PIC24 UART Rx Interrupt
OP #5775954
Hallo Zusammen,
ich arbeite mit einem PIC24FJ256GA106 Chip. Ich versuche ein char bzw.
einen String über UART zu empfangen. Da ich mich noch nicht so gut
auskenne, wollte ich dies mit dem MCC Configurator versuchen. So erhielt
ich folgenden Code fürs Header:
#ifndef UART1_H
#define UART1_H
 Section: Included Files
#include <xc.h>
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
#include <stdio.h>
#define PPS_DISABLE_IOLOCK {  __builtin_write_OSCCONL( OSCCON & 0xbf ); }
#define PPS_ENABLE_IOLOCK { __builtin_write_OSCCONL( OSCCON | 0x40 ); }
#ifdef __cplusplus  // Provide C++ Compatibility
    extern "C" {
#endif
24
  Section: Data Types
25
26
27
/** UART1 Driver Hardware Flags
28
29
  @Summary
30
    Specifies the status of the hardware receive or transmit
31
32
  @Description
33
    This type specifies the status of the hardware receive or transmit.
34
    More than one of these values may be OR'd together to create a complete
35
    status value.  To test a value of this type, the bit of interest must be
36
    AND'ed with value and checked to see if the result is non-zero.
37
38
39
typedef enum
40
41
    /* Indicates that Receive buffer has data, at least one more character can be read */
42
    UART1_RX_DATA_AVAILABLE
43
        /*DOM-IGNORE-BEGIN*/  = (1 << 0) /*DOM-IGNORE-END*/,
44
45
    /* Indicates that Receive buffer has overflowed */
46
    UART1_RX_OVERRUN_ERROR
47
        /*DOM-IGNORE-BEGIN*/  = (1 << 1) /*DOM-IGNORE-END*/,
48
49
    /* Indicates that Framing error has been detected for the current character */
50
    UART1_FRAMING_ERROR
51
        /*DOM-IGNORE-BEGIN*/  = (1 << 2) /*DOM-IGNORE-END*/,
52
53
    /* Indicates that Parity error has been detected for the current character */
54
    UART1_PARITY_ERROR
55
        /*DOM-IGNORE-BEGIN*/  = (1 << 3) /*DOM-IGNORE-END*/,
56
57
    /* Indicates that Receiver is Idle */
58
    UART1_RECEIVER_IDLE
59
        /*DOM-IGNORE-BEGIN*/  = (1 << 4) /*DOM-IGNORE-END*/,
60
61
    /* Indicates that the last transmission has completed */
62
    UART1_TX_COMPLETE
63
        /*DOM-IGNORE-BEGIN*/  = (1 << 8) /*DOM-IGNORE-END*/,
64
65
    /* Indicates that Transmit buffer is full */
66
    UART1_TX_FULL
67
        /*DOM-IGNORE-BEGIN*/  = (1 << 9) /*DOM-IGNORE-END*/
68
69
} UART1_STATUS;
70
71
/** UART1 Driver Transfer Flags
72
73
  @Summary
74
    Specifies the status of the receive or transmit
75
76
  @Description
77
    This type specifies the status of the receive or transmit operation.
78
79
80
81
82
83
typedef enum
84
85
    /* Indicates that the core driver buffer is full */
86
    UART1_TRANSFER_STATUS_RX_FULL
87
88
89
    /* Indicates that at least one byte of Data has been received */
90
    UART1_TRANSFER_STATUS_RX_DATA_PRESENT
91
92
93
    /* Indicates that the core driver receiver buffer is empty */
94
    UART1_TRANSFER_STATUS_RX_EMPTY
95
96
97
    /* Indicates that the core driver transmitter buffer is full */
98
    UART1_TRANSFER_STATUS_TX_FULL
99
100
101
    /* Indicates that the core driver transmitter buffer is empty */
102
    UART1_TRANSFER_STATUS_TX_EMPTY
103
104
105
} UART1_TRANSFER_STATUS;
106
107
108
  Section: UART1 Driver Routines
109
110
111
112
  @Summary
113
    Initializes the UART instance : 1
114
115
  @Description
116
    This routine initializes the UART driver instance for : 1
117
    index.
118
    This routine must be called before any other UART routine is called.
119
120
  @Preconditions
121
    None.
122
123
  @Returns
124
    None.
125
126
  @Param
127
    None.
