LED-Blink VHDL
Gast #5711921
Hallo!
Ich habe ein Problem: Ich versuche 4 LEDs kurz blinken zu lassen. Als
erstes LED 1-2 und anschließend LED 3-4. Das findet dann auf dem
DE0-Nano Board statt. Leider bekomme ich die Warnung:
Warning (332060): Node: state.S_LED was determined to be a clock but was
found without an associated clock assignment.
Info (13166): Latch LEDG[1]$latch is being clocked by state.S_LED
Außderdem befinden sich noch Latches im Code:
Warning (335093): TimeQuest Timing Analyzer is analyzing 37
combinational loops as latches. For more details, run the Check Timing
command in the TimeQuest Timing Analyzer or view the "User-Specified and
Inferred Latches" table in the Analysis & Synthesis report.
Leider verstehe ich die Warnungen nicht recht. Vielleicht kann mir ja
jemand weiterhelfen.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
entity MainComputer is
  port (
    clock : in     STD_LOGIC;
    reset : in     STD_LOGIC;
    SW   : in     STD_LOGIC_VECTOR(0 to 3);
    GP_IO : inout   STD_LOGIC_VECTOR(0 to 3);
    KEY   : in     STD_LOGIC;
    LEDG   : out   STD_LOGIC_VECTOR(0 to 3)
end MainComputer;
architecture rtl of MainComputer is
--internal signal declaration
type state_t is (S_IDLE, S_COUNT, S_COUNT2, S_LED, S_LED2);
  signal count,count_nxt : unsigned(29 downto 0);
  signal state, state_nxt: state_t;
begin
23
24
  process(clock, reset)
25
  begin
26
    -- asynchronous reset
27
    if reset   = '1' then
28
      count         <= (others => '0');
29
      state         <= S_IDLE;
30
    elsif rising_edge(clock) then
31
      count         <= count_nxt;
32
      state         <= state_nxt;
33
34
    end if;
35
  end process;
36
37
--logic connections between internal signals
38
  process (clock,state,key,count)
39
  begin
40
  case state is
41
42
  when S_IDLE =>
43
  if key = '1' then
44
  state_nxt <= S_COUNT;
45
  end if;
46
47
  when S_COUNT =>
48
  count_nxt <= count + to_unsigned(1, count'length);
49
  if count = to_unsigned(100000000, count'length) then
50
  count_nxt <= (others => '0');
51
  state_nxt <= S_LED;
52
  end if;
53
54
  when S_LED =>
55
  LEDG <= "1100";
56
  state_NXT <= S_COUNT2;
57
58
59
  when S_COUNT2 =>
60
61
62
63
  state_nxt <= S_LED2;
64
  end if;
65
66
  when S_LED2 =>
67
  LEDG <= "0011";
68
  state_nxt <= S_IDLE;
69
70
71
72
73
  end case;
74
  end process;
75
end rtl;
Vielen Dank im voraus.
Gast #5712107
die kannst du vermeiden, indem du im zweiten Prozess in jedem
möglichen Zustand jedem benutzten Signal eine Zuweisung gibst.
Z.B. in S_IDLE erfolgt keine Zuweisung an LEDG und count_nxt, also muss
sich in diesem Fall der bisherige Wert von LEDG und count_nxt gemerkt
werden (in einem LAtch).
Ggf. braucht deine case-Struktur dann auch noch ein when others. Und ein
Signal LEDG_nxt.
Moderator (Firma: Titel) Persönliche Seite #5714535
Du müsstest eigentlich auch für die LEDs mit einem LEDG_nxt Signal
arbeiten und wie bei dem Zähler im getakteten Prozess die Zuweisung an
LEDG machen.
Latches im Design sind besonders dann so unkalkulierbar, wenn davor
irgendeine Kombinatorik sitzt, die wie z.B. die Weiterschaltlogik einer
FAM oder eines Zählers "Glichtes" erzeugen kann. Dann speichern die
Latches nämlich beliebige Werte (es kann auch sein, dass der Glitch so
kurz ist, dass nur ein Teil der Latches den mitbekommt und falsche Werte
speichert) und daraus resultiert dann meist beliebiges fehlerhaftes
Verhalten.
> Vielleicht kann mir ja jemand weiterhelfen.
Das Thema "Off by One" solltest du auch mal googeln: dein Zähler braucht
real 100000001 Takte. Gut, das ist hier jetzt nicht so arg, aber wenn du
mal nur auf 10 zählen willst, dann hast du 10% Fehler.
Achim S. schrieb:
> die kannst du vermeiden, indem du im zweiten Prozess in jedem_ möglichen
> Zustand _jedem benutzten Signal eine Zuweisung gibst.
Oder indem du mit der Ein-Prozess-Schreibweise arbeitest. Dann passiert
sowas garantiert nicht:
http://www.lothar-miller.de/s9y/archives/43-Ein-oder-Zwei-Prozess-Schreibweise-fuer-FSM.html
Und das mit der möglicherweise auftretenden Latency bekommt man mit ein
wenig Brainstorming dann recht schnell kapiert.
Gast #5725638
> LEDG machen.
Das ist die zu bevorzugende Variante in FPGAs aus den genannten Gründen.
Es geht auch etwas einfacher, wenn man vor dem case Statement dem Signal
LEDG einen default Wert zuweist. Innerhalb eines Prozesses "gewinnt" die
letzte Zuweisung an ein Signal.
process (state,key,count)
  begin
  -- Default Wert zuweisen
  LEDG <= "0000";
  case state is
Gast #5725649
Das vermeidet zwar die Latches, aber daraus ergibt sich dann eine andere
Funktion als der TO eigentlich möchte. Er will ja tatsächlich für einige
Kombinationen der Eingangssignale den Wert von LEDG speichern - nur
sollte das eben in Flip-Flops und nicht in Latches passieren.
Mit der Defaultzuweisung zu Beginn des Prozesses würde er LEDG eben
nicht speichern sondern auf den Default-Wert setzen.
Gast #5726598
Er hat gesagt kurz :-) Wie so dann etwas speichern...
Ich gebe dir recht, dass der LED Zustand gespeichert werden soll um das
zu bekommen, was die meisten mit so einem LED blinker wollen. Es war
auch mehr zur Ergänzung wie man die Latches mit weniger Schreibarbeit
vermeiden kann.
  • [vhdl]VHDL-Code[/vhdl]
