PIC16F886 resetet sich selbstständig beim ADC auslesen
Gast #5736176
Moin Leute,
leider habe ich ein Problem mit meinem PIC. Dieser resetet sich
automatisch, sobald ich
return ((ADRESH<<8)+ADRESL);
 ausführe. Leider finde ich keine wirkliche Ursache dafür. Kann mir
jemand helfen?
Vielen Dank.
#pragma config FOSC = XT        // Oscillator Selection bits (XT oscillator)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = ON       // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOREN = ON       // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF        // Low-Voltage (Single-Supply)
#pragma config CPD = OFF        // Data EEPROM Memory Code Protection bit
#pragma config WRT = OFF        // Flash Program Memory Write Enable bits
#pragma config CP = OFF         // Flash Program Memory Code Protection bit
#define _XTAL_FREQ 8000000
#include "xc.h"
int result;
void InitPWM(){
    CCP1CON = 0b00001100;
    CCP2CON = 0b00111100;
    PSTRCON = 0b00000100;
    CCPR1L = 40;
    CCPR1H = 0x00;
24
void InitTMR2(){
25
26
    T2CON=0b01111100;
27
    PR2=100;            //100 us
28
    TMR2=0;
29
    TMR2IF = 0;
30
    TMR2ON = 1;
31
32
33
void InitADC()
34
35
  ADCON0 = 0x11000000;
36
  ADCON1 = 0b10000000;
37
  ADCON0bits.ADON = 1;
38
  __delay_ms(10);
39
40
41
42
43
int ADC_Read(unsigned char channel)
44
45
  __delay_ms(2);
46
  GO_nDONE = 1;
47
  while(GO_nDONE);
48
49
50
51
int main(void) {
52
53
    OSCCON = 0x66; //Interner Oszi
54
55
    int dc = 0;
56
    int a = 0;
57
58
    TRISA = PORTA = TRISB = PORTB = TRISC = PORTB =0x00;
59
    ANSEL = 0x01;
60
61
    TRISBbits.TRISB1=0;
62
    PORTBbits.RB1=0;
63
64
    TRISAbits.TRISA0=1;
65
    PORTAbits.RA0=1;
66
67
    TRISCbits.TRISC2=0;
68
    PORTCbits.RC2=0;
69
    TRISCbits.TRISC3=0;
70
    PORTCbits.RC3=0;
71
    TRISCbits.TRISC4=0;
72
    PORTCbits.RC4=0;
73
74
    TRISAbits.TRISA1=0;
75
    PORTAbits.RA1=0;
76
    TRISAbits.TRISA2=0;
77
    PORTAbits.RA2=0;
78
    TRISAbits.TRISA5=0;
79
    PORTAbits.RA5=0;
80
81
    INTCON = 0;
82
    PIE1   = 0;
83
    PIE2   = 0;
84
85
    InitTMR2();
86
    InitPWM();
87
    InitADC();
88
89
    while(1){
90
91
        PORTCbits.RC4 = 1;
92
        PORTAbits.RA2 = 1;
93
94
        result = ADC_Read(0); //Analog Channel 0
95
96
        for (dc = 0; dc < 17; dc++)
97
98
            CCPR1L = dc;
99
            CCPR2L = 17-dc;
100
            __delay_ms(100);
101
102
103
        for (dc = 16; dc > 0; dc--)
104
105
            CCPR1L = dc;
106
            CCPR2L = 17-dc;
107
            __delay_ms(100);
108
109
110
#5736224
> ausführe.
Das scheint mir eh irgendwie falsch. Was soll das denn tun?
Hast du schon mal return ADRES; getestet? Könnte funktionieren.
Woher weißt du, dass es genau an dieser Zeile liegt? Debugger?
(ADRESH<<8 gibt vermutlich immer 0, warum das einen Reset auslösen
solle, weiß ich allerdings auch nicht)
Gast #5736315
Solche Konstrukte würde ich lieber sein lassen. Der Compiler muss für
den return Wert vor dem Interrupt Speicher reservieren. Ob es das macht?
global Irgend_nTyp InterrupReturnValue;
void InterruptRoutine(Irgend_nTyp Irgend_nVarname) {
   InterrupReturnValue = RegisterXY
Funzt bei mir zuverlässig.
Gast #5736838
Moin,
ich bin mir nicht sicher, ob es direkt an der Zeile liegt. Im Debugger
lande ich danach immer direkt wieder an den Anfang der Main.
Leider scheint der ADC aktuell gar nicht zu funktionieren. Ich bekomme
immer als return 0x0000. Auch wenn ich
result = ((ADRESH<<8)+ADRESL); //Returns Result
 mache.
Ist meine ADC Konfiguration falsch? Möchte VDD als Ref verwenden und A0
als Input.
Gast #5736839
Volker S. schrieb:
>> automatisch, sobald ichreturn ((ADRESH<<8)+ADRESL);> ausführe.
Return ADRES funktioniert nicht. Kennt der Compiler nicht.
#5736961
HyperMario schrieb:
> Weil es kein ADRES Register gibt.
Oft hat aber jemand dem Compiler gesagt, was es bedeutet.
#define ADRES *(uint_16t*)(&ADRESL) oder so ähnlich
Das geht beim 16F886 leider nicht, weil die Register nicht
dementsprechend liegen. Bei den neueren funktioniert es vermutlich
immer.
@ThinkPIC
setz doch mal einen Breakpoint auf den Resetvector, bzw. den
Interruptvector (im Program Memory View) und schau, ob er vielleicht
dahin springt.
Oder setz den Breakpoint auf das return, und geh dann im Single Step
weiter.
(single step auch im Program Memory View)
Wenn das (ADRESH<<8) später immer 0 liefert, dann probier
((uint16_t)ADRESH)<<8)
#5737075
Peter D. schrieb:
> ThinkPic schrieb:
>> GO_nDONE = 1;
>>   while(GO_nDONE);
> Vermutlich wird GO_nDONE niemals auf 0 gesetzt, d.h. Endlosschleife und
> irgendwann schlägt der Watchdogreset zu.
Würde ich auch schätzen.
>   __delay_ms(2);
>   GO_nDONE = 1;
>   while(GO_nDONE);
Finde ich sowieso etwas speziell. Normalerweise startet man doch eine
Messung über ein ADC Flag und wartet bis der ADC ein Done Flag setzt.
Oder das ganze ist im Freilauf. Aber selber irgendwelche Flags
erfinden...
#5737076
> disabled)
Wenn der ADC richtig konfiguriert wurde, dann geht GO_nDONE nach
erfolgter Wandlung wieder auf 0
Weiß zwar nicht, warum eine falsche Konfiguration einen RESET auslösen
sollte, aber mach mal trotzdem das x zu einem b ;-)
Patrick B. schrieb:
> Aber selber irgendwelche Flags erfinden...
Wie kommst du jetzt darauf? Noch nie PICs programmiert?
Ich bin weiterhin für Debuggen!