128
129
  @Comment
130
131
132
  @Example
133
    <code>
134
        const uint8_t writeBuffer[35] = "1234567890ABCDEFGHIJKLMNOP\r\n" ;
135
        unsigned int numBytes = 0;
136
        int  writebufferLen = strlen((char *)writeBuffer);
137
        UART1_Initialize();
138
139
        while(numBytes < writebufferLen)
140
141
            int bytesToWrite = UART1_TransmitBufferSizeGet();
142
            numBytes += UART1_WriteBuffer ( writeBuffer+numBytes, bytesToWrite)  ;
143
144
    </code>
145
146
147
148
void UART1_Initialize(void);
149
150
151
  @Summary
152
    Allows setting of a the enable bit for the UART1 mode
153
154
  @Description
155
    This routine is used to enable the UART1
156
157
  @Preconditions
158
    UART1_Initialize() function should have been
159
    called before calling this function.
160
161
  @Returns
162
    None
163
164
  @Param
165
    None
166
167
  @Example
168
    Refer to UART1_Initialize(); for an example
169
170
171
void UART1_Enable(void);
172
173
174
  @Summary
175
    Allows setting of a the disable bit for the UART1 mode
176
177
  @Description
178
    This routine is used to disable the UART1
179
180
  @Preconditions
181
182
183
184
  @Returns
185
    None
186
187
  @Param
188
    None
189
190
  @Example
191
192
193
194
void UART1_Disable(void);
195
196
197
  @Summary
198
    Read a byte of data from the UART1
199
200
  @Description
201
    This routine reads a byte of data from the UART1.
202
203
  @Preconditions
204
    UART1_Initialize function should have been called
205
    before calling this function. The transfer status should be checked to see
206
    if the receiver is not empty before calling this function.
207
208
  @Param
209
    None.
210
211
  @Returns
212
    A data byte received by the driver.
213
214
  @Example
215
    <code>
216
    uint8_t myBuffer[MY_BUFFER_SIZE];
217
218
219
    // Pre-initialize myBuffer with MY_BUFFER_SIZE bytes of valid data.
220
221
    do
222
223
        if( UART1_TRANSFER_STATUS_RX_DATA_PRESENT & UART1_TransferStatusGet() )
224
225
            myBuffer[numBytes++] = UART1_Read();
226
227
228
        // Do something else...
229
230
    } while( numBytes < MY_BUFFER_SIZE);
231
    </code>
232
233
234
uint8_t UART1_Read( void);
235
236
237
  @Summary
238
    Returns the number of bytes read by the UART1 peripheral
239
240
  @Description
241
    This routine returns the number of bytes read by the Peripheral and fills the
242
    application read buffer with the read data.
243
244
  @Preconditions
245
246
247
248
  @Param
249
    buffer       - Buffer into which the data read from the UART1
250
251
  @Param
252
    numbytes     - Total number of bytes that need to be read from the UART1
253
                   (must be equal to or less than the size of the buffer)
254
255
  @Returns
256
    Number of bytes actually copied into the caller's buffer or -1 if there
257
    is an error.
258
259
  @Example
260
    <code>
261
    uint8_t readBuffer[MY_BUFFER_SIZE];
262
    unsigned int status, numBytes = 0;
263
264
    // Pre-initialize readBuffer with MY_BUFFER_SIZE bytes of valid data.
265
266
    while (numBytes < MY_BUFFER_SIZE);
267
268
        status = UART1_TransferStatusGet();
269
        if (status & UART1_TRANSFER_STATUS_RX_FULL) {
270
            numBytes += UART1_ReadBuffer(readBuffer + numBytes, MY_BUFFER_SIZE - numBytes);
271
272
273
274
275
    </code>
276
277
278
unsigned int UART1_ReadBuffer( uint8_t *buffer ,  const unsigned int numbytes);
279
280
281
  @Summary
282
    Writes a byte of data to the UART1
283
284
  @Description
285
    This routine writes a byte of data to the UART1.
286
287
  @Preconditions
288
289
    before calling this function. The transfer status should be checked to see if
290
    transmitter is not full before calling this function.
291
292
  @Param
293
    byte         - Data byte to write to the UART1
294
295
  @Returns
296
    None.
