor);
Außerdem:
### Reading sensor data
#### Example for reading all sensor data
  struct bme680_field_data data;
  while(1)
    rslt = bme680_get_sensor_data(&data, &gas_sensor);
    printf("T: %.2f degC, P: %.2f hPa, H %.2f %%rH ", data.temperature / 100.0f,
      data.pressure / 100.0f, data.humidity / 1000.0f );
    /* Avoid using measurements from an unstable heating setup */
    if(data.status & BME680_GASM_VALID_MSK)
      printf(", G: %d ohms", data.gas_resistance);
    printf("\r\n");
Und..
### Templates for function pointers
void user_delay_ms(uint32_t period)
     * Return control or wait,
     * for a period amount of milliseconds
int8_t user_i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    int8_t rslt = 0; /* Return 0 for Success, non-zero for failure */
     * The parameter dev_id can be used as a variable to store the I2C address of the device
     * Data on the bus should be like
     * | I2C action | Data                |
24
25
     * | Start      | -                   |
26
     * | Write      | (reg_addr)          |
27
     * | Stop       | -                   |
28
     * | Start      | -                   |
29
     * | Read       | (reg_data[0])       |
30
     * | Read       | (....)              |
31
     * | Read       | (reg_data[len - 1]) |
32
     * | Stop       | -                   |
33
34
35
36
    return rslt;
37
38
39
int8_t user_i2c_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
40
41
42
43
44
45
46
47
48
49
50
51
52
     * | Start      | -                   |
53
54
     * | Write      | (reg_data[0])       |
55
     * | Write      | (....)              |
56
     * | Write      | (reg_data[len - 1]) |
57
     * | Stop       | -                   |
58
59
60
61
    return rslt;
62
Die mit "!" gekennzeichneten Zeilen verstehe ich nicht. Ich vermute, der
Anwender soll seinem Code entsprechend I2C-Anweisungen durchführen. Aber
wie nur?
Gast #5226741
Sven G. schrieb:
> Die von Dir angesprochen Zeilen musst du selber Implementieren.
Das hab´ich mir schon gedacht.. Nur, im ersten Abschnitt INIT, wird die
Struktur gas_sensor.read mittels Funktion user_i2c_read; befüllt.
Warum ist denn dort nicht die Parameterliste angegeben?
dev_id,  reg_addr,  *reg_data,  len angegeben?
Gast #5227033
NEIN!
Da wird ein Ptr auf eine Funktion zugewiesen!
Weil es KEIN Funktionsaufruf ist!
#5227051
Bei den gekennzeichneten Stellen mußt du Zeiger auf deine Funktionen
zum Zugriff auf I2C (oder SPI) und für eine Delay-Funktion einfügen.
Falls du das Konzept function pointer noch nicht kennst, ist jetzt
genau der richtige Zeitpunkt, das nachzulesen.
Weiter unten sind leere Funktionsrümpfe für diese Funktionen gezeigt,
aus denen du ersehen kannst, welche Parameter der Code von Bosch
übergibt, wenn er deine Funktionen aufruft und welches Ergebnis er
jeweils erwartet.
In bme680_defs.h findest du auch die typedefs für die function pointer
und Makros für die erwarteten Rückgabewerte (z.B. BME680_OK, wenn alles
glatt gelaufen ist).
Gast #5241494
Vielen Dank Axel. Über Funktionspointer bin ich tatsächlich noch nicht
gestolpert. Und, ich muss gestehen, dass mich die Lektüre des Artikels
unter https://www.mikrocontroller.net/articles/Funktionszeiger_in_C nur
mehr verwirrt hat. Zitat: "Um Menüs oder ähnliche Dinge aufzubauen, ist
es oft praktisch, ein Array von Funktionszeigern zu definieren." Wo ist
da der zusammenhang?!
Ich vermute stark, ich muss das u.g. Template mit Leben füllen. Vermute
ferner, dass ich eine Funktion implementieren soll, dessen Rückgabewert
der BME-Antwort gemäß Parameterliste entspricht. Nur warum ist der
Rückgabewert ein int8_t?
[c]
     * | Start      | -                   |
     * | Stop       | -                   |
     * | Start      | -                   |
     * | Read       | (....)              |
     * | Stop       | -                   |
    return rslt;
#5241566
Dieser Zusammenhang ist in der Tat nicht zwingend. Die hauptsächliche
Verwendung von Funktionspointern sind Callback-Funktionen
(https://de.wikipedia.org/wiki/Rückruffunktion)
Ganz konkret füllst du für die Treiber-Software von Bosch eine Struktur
mit Funktionszeigern und der Treiber ruft deine Funktionen immer dann
auf (Callback) wenn er es für nötig befindet. Der Vorteil besteht an
dieser Stelle darin, daß der exakt gleiche Code von Bosch verwendet
werden kann, um den Sensor abzufragen, vollkommen egal ob der Sensor per
I²C oder SPI angebunden ist, wie das Interface konkret aufgebaut ist und
sogar, ob es vielleicht mehrere solche Sensoren am gleichen Bus gibt.
Und das einfach nur, indem du ein paar passende Funktionen für die
low-Level Kommunikation mit dem Sensor schreibst und Zeiger auf (im
Quelltext praktisch: die Namen für) diese Funktionen in eine Struktur
füllst.
Das ist der kleinste Wert, den eine Funktion in C zurückgeben kann. Und
tatsächlich erwartet die Bosch Software ja auch nur entweder 0 oder
einen von 0 verschiedenen Wert.
