SSD1306 clear buffer / display code
OP #5305386
Hallo!
kann sich mal jemand ssd1306_display_clear() anschauen, ich bekomme es
nicht hin das Display zu löschen. Der Rest funktioniert.
https://pastebin.com/vXEgC4bG
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/gpio.h"
#include "driver/i2c.h"
#include "esp_err.h"
#include "esp_log.h"
#include "ssd1366.h"
#include "font8x8_basic.h"
#define SDA_PIN GPIO_NUM_21
#define SCL_PIN GPIO_NUM_22
#define tag "ssd1306"
void i2c_master_init() {
  i2c_config_t i2c_config = {
23
24
    .mode = I2C_MODE_MASTER,
25
    .sda_io_num = SDA_PIN,
26
    .scl_io_num = SCL_PIN,
27
    .sda_pullup_en = GPIO_PULLUP_ENABLE,
28
    .scl_pullup_en = GPIO_PULLUP_ENABLE,
29
    .master.clk_speed = 1000000
30
31
32
  i2c_param_config(I2C_NUM_0, &i2c_config);
33
  i2c_driver_install(I2C_NUM_0, I2C_MODE_MASTER, 0, 0, 0);
34
35
36
void ssd1306_init() {
37
  esp_err_t espRc;
38
  i2c_cmd_handle_t cmd = i2c_cmd_link_create();
39
  i2c_master_start(cmd);
40
    i2c_master_write_byte(cmd, (OLED_I2C_ADDRESS << 1) | I2C_MASTER_WRITE, true);
41
    i2c_master_write_byte(cmd, OLED_CONTROL_BYTE_CMD_STREAM, true);
42
      i2c_master_write_byte(cmd, OLED_CMD_SET_CHARGE_PUMP, true);
43
        i2c_master_write_byte(cmd, 0x14, true); // 0x14(enable)
44
      i2c_master_write_byte(cmd, OLED_CMD_SET_SEGMENT_REMAP, true); // reverse left-right mapping
45
      i2c_master_write_byte(cmd, OLED_CMD_SET_COM_SCAN_MODE, true); // reverse up-bottom mapping
46
    i2c_master_write_byte(cmd, OLED_CMD_DISPLAY_ON, true);
47
  i2c_master_stop(cmd);
48
  espRc = i2c_master_cmd_begin(I2C_NUM_0, cmd, 10/portTICK_PERIOD_MS);
49
  if (espRc == ESP_OK) {
50
    ESP_LOGI(tag, "ssd1306_init successfully");
51
  } else {
52
    ESP_LOGE(tag, "ssd1306_init failed. code: 0x%.2X", espRc);
53
54
  i2c_cmd_link_delete(cmd);
55
56
57
void ssd1306_display_clear(void) {
58
  i2c_cmd_handle_t cmd;
59
  uint8_t zero[128] = {0};
60
  for (uint8_t i = 0; i < 8; i++) {
61
62
63
64
      i2c_master_write_byte(cmd, OLED_CONTROL_BYTE_CMD_SINGLE, true);
65
      i2c_master_write_byte(cmd, 0xB0 | i, true); // Set GDDRAM page start address
66
        i2c_master_write_byte(cmd, OLED_CONTROL_BYTE_DATA_STREAM, true);
67
        i2c_master_write(cmd, zero, 128, true);
68
69
70
71
72
73
74
void ssd1306_display_text(void *arg_text) {
75
  char *text = (char*)arg_text;
76
  uint8_t text_len = strlen(text);
77
78
  uint8_t cur_page = 0;
79
80
81
82
83
  i2c_master_write_byte(cmd, 0x00, true); // reset column
84
  i2c_master_write_byte(cmd, 0x10, true);
85
  i2c_master_write_byte(cmd, 0xB0 | cur_page, true); // reset page
86
87
88
89
  for (uint8_t i = 0; i < text_len; i++) {
90
    if (text[i] == '\n') {
91
92
93
94
95
96
97
      i2c_master_write_byte(cmd, 0xB0 | ++cur_page, true); // increment page
98
99
100
101
    } else {
102
103
104
105
106
      i2c_master_write(cmd, font8x8_basic_tr[(uint8_t)text[i]], 8, true);
107
108
109
110
111
112
113
114
void app_main(void) {
115
  i2c_master_init();
116
  ssd1306_init();
117
  ssd1306_display_clear();
118
  ssd1306_display_text("ABCDEFGHIJKLMNOP");
119
Kruder und ineffizienter Code. Was geht denn nicht bzw. wass passiert
mit Deinem Code?
Ich würde den Horizontal Addressing Mode nutzen, dann kannst Du in einem
durchschreiben. Geht schneller und spart Speicherplatz.
Ich hab das ganze so gelöst:
void lcd_clrscr(void){
    memset(displayBuffer, 0x00, sizeof(displayBuffer));
#if defined SSD1306
    lcd_data(displayBuffer, sizeof(displayBuffer));
#elif defined SH1106
    for (uint8_t i=0; i <= DISPLAY_HEIGHT/8; i++) {
        uint8_t actualLine[DISPLAY_WIDTH];
        for (uint8_t j=0; j< DISPLAY_WIDTH; j++) {
            actualLine[j]=displayBuffer[i*DISPLAY_WIDTH+j];
        lcd_data(actualLine, sizeof(actualLine));
        lcd_gotoxy(0, i);
#endif
    lcd_home(); // gotoxy(0,0)
void lcd_data(uint8_t data[], uint16_t size) {
    i2c_start(LCD_I2C_ADR);
    i2c_byte(0x40);  // 0x00 for command, 0x40 for data
    for (uint16_t i = 0; i<size; i++) {
        i2c_byte(data[i]);
23
24
    i2c_stop();
25
Mein Library findest du unter:
https://github.com/Sylaina/oled-display/
Sie ist für Atmegas geschrieben, für andere µC müssen nur die
I2C-Funktionen entsprechend umgeschrieben werden.
OP
> mit Deinem Code?
Ja, er löscht nur unzuverlässig. Mal gehts, mal gehts nicht. Was meinst
Du mit kruder Coder?
Danke, das schau ich mir an!
Meine funktionierende Prozedur sieht ein bisschen anders aus:
        i2c_start();
        i2c_send(i2c_address << 1);    // address + write
        i2c_send(0x00);                // command
        i2c_send(0xB0 + page);         // set page 0-7
        i2c_send(0x21);                // column address
        i2c_send(0x00);                // first column =0
        i2c_send(width - 1);           // last column (=127)
        i2c_stop();
        // send one page of buffer to the display
        i2c_start();
        i2c_send(0x40);                // data
        for (uint_fast8_t column = 0; column < width; column++)
            i2c_send(buffer[index++]);
        i2c_stop();
Das ganze wiederhole ich 8 mal für die 8 pages. Wobei mein Buffer ein
komplettes Abbild des Display-SPeichers ist. Du könntest in der
for-Schleife einfach 128 mal eine 0 senden, um das Display zu löschen.
OP
Hi Stefan, danke für deinen Code!
Das war mein Plan:
(I2C commands entfernt)
    i2c_master_write_byte(cmd, 0x80, true); // OLED_CONTROL_BYTE_CMD_SINGLE
    i2c_master_write_byte(cmd, 0x00, true); // OLED_CONTROL_BYTE_CMD_STREAM