297
298
  @Example
299
    <code>
300
301
302
303
304
305
306
307
        if (!(UART1_TRANSFER_STATUS_TX_FULL & UART1_TransferStatusGet())) {
308
            UART1_Write(myBuffer[numBytes++]);
309
310
311
312
313
    </code>
314
315
316
void UART1_Write( const uint8_t byte);
317
318
319
  @Summary
320
    Returns the number of bytes written into the internal buffer
321
322
  @Description
323
    This API transfers the data from application buffer to internal buffer and
324
    returns the number of bytes added in that queue
325
326
  @Preconditions
327
328
329
330
  @Example
331
    <code>
332
333
334
    UART1_TRANSFER_STATUS status;
335
336
337
338
339
340
341
        if (status & UART1_TRANSFER_STATUS_TX_EMPTY) {
342
            numBytes += UART1_WriteBuffer(myBuffer + numBytes, MY_BUFFER_SIZE - numBytes);
343
344
345
346
347
    </code>
348
349
350
unsigned int UART1_WriteBuffer( const uint8_t *buffer , const unsigned int numbytes );
351
352
353
  @Summary
354
    Returns the transmitter and receiver transfer status
355
356
  @Description
357
    This returns the transmitter and receiver transfer status.The returned status
358
    may contain a value with more than one of the bits
359
    specified in the UART1_TRANSFER_STATUS enumeration set.
360
    The caller should perform an "AND" with the bit of interest and verify if the
361
    result is non-zero (as shown in the example) to verify the desired status
362
    bit.
363
364
  @Preconditions
365
366
367
368
  @Param
369
    None.
370
371
  @Returns
372
    A UART1_TRANSFER_STATUS value describing the current status
373
    of the transfer.
374
375
  @Example
376
    Refer to UART1_ReadBuffer and UART1_WriteBuffer for example
377
378
379
380
UART1_TRANSFER_STATUS UART1_TransferStatusGet (void );
381
382
383
  @Summary
384
    Returns the character in the read sequence at the offset provided, without
385
    extracting it
386
387
  @Description
388
    This routine returns the character in the read sequence at the offset provided,
389
    without extracting it
390
391
  @Param
392
    None.
393
394
  @Example
395
    <code>
396
    uint8_t readBuffer[5];
397
    unsigned int data, numBytes = 0;
398
    unsigned int readbufferLen = sizeof (readBuffer);
399
    UART1_Initialize();
400
401
    while (numBytes < readbufferLen) {
402
        //Check for data at a particular place in the buffer
403
        data = UART1_Peek(3);
404
        if (data == 5) {
405
            //discard all other data if byte that is wanted is received.
406
            //continue other operation
407
            numBytes += UART1_ReadBuffer(readBuffer + numBytes, readbufferLen);
408
        } else {
409
            break;
410
411
412
    </code>
413
414
415
416
uint8_t UART1_Peek(uint16_t offset);
417
418
419
  @Summary
420
    Validates the offset input and get the character in the read sequence at the
421
    offset provided, without extracting it
422
423
  @Description
424
    This routine validates the offset input and get the character in the read
425
    sequence at the offset provided, without extracting it.
426
427
  @Param
428
    dataByte     - Data byte to be read from UART1 RX buffer based on offset position.
429
    offset       - UART1 RX buffer peek position. Offset input range is should be
430
                   0 to (UART1_CONFIG_RX_BYTEQ_LENGTH - 1).
431
432
  @Return
433
    false        - If the UART1 RX buffer is empty or dataByte is NULL or UART1 RX
434
                   buffer is empty.
435
    true         - Valid offset input position.
436
437
  @Example
438
    <code>
439
    uint8_t readBuffer[MY_BUFFER_SIZE], data;
440
441
    UART1_Initialize();
442
443
444
445
    while (numBytes < MY_BUFFER_SIZE) {
446
447
        if (UART1_PeekSafe(&data, 3)) {
448
            if (data == 5) {
449
450
451
452
            } else {
453
                break;
454
455
456
457
    </code>
458
459
460
461
bool UART1_PeekSafe(uint8_t *dataByte, uint16_t offset);
462
463
464
  @Summary
465
    Returns the number of bytes remaining in the receive buffer
466
467
  @Description
468
    This routine returns the number of bytes remaining in the receive buffer.
469
470
  @Param
471
    None.
472
473
  @Returns
474
    Remaining size of receive buffer.
475
476
  @Example
477
    <code>
478
479
    unsigned int size, numBytes = 0;
480
    UART1_Initialize();
481
482
483
484
    while (size < MY_BUFFER_SIZE) {
485
        size = UART1_ReceiveBufferSizeGet();
486
487
    numBytes = UART1_ReadBuffer(readBuffer, MY_BUFFER_SIZE);
488
    </code>
489
490
491
492
unsigned int UART1_ReceiveBufferSizeGet(void);
493
494
495
  @Summary
496
    Returns the number of bytes remaining in the transmit buffer.
