Wieso Wert nicht gleich auf 0 setzen?
Gast #5681291
Es handelt sich um einen At90CAN128.
Hier der Code.
ISR(CANIT_vect)
  uint8_t canpage;
  uint8_t mob;
  if ((CANHPMOB & 0xF0) != 0xF0)
    // save MOb page register
    canpage = CANPAGE;
    // select MOb page with the highest priority
    CANPAGE = CANHPMOB & 0xF0;
    mob = (CANHPMOB >> 4);
    // a interrupt is only generated if a message was transmitted or received
    if (CANSTMOB & (1 << TXOK))
      // clear MOb
      CANSTMOB &= 0;
      CANCDMOB = 0;
      can_t *buf = CanBufferGetDequeuePtr(&CanTxBufferInfo);
24
25
      // check if there are any another messages waiting
26
      if (buf != NULL)
27
28
        _CanCopyMessageToMob( buf );
29
        CanBufferDequeue(&CanTxBufferInfo);
30
31
        // enable transmission
32
        CANCDMOB |= (1<<CONMOB0);
33
34
      else {
35
        // buffer underflow => no more messages to send
36
        _DisableMobInterrupt(mob);
37
        _transmission_in_progress = 0;
38
39
40
    else {
41
      // a message was received successfully
42
      can_t *buf = CanBufferGetEnqueuePtr(&CanRxBufferInfo);
43
44
      if (buf != NULL)
45
46
        // read message
47
        _CanCopyMobToMessage( buf );
48
49
        // push it to the list
50
        CanBufferEnqueue(&CanRxBufferInfo);
51
52
      else {
53
        // buffer overflow => reject message
54
        // FIXME inform the user
55
56
57
      // clear flags
58
      CANSTMOB &= 0;
59
      CANCDMOB = (1 << CONMOB1) | (CANCDMOB & (1 << IDE));
60
61
62
    // restore MOb page register
63
    CANPAGE = canpage;
64
65
  else
66
67
    // no MOb matches with the interrupt => general interrupt
68
    CANGIT |= 0;
69
70
Gast #5681340
Hallo
Laut Datenblatt des At90CAN128:
To acknowledge a MOb interrupt, the corresponding bits of CANSTMOB
register (RXOK, TXOK,...) must be cleared by the software application.
This operation needs a read-modify-write
software routine.
Hansi  H. schrieb:
> CANSTMOB &= 0;
entspricht ja
CANSTMOB = CANSTMOB & 0;
Das Register wird hier zuerst gelesen (read), danach mit & 0 auf 0
gesetzt (modify) und abschließend wieder geschrieben (write).
Gast #5681352
Datenblatt schrieb im Beitrag #568134
> Hansi  H. schrieb:
> CANSTMOB &= 0;
> entspricht ja
Das macht natürlich Sinn. Danke für die Erklärung.
Gast #5681385
Walter schrieb:
> Hansi  H. schrieb:
> CANGIT |= 0;
> Register lesen und unverändert zurückschreiben ist mir bisher auch noch
> nicht untergekommen. Wenn das denn sein muss würde ich zumindest
> CANGIT = CANGIT
> schreiben
Zumal ist das wahrscheinlich noch schneller.
Gast #5681395
Jim M. schrieb:
> Falls das wirklich so gedacht war (Zusätzlicher Lesezugriff auf das
> Register) dann muss da mindestens ein aussagekräftiger Kommentar sein.
Bei uC, besonders bei serieller IO ist es üblich, das Register gelesen
und beschrieben werden müssen.
Niemand würde, ohne das DB zu lesen, solch Registerzugriffe in der
Reihenfolge vertauschen oder "optimieren".
Ein Kommentar? Didaktisch OK. Je nach skills der Zielgruppe. Am Ende
will man aber weder das DB im Code haben, noch bei jeder RMW-operation
dabeischreiben, dass es eine sein soll.
#5681412
Walter schrieb:
> Hansi  H. schrieb:
>> CANGIT |= 0;
> noch nicht untergekommen.
Der Grund dürfte der gleiche sein wie im Beispiel weiter oben: das Lesen
des Registers hat einen hardwareseitigen Effekt, der benötigt wird.
>> CANGIT = CANGIT schreiben
Der Compiler wird die Veroderung mit 0 wegoptimieren.
