switch-case Problem
Gast #5432890
Hallo liebe Forenmitglieder,
ich bin gerade dabei, mich in die VHDL-Welt anzutatsten. Aus diesem
Grund schreibe ich gerade kleine simple VHDL-Programme und bin auch
schon leider um stocken gekommen.
library IEEE;
use IEEE.std_logic_1164.all;
entity col_row_buttons is
  generic (COL_ROW_BUTTONS : natural := 4;
       KEYPAD_BUTTONS   : natural := 16);
  port (
    clk_i          : in std_logic;
    reset_i       : in std_logic;
    row_buttons_i    : in std_logic_vector (COL_ROW_BUTTONS - 1 downto 0);
    col_buttons_o    : out std_logic_vector (COL_ROW_BUTTONS - 1 downto 0);
    pressed_button_o   : out std_logic_vector (KEYPAD_BUTTONS - 1 downto 0));
end col_row_buttons;
architecture rtl of col_row_buttons is
    signal s_column_buttons  : std_logic_vector (COL_ROW_BUTTONS - 1 downto 0);
    signal s_pressed_button  : std_logic_vector (KEYPAD_BUTTONS - 1 downto 0);
  p_column : process (clk_i, reset_i)
    variable var_column : natural in range 0 to 3;
23
  begin
24
    if reset_i = '1' then
25
      s_column_buttons <= x"F";
26
      var_column := 0;
27
    elsif clk_i = '1' and clk_i'event then
28
      if s_presc_en = '1' then
29
        if var_column = 0 then
30
          s_column_buttons <= "1110";
31
        elsif var_column = 1 then
32
          s_column_buttons <= "1101";
33
        elsif var_column = 2 then
34
          s_column_buttons <= "1011";
35
        elsif var_column = 3 then
36
          s_column_buttons <= "0111";
37
          var_column := 0;
38
        end if;
39
        var_column := var_column + 1;
40
      end if;
41
    end if;
42
  end process p_column;
43
44
  col_buttons_o <= s_column_buttons;
45
46
  p_press_buttons : process (clk_i, reset_i)
47
    variable var_temp : std_logic_vector (COL_ROW_BUTTONS - 1 downto 0);
48
  begin
49
50
      s_pressed_button <= (others => '1');
51
52
      case s_column_buttons is -- hier gibt er mir die Fehlermeldung aus
53
        when "1110" =>
54
55
      end case;
56
    end if;
57
  end process;
58
end architecture rtl;
Der Fehler liegt in der case Zeile. Wenn ich das in Modelsim kompeliere
bekomme ich als Fehlermeldung: "Array type case expression must be of a
locally static subtype" heraus. Mir ist klar, dass die die case
Bedingung statisch sen muss, deshalb habe ich auh probiert, diese zuert
in eine Variable zuzuweißen und die Variable als Bedingung abzufragen,
jedach kamm hier auch die selbe Fehlermeldung :(
Ich hoffe ihr könnt mir da weiterhelfen.
Lg
(Firma: www.elpra.de) Persönliche Seite #5432913
Hallo Johannes,
das Problem ist, dass die Länge deines Vektors s_column_buttons eine
generische Länge hat (Längen hängt ab von COL_ROW_BUTTONS).
Ersetze bitte mal COL_ROW_BUTTONS durch die eigentliche Zahl und du
wirst sehen, dass die Meldung verschwindet. Das macht in deinem Fall
auch Sinn, weil die einzelnen Fälle auch eine fixe Länge haben, daher
braucht auch der "Probant" eine fixe Länge. Dieses Verhalten ist
übrigens in der VHDL Spezifikation so definiert, wenn du mal tiefer
einsteigen möchtest, kann ich empfehlen da mal einen kleinen Blick
reinzuwerfen.
Du solltest mal folgendes probieren:
case s_column_buttons(3 downto 0) is
Damit ist die Abfrage genauso locally static, wie die einzelnen Fälle
die du angibst.
Entsprechend solltest du noch die Generics einschränken, damit das bei
Fehlkonfiguration nicht um die Ohren fliegt:
  generic (
       COL_ROW_BUTTONS : natural range 4 to 32 := 4;  -- 32 ist hier mal ein beliebiges Maximum
Ich habe hier gerade kein Modelsim Zugriff, aber zumindest prinzipiell
sollte es so korrekt sein.
Gast #5432967
Hat wirklich geholfen vielen, vielen Dank :)
Jedoch habe ich diesen Absatz nicht ganz verstanden:
generic (
 --ein beliebiges Maximum
Von 3 downto 0 (also 4) ist mein eigentliches Signal, aber warum bis 32
definieren und wozu eigentlich?
  • [vhdl]VHDL-Code[/vhdl]
