Cast between a pointer to object and an integral type
Gast #5235713
I want to calculate the address difference of var_a compared to base
address of structure.
The solution works fine but I get the following warning:
**"Cast between a pointer to object and an integral type."**
    typedef struct
        volatile int var_a;
        volatile int var_b;
    } struct_a;
    struct_a *pa;
Access:
    adrDiff_p = (int)&pa->var_a - (int)pa;
Do you have any better idea?
Persönliche Seite #5235854
Offsetof is indeed compiler-independent.
Its a macro in the C stanndard.
See http://en.cppreference.com/w/cpp/types/offsetof
The wikipedia article on this topic has more information on it and
features a sample implementation.
See https://en.m.wikipedia.org/wiki/Offsetof?wprov=sfla1
By the way: this is a german forum with a similar english one on
embdev.net
Best regards,
N.G.
Gast #5236096
please try this
typedef struct
  volatile int var_a;
  volatile int var_b;
  uint8_t var_c;
  uint8_t var_d;
} struct_a;
struct_a dummy;
struct_a *pa = &dummy;
int main(void) {
uint32_t addr_diff;
  addr_diff = (void *)&(pa->var_a) - (void *)pa;
  printf ("diff: %x\n\r", addr_diff);
  addr_diff = (void *)&(pa->var_b) - (void *)pa;
  addr_diff = (void *)&(pa->var_c) - (void *)pa;
23
24
25
  addr_diff = (void *)&(pa->var_d) - (void *)pa;
26
compiles without errors or warnings.
#5238685
This is incorrect. Since void has no size, you cannot do pointer
arithmetic with void*. You have to use char*.
Well, I get a lot of errors and warnings from it. If I fix the missing
headers and closing parenthesis in main, I still get:
voidp.c: In function ‘main’:
voidp.c:19:36: warning: pointer of type ‘void *’ used in subtraction [-Wpointer-arith]
voidp.c:22:36: warning: pointer of type ‘void *’ used in subtraction [-Wpointer-arith]
voidp.c:25:36: warning: pointer of type ‘void *’ used in subtraction [-Wpointer-arith]
voidp.c:28:36: warning: pointer of type ‘void *’ used in subtraction [-Wpointer-arith]
Gast #5238807
Rolf M. schrieb:
> This is incorrect.
I got this with default compiler options after installation:
-------------- Build: Release in dummy (compiler: GNU GCC
Compiler)---------------
mingw32-gcc.exe -Wall -O2  -c C:\...\C_CodeBlocks\dummy\main.c -o
obj\Release\main.o
mingw32-g++.exe  -o bin\Release\dummy.exe obj\Release\main.o  -s
Output file is bin\Release\dummy.exe with size 19.00 KB
Process terminated with status 0 (0 minute(s), 0 second(s))
0 error(s), 0 warning(s) (0 minute(s), 0 second(s))
#5238816
If you add -pedantic to the options, you'll get the warning. I recommend
to add something like -std=c99 -pedantic -Wall -Wextra to the compiler
command line.
Anyway, as I said, this is not correct C, even if gcc accepts it. The OP
wanted a compiler independant solution.
Johann L. schrieb:
> FYI, gcc allows arithmetic on void*, adding even more confusion
Yes, unfortunately, it even does in strict ISO C mode.
Beitrag #5239015 wurde von einem Moderator gelöscht.
Beitrag #5239237 wurde von einem Moderator gelöscht.
