wer kann codesys programmieren
Gast #5642359
Guten Tag,
ich habe eine Frage, wer kann hier Codesys programmieren?
Ich habe hier ein Projekt in Codesys auf einer SPS und  verstehe nicht
warum eine Funktion immer zweimal Daten in mein CANOPEN Netz schickt.
 es handelst sich um folgenden Code.
IF SDOWrite.CONFIRM THEN
  // SDO Write successful.
  xEnable := FALSE;
ELSIF SDOWrite.ERROR <> CiA405.CANOPEN_KERNEL_ERROR.CANOPEN_KERNEL_NO_ERROR THEN
  // Error occured
  IF SDOWrite.ERROR = CIA405.CANOPEN_KERNEL_ERROR.CANOPEN_KERNEL_OTHER_ERROR THEN
    //output error info contains abort code in little endian format
    MEMUtils.MemCpy(pbyDest := ADR(dwAbortCode), pbySrc := ADR(SDOWrite.ERRORINFO), dwSize := SIZEOF(dwAbortCode));
    MEMUtils.SwapLocalToIntel(pAddress := ADR(dwAbortCode), iSize := TO_INT(SIZEOF(dwAbortCode))); //function only swaps on big endian systems
  END_IF
  xEnable := FALSE;
END_IF
SDOWrite(  Enable     := xEnable,
       Network    := CANbus.NetId + 1, //CODESYS NetId starts by 0 (the number entered into the CANbus configurator); CiA405 NETWORK by 1; That is the reason why we have to increment it here.
           Timeout    := 0, //Timeout for SDO read in ms. Here: 0 ==> no timeout
           Device     := CANopenRemoteDevice.NodeID, // NodeID of destination device
           Channel    := 0, //SDO channel which should be used. 0 means auto channeling ==> the next free channel will be used. It depends on the slave which settings are working here but 0 and channel 1 is always working.
           Index      := 16#3000, //object index which should be written ==> 16#3000 = simple string object
           SubIndex   := 0, //object sub index which should be written
       MODE      := CIA405.SDO_MODE.AUTO, //Use SDO mode AUTO ==> Mode will be selected automatically. Use SDO_MODE.BLOCK for forcing Block Transfer.
           Data       := ADR(aData), // Pointer to data buffer where result should be written to.
23
           DataLength := TO_UDINT(Stu.StrLenA(ADR(aData[0]))) //Length of data
24
xEnable wird nur einmal auf True gesetzt.
Was übersehe ich???
Danke
lG
vicara schrieb:
> xEnable wird nur einmal auf True ..
..in dem Quellcode gesetzt, den du nicht gepostet hast.
Wenn xEnable an einer Stelle im Programm gesetzt wird bedeutet nicht
zwangsweise, dass es nur einmal gesetzt wird. SPS arbeitet zyklisch, die
Variable wird in jedem Zyklus gesetzt, in dem die Zuweisung abgearbeitet
wird. So wie ich das sehe, wird xEnable an zwei Stellen auf FALSE
gesetzt: im IF und im ELSIF Block.
Mach dir ein Zeitdiagramm mit allen beteiligten Signalen Ablauf. Damit
sollte ersichtlich sein, wann und für wie lange xEnable auf TRUE gesetzt
wird und wann die beiden geposteten Bedingungen zum Zurücksetzen von
xEnable erfüllt sind
SDOWrite.CONFIRM
und
Wenn in der Zeitspanne in der xEnable auf TRUE gesetzt wird eine der
Bedingungen auch nur für einen SPS Zyklus erfüllt ist, dann geht xEnable
kurz auf FALSE. Der SDOWrite erkennt mehrere Triggerflanken auf Enable
und sendet die Daten mehrfach.
Eigentlich wäre das eine Frage für sps-forum.de