497
498
  @Description
499
    This routine returns the number of bytes remaining in the transmit buffer.
500
501
 @Param
502
    None.
503
504
 @Returns
505
    Remaining size of transmit buffer.
506
507
 @Example
508
    Refer to UART1_Initialize(); for example.
509
510
511
unsigned int UART1_TransmitBufferSizeGet(void);
512
513
514
  @Summary
515
    Returns the status of the receive buffer
516
517
  @Description
518
    This routine returns if the receive buffer is empty or not.
519
520
  @Param
521
    None.
522
523
  @Returns
524
    True if the receive buffer is empty
525
    False if the receive buffer is not empty
526
527
  @Example
528
    <code>
529
530
    unsigned int numBytes;
531
532
533
534
535
    numBytes = 0;
536
537
538
539
        if (!UART1_ReceiveBufferIsEmpty()) {
540
            numBytes += UART1_ReadBuffer(myBuffer + numBytes, MY_BUFFER_SIZE - numBytes);
541
542
543
544
    </code>
545
546
547
548
bool UART1_ReceiveBufferIsEmpty (void);
549
550
551
  @Summary
552
    Returns the status of the transmit buffer
553
554
  @Description
555
    This routine returns if the transmit buffer is full or not.
556
557
 @Param
558
    None.
559
560
 @Returns
561
    True if the transmit buffer is full
562
    False if the transmit buffer is not full
563
564
 @Example
565
    Refer to UART1_Initialize() for example.
566
567
568
569
bool UART1_TransmitBufferIsFull (void);
570
571
572
  @Summary
573
    Returns the transmitter and receiver status
574
575
  @Description
576
    This returns the transmitter and receiver status. The returned status
577
    contains a 16 bit value.
578
579
580
    bit.
581
582
  @Preconditions
583
584
585
586
  @Param
587
    None.
588
589
  @Returns
590
    16 bit value describing the current status of the transfer.
591
592
  @Example
593
    <code>
594
        while(!(UART1_StatusGet() & UART1_TX_COMPLETE ))
595
596
           // Wait for the tranmission to complete
597
598
    </code>
599
600
601
uint16_t UART1_StatusGet (void );
602
603
604
605
606
607
#endif
608
609
#endif  // UART1_H
Dazu habe ich folgendes C File:
#include "uart1.h"
  Section: Data Type Definitions
/** UART Driver Queue Status
  @Summary
    Defines the object required for the status of the queue.
typedef union
    struct
            uint8_t full:1;
            uint8_t empty:1;
            uint8_t reserved:6;
    }s;
    uint8_t status;
24
UART_BYTEQ_STATUS;
25
26
/** UART Driver Hardware Instance Object
27
28
  @Summary
29
    Defines the object required for the maintenance of the hardware instance.
30
31
32
33
typedef struct
34
35
    /* RX Byte Q */
36
    uint8_t                                      *rxTail ;
37
38
    uint8_t                                      *rxHead ;
39
40
    /* TX Byte Q */
41
    uint8_t                                      *txTail ;
42
43
    uint8_t                                      *txHead ;
44
45
    UART_BYTEQ_STATUS                        rxStatus ;
46
47
    UART_BYTEQ_STATUS                        txStatus ;
48
49
} UART_OBJECT ;
50
51
static volatile UART_OBJECT uart1_obj ;
52
53
/** UART Driver Queue Length
54
55
  @Summary
56
    Defines the length of the Transmit and Receive Buffers
57
58
59
60
#define UART1_CONFIG_TX_BYTEQ_LENGTH 8
61
#define UART1_CONFIG_RX_BYTEQ_LENGTH 8
62
63
64
65
  @Summary
66
    Defines the Transmit and Receive Buffers
67
68
69
70
static uint8_t uart1_txByteQ[UART1_CONFIG_TX_BYTEQ_LENGTH] ;
71
static uint8_t uart1_rxByteQ[UART1_CONFIG_RX_BYTEQ_LENGTH] ;
72
73
74
  Section: Driver Interface
