stm32f4 discovery can transmit problem
OP (Firma: uni rostock) #5523867
this is my program for can transmit .i just want to see through
oscilloscope wether something is being sent or not .i am using stm32f407
and attolic true studio for it.but i am unable to see any signal on my
tx pin.kindly tell me where is my mistake
#include "stm32f4xx.h"
int main(void)
  GPIO_InitTypeDef      GPIO_InitStructure;
  RCC_ClocksTypeDef     RCC_Clocks;
  CAN_InitTypeDef       CAN_InitStructure;
  CAN_FilterInitTypeDef CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  RCC_GetClocksFreq(&RCC_Clocks);
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource0, GPIO_AF_CAN1);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource1, GPIO_AF_CAN1);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler = 5;
  CAN_Init(CAN1, &CAN_InitStructure);
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh      = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow       = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh  = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow   = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = CAN_FIFO0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  // transmit */
  TxMessage.StdId = 0x123;
  TxMessage.ExtId = 0x00;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 4;
  TxMessage.Data[0] = 0x02;
  TxMessage.Data[1] = 0x11;
  TxMessage.Data[2] = 0x11;
  TxMessage.Data[3] = 0x11;
  while(1)
    volatile uint32_t i;
    uint8_t TransmitMailbox = 0;
   // sprintf(TxMessage.Data, "Imran\n");
    TransmitMailbox = CAN_Transmit(CAN1, &TxMessage);
    i = 0;
    while((CAN_TransmitStatus(CAN1, TransmitMailbox) != CANTXOK) && (i
!= 0xFFFFFF)) // Wait on Transmit
      i++;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line
number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and
line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file,
line) */
  /* Infinite loop */
  while (1)
#endif
hello i was thinking stm32f4 has built in can transciever kindly guide
me how can i work with it do i need to connect externally and do i have
to write some code for it.i am new to can so i do not know much about
it.
Maybe try to do the GPIO_PinAFConfig after your GPIO_Init. I slightly
remember a case, where the implementation of GPIO_Init had reset the
dedicated AF registers. But I am not sure, if it applies to the stm32f4.
Just give it a try, I'd say.
And on the CAN TX pin, you should be able to see some flickering, just
not what you would expect on the actual CAN bus.
Well, at least until your CAN controller goes into Bus Off mode.
Without CAN Tranceiver you see this observation only, if you ensure,
that the CAN RX Pin is in rezessive State (High). In other case the CAN
controller do not switch in the buson state.
hello! thank you for your responses
i connected transciever and i see some wave also on oscilloscope. but
the problem is i am seeing this wave on all the pins of transciever and
i am also seeing the same wave at the transmit point of db9 module. am i
doing something wrong?? the program which i have written is this okay or
does it have some kind of mistake???  on my board db9 module is only
connected with pin 0 and pin 1 thats why i am using in my code pin 0 and
pin 1. and also kindly tell me in this case TX will be CAN_H and RX will
be CAN_L??? as i am transmitting the data.
i will be waiting for your kind response
CAN RX -> RXD
CAN TX -> TXD
CAN-H and CAN-L is your CAN bus
Please check the datasheet and manual of the transceiver. Typical there
are many pictures. ;-)
Check, that you have a bus termination (resistor).
Without details nobody can say, if 'some wave' is a CAN message.
Do you use a CAN analyser? Send a message with it and you can see a
correct CAN message wave.
Please check the hint of Lars.
