g++, OpenSSL Linker meckert
OP (Firma: JDCC) #5378080
Servus,
ich mache gerade die ersten Gehversuche mit C++ und Gnu.
Beispiel ist
https://www.codeproject.com/Articles/98355/SMTP-Client-with-SSL-TLS
OS: W7, Gnu 6.3.0 (MinGW)
Um das Teil zu kompilieren und zu linken:
g++ -o cstmp.exe -Iopenssl-0.9.8l\inc32 csmtp.cpp main.cpp base64.cpp
md5.cpp -lws2_32 -lwsock32  -Lopenssl-0.9.8l\out32 2>err.txt
err.txt:
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7635):
undefined reference to `SSL_read'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x764a):
undefined reference to `SSL_get_error'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x76fc):
undefined reference to `SSL_pending'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7e90):
undefined reference to `SSL_write'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7ea5):
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7f7d):
undefined reference to `SSL_library_init'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7f82):
undefined reference to `SSL_load_error_strings'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7f87):
undefined reference to `SSLv23_client_method'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x7f8f):
undefined reference to `SSL_CTX_new'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x804f):
undefined reference to `SSL_new'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x80ca):
undefined reference to `SSL_set_fd'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x80f6):
undefined reference to `SSL_ctrl'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x839b):
undefined reference to `SSL_connect'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x83b9):
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x848b):
undefined reference to `SSL_shutdown'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x849c):
undefined reference to `SSL_free'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x84c7):
undefined reference to `SSL_CTX_free'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x84e0):
undefined reference to `ERR_remove_state'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x84e5):
undefined reference to `ERR_free_strings'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x84ea):
undefined reference to `EVP_cleanup'
C:\Users\jd\AppData\Local\Temp\cciHl5Zl.o:csmtp.cpp:(.text+0x84ef):
undefined reference to `CRYPTO_cleanup_all_ex_data'
collect2.exe: error: ld returned 1 exit status
Im Hexdump der Lib in openssl-0.9.8l\out32\ssleay32.lib finde ih zB
SSL_read
Irgendwas fehlt da noch bzw. habe ich übersehen ...
Bei Google finde ich da auch nichts was weiterhilft. Die Dokumentation
der Compiler-
und Linkerflags ist auch so eher lala ;)
Hat da vielleicht jemand einen Tip ?
Gast #5378083
Moin,
sieht für mich spontan so aus, dass in der csmtp.cpp die Headerdatei für
die SSL Funktionen fehlt. Vllt. findet er auch den Pfad nicht zu der
Datei.
Waldfee
Gast #5378135
Joachim D. schrieb:
> Geht auch gemischt ;)
Ohgott...
Joachim D. schrieb:
> Wir wollen mittelfristig in der
> Firma auf Linux wechseln,
Ja dann gleich richtig machen und vorsorgen! Ein / statt \ zu tippen ist
auch nicht so der gigantische Aufwand. Zum Einstieg kannst du ja mit
Linux experimentieren... wenn's funktioniert kannst du dir dann den Spaß
mit Windows antun.
#5378167
Hui. Wir sind bei OpenSSL 1.1.x, die 0.9.x sind hoffnungslos veraltet.
In Deiner Linker Kommandozeile sehe ich das Verzeichnis aber nicht die
ssleay32.lib oder crypto32.lib Dateien. Du musst dem Linker schon sagen
welche Libs er mit einlinken soll.
OP (Firma: JDCC) #5378178
Mit kleinem 'l':
c:/mingw/bin/../lib/gcc/mingw32/6.3.0/../../../../mingw32/bin/ld.exe:
cannot find -lopenssl-0.9.8l\out32\libeay32.lib
cannot find -lopenssl-0.9.8l\out32\ssleay32.lib
Gast #5378204
-L spezifiziert ein Verzeichnis, in dem nach Dateien gesucht wird, die
per -l angegeben werden. Dateien per -lfoo werden nach dem Schema
"libfoo.a" in den -L Verzeichnissen gesucht. Wenn man ganze Dateipfade
angibt ala openssl-0.9.8l\out32\ssleay32.lib darf man -l noch -L nutzen.
OP (Firma: JDCC) #5378213
md5.cpp -lws2_32 -lwsock32  -Lopenssl-0.9.8l\out32 -lssleay32 -llibeay32
2>err.txt
ergibt:
openssl-0.9.8l\out32/ssleay32.lib(tmp32/ssl_ciph.obj):(.text[_ssl_cipher
_get_evp]+0x6):  undefined reference to `_chkstk'
_apply_rule]+0x6):  undefined reference to `_chkstk'
_process_rulestr]+0x6):  undefined reference to `_chkstk'
openssl-0.9.8l\out32/ssleay32.lib(tmp32/ssl_ciph.obj):(.text[_ssl_create
_cipher_list]+0x6):  undefined reference to `_chkstk'
openssl-0.9.8l\out32/ssleay32.lib(tmp32/ssl_ciph.obj):(.text[_SSL_CIPHER
_description]+0x6):  undefined reference to `_chkstk'
openssl-0.9.8l\out32/ssleay32.lib(tmp32/ssl_lib.obj):(.text[_SSL_has_mat
ching_session_id]+0x6):  more undefined references to `_chkstk' follow
ching_session_id]+0xb):  undefined reference to `__security_cookie'
(insgesamt 751 fehlende ;)
Gast #5378214
Oliver S. schrieb:
> Warum,
> musst du ergründen.
Weil das -l zu viel ist. i.A. braucht der MinGW-GCC übrigens keine .lib
Dateien, man kann direkt gegen die DLL linken. Mach doch mal "nm
openssl-0.9.8l\out32" und schau ob da die benötigten Symbole drin sind.
OP (Firma: JDCC) #5378240
Dr. Sommer schrieb:
> Oliver S. schrieb:
>> Warum,
>> musst du ergründen.
nm -g openssl-0.0.81\out32\ssleay32.lib
ergibt eine ziemlich große Datei, "SSL_read" ist drin:
Z 10: 00000000 R ??_C@_08DAJNHMMC@SSL_read?$AA@
Z 473:          U _SSL_read
Z 1387: 00000000 T _SSL_read
Z 2109: U _SSL_read
Gast #5378274
Der letzte Post
legt nahe dass das SSL_read jetzt gefunden wird.
Kompiliere openssl selbst neu mit dem GCC, oder kompiliere dein Programm
mit MSVC.
Joachim D. schrieb:
> Der Quellcode ist nicht von mir. Wir wollen mittelfristig in der
> Firma auf Linux wechseln, deshalb auch GNU.
Man kann das selbe Programm unter Windows mit MSVC und unter Linux mit
GCC kompilieren, wenn es sauber geschrieben wurde (d.h. man achtet
darauf was der C(++)-Standard garantiert, nicht das was GCC/MSVC sonst
noch erlauben). Man muss nicht unbedingt den GCC unter Windows nutzen;
MSVC hat da schon gewisse Vorteile (z.B. kleinere .exe-Dateien,
schnellere Kompilation, Kompatibilität mit mehr Bibliotheken).
