CubeMX Konfiguration wird nicht in SW4STM32 übernommen
Gast #5581931
ich versuche gerade meinen stm32f302r8 zum laufen zu bringen. Ich
verwende CubeMX für die Pin Konfiguration und die IDE SW4STM32. Wenn ich
die pins versuche zu konfigurieren, wird eclipse normal geöffnet aber
die Konfiguration nicht übernommen. Das erkenne ich daran, dass in der
main.h sonst per #define die Pins definiert wurden die ich konfiguriert
habe. Im Anhang meine ioc Datei.
Gast #5581955
Ja, davon gehe ich aus weil die main.h Datei nach dem generieren wieder
erstellt wird, allerdings leer:
Die main.h sieht so aus:
  * @file           : main.h
  * @brief          : Header for main.c file.
  *                   This file contains the common defines of the
application.
  ** This notice applies to any and all portions of this file
  * that are not between comment pairs USER CODE BEGIN and
  * USER CODE END. Other portions of this file, whether
  * inserted by the user or by software development tools
  * are owned by their respective copyright owners.
  * COPYRIGHT(c) 2018 STMicroelectronics
  * Redistribution and use in source and binary forms, with or without
modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright
notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above
copyright notice,
  *      this list of conditions and the following disclaimer in the
documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its
contributors
  *      may be used to endorse or promote products derived from this
software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
"AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS
BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Define to prevent recursive inclusion
#ifndef _MAIN_H_
#define _MAIN_H_
/* Includes
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private define
/* ########################## Assert Selection
  * @brief Uncomment the line below to expanse the "assert_param" macro
in the
  *        HAL drivers code
/* #define USE_FULL_ASSERT    1U */
/* USER CODE BEGIN Private defines */
/* USER CODE END Private defines */
#ifdef __cplusplus
 extern "C" {
#endif
void _Error_Handler(char *, int);
#define Error_Handler() _Error_Handler(_FILE_, _LINE_)
#ifdef __cplusplus
#endif
#endif /* _MAIN_H_ */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF
FILE****/
ich vermisse daher die #define befehle für die konfigurierten Pins.
Gast #5582098
Ok das wusste ich nicht, danke für die Info. Das mit dem #define hab ich
überprüft indem ich einen GPIO gelabelt habe und siehe da, es
funktioniert. Allerdings kann ich mittlerweile nicht mehr compilieren.
Ich bekomme einfach nur ein rotes x ohne Fehlermeldung angezeigt. Neu
starten und ein und ausstöpseln nicht schonmal nicht. Übrigens hab ich
die Fehlermeldung auch wenn der stm32 nicht angeschlossen ist. Ne Ahnung
was das sein könnte ?
#5582203
Wenn du es zum Laufen bekommen hast, könntest du mal versuchen, in Cube
etwas am Setup zu verändern. Dabei drauf achten, dass dein Code immer
zwischen den User code begin und user code end packst, sonst löscht cube
deinen Code nämlich.
Was dann nämlich nach der Änderung interessant wäre, ob die ganzen inits
noch da sind.
Ich hatte das Problem, dass ich ein Projekt mit Display fürs f746disco
erstellt hab. Dann wollt ich im Nachhinein noch nen ADC mit im Boot
haben. Also in Cube den ADC dazu geklickt in SW4STM32 aktualisiert, und
plötzlich waren alle Inits rot ausser den neu zugekommenen vom ADC
Gast #5582233
Mittlerweile taucht ein neuer Fehler beim compilieren auf:
Polling target STM32F302R8Tx.cpu failed, trying to reexamine.
Keine Ahnung was mit meinem PC bzw. dem STM32 abgeht, hab eig nur
mehrmals CUbeMX und SW4STM32 neu installiert und mehrere Workspaces und
Projekte ausprobiert. Hab in den Projekten bzw. in der main keine Zeile
code stehen. Ich kompiliere nur direkt nachdem ich auf "generate source
code based on user settings" ausgeführt habe. Das SW4STM32 öffnet sich
dann ja automatisch.
