ESP32 nRF24L01 Funkmodul
OP #5379635
ich möchte eine Funkverbindung mit  nRF24L01 Modulen zwischen zwei esp32
aufbauen.
Dazu habe ich das Modul so verkabelt:
CE         -> GPIO 18
CSN        -> GPIO 05
MISO       -> GPIO 12
MOSI       -> GPIO 13
CLK        -> GPIO 14
IRQ        -> nicht verbunden
Das Layout vom esp32 ist dieses:
https://raw.githubusercontent.com/playelek/pinout-doit-32devkitv1/master/pinoutDOIT32devkitv1.png
Mein Problem ist, dass keine Verbindung aufgebaut wird.
Das habe ich mit volgendem Code herrausgefunden:
(Das ist die void setup vom "Getting Started" Beispiel, wo ich noch dies
eingefügt habe:
if (radio.begin()) { Serial.println("Alles Super");
      else{ Serial.println("Nicht gut");
    * Getting Started example sketch for nRF24L01+ radios
    * This is a very basic example of how to send data from one node to another
    * Updated: Dec 2014 by TMRh20
    #include <SPI.h>
    #include "RF24.h"
    /****************** User Config ***************************/
    /***      Set this radio as radio number 0 or 1         ***/
    bool radioNumber = 0;
    /* Hardware configuration: Set up nRF24L01 radio on SPI bus plus pins 7 & 8 */
    RF24 radio(5,18); //CE, CSN
    byte addresses[][6] = {"1Node","2Node"};
    // Used to control whether this node is sending or receiving
    bool role = 0;
    void setup() {
24
      Serial.begin(115200);
25
      Serial.println(F("RF24/examples/GettingStarted"));
26
      Serial.println(F("*** PRESS 'T' to begin transmitting to the other node"));
27
28
29
30
31
32
33
34
      delay(6000);
35
      // Set the PA Level low to prevent power supply related issues since this is a
36
     // getting_started sketch, and the likelihood of close proximity of the devices. RF24_PA_MAX is default.
37
      radio.setPALevel(RF24_PA_LOW);
38
39
      // Open a writing and reading pipe on each radio, with opposite addresses
40
      if(radioNumber){
41
      radio.openWritingPipe(addresses[1]);
42
      radio.openReadingPipe(1,addresses[0]);
43
      }else{
44
      radio.openWritingPipe(addresses[0]);
45
      radio.openReadingPipe(1,addresses[1]);
46
47
48
      // Start the radio listening for data
49
      radio.startListening();
50
51
                void loop(){
52
In der Datei "arduino_pins.h" habe ich volgendes geändert:
Ich habe
static const uint8_t SS    = 5;
static const uint8_t MOSI  = 23;
static const uint8_t MISO  = 19;
static const uint8_t SCK = 18;
gegen
static const uint8_t MOSI  = 13;
static const uint8_t MISO  = 12;
static const uint8_t SCK   = 14;
ausgetauscht.
leider wird im seriellen Monitor der Arduino IDE immer "Nicht gut"
angezeigt.
Ich hoffe, dass mir jemand Weiterhelfen kann.
Viele Güße
Flo