75
76
77
78
79
    PPS_DISABLE_IOLOCK;
80
81
        RPINR18bits.U1RXR = 16; /* Assign UART1 Receive (U1RX) to RP16 pin */
82
        RPOR15bits.RP30R = 3; /* RP30 is tied to default port pin */
83
84
    PPS_ENABLE_IOLOCK;
85
86
    // STSEL 1; IREN disabled; PDSEL 8N; UARTEN enabled; RTSMD disabled; USIDL disabled; WAKE disabled; ABAUD disabled; LPBACK disabled; BRGH enabled; RXINV disabled; UEN TX_RX;
87
    // Data Bits = 8; Parity = None; Stop Bits = 1;
88
    U1MODE = (0x8008 & ~(1<<15));  // disabling UARTEN bit
89
    // UTXISEL0 TX_ONE_CHAR; UTXINV disabled; OERR NO_ERROR_cleared; URXISEL RX_ONE_CHAR; UTXBRK COMPLETED; UTXEN disabled; ADDEN disabled;
90
    U1STA = 0x00;
91
  // BaudRate = 115200; Frequency = 16000000 Hz; BRG 34;
92
    U1BRG = 0x22;
93
94
    IEC0bits.U1RXIE = 1;
95
96
    //Make sure to set LAT bit corresponding to TxPin as high before UART initialization
97
98
    UART1_Enable();  // enabling UARTEN bit
99
100
    uart1_obj.txHead = uart1_txByteQ;
101
    uart1_obj.txTail = uart1_txByteQ;
102
    uart1_obj.rxHead = uart1_rxByteQ;
103
    uart1_obj.rxTail = uart1_rxByteQ;
104
    uart1_obj.rxStatus.s.empty = true;
105
    uart1_obj.txStatus.s.empty = true;
106
    uart1_obj.txStatus.s.full = false;
107
    uart1_obj.rxStatus.s.full = false;
108
109
110
111
    Maintains the driver's transmitter state machine and implements its ISR
112
113
114
void __attribute__ ( ( interrupt, no_auto_psv ) ) _U1TXInterrupt ( void )
115
116
    if((uart1_obj.txHead == uart1_obj.txTail) && (uart1_obj.txStatus.s.full == false))
117
118
        while(U1STAbits.TRMT == 0){}
119
120
121
        IEC0bits.U1TXIE = 0;
122
        return;
123
124
125
    IFS0bits.U1TXIF = 0;
126
127
    while(!(U1STAbits.UTXBF == 1))
128
129
        U1TXREG = *uart1_obj.txHead;
130
131
        uart1_obj.txHead++;
132
133
        if(uart1_obj.txHead == (uart1_txByteQ + UART1_CONFIG_TX_BYTEQ_LENGTH))
134
135
136
137
138
139
140
        if(uart1_obj.txHead == uart1_obj.txTail)
141
142
            break;
143
144
145
146
147
void __attribute__ ( ( interrupt, no_auto_psv ) ) _U1RXInterrupt( void )
148
149
150
    while((U1STAbits.URXDA == 1))
151
152
        *uart1_obj.rxTail = U1RXREG;
153
154
        uart1_obj.rxTail++;
155
156
        if(uart1_obj.rxTail == (uart1_rxByteQ + UART1_CONFIG_RX_BYTEQ_LENGTH))
157
158
159
160
161
        uart1_obj.rxStatus.s.empty = false;
162
163
        if(uart1_obj.rxTail == uart1_obj.rxHead)
164
165
            //Sets the flag RX full
166
            uart1_obj.rxStatus.s.full = true;
167
            break;
168
169
170
171
    IFS0bits.U1RXIF = false;
172
173
174
void __attribute__ ( ( interrupt, no_auto_psv ) ) _U1ErrInterrupt( void )
175
176
    if ((U1STAbits.OERR == 1))
177
178
        U1STAbits.OERR = 0;
179
180
181
    IFS4bits.U1ERIF = false;
182
183
184
185
  Section: UART Driver Client Routines
186
187
188
189
190
    uint8_t data = 0;
191
192
    data = *uart1_obj.rxHead;
193
194
    uart1_obj.rxHead++;
195
196
    if (uart1_obj.rxHead == (uart1_rxByteQ + UART1_CONFIG_RX_BYTEQ_LENGTH))
197
198
199
200
201
    if (uart1_obj.rxHead == uart1_obj.rxTail)
202
203
204
205
206
207
208
    return data;
209
210
211
unsigned int UART1_ReadBuffer( uint8_t *buffer, const unsigned int bufLen)
212
213
    unsigned int numBytesRead = 0 ;
214
    while ( numBytesRead < ( bufLen ))
215
216
        if( uart1_obj.rxStatus.s.empty)
217
218
            break;
219
220
        else
221
222
            buffer[numBytesRead++] = UART1_Read () ;
223
224
225
226
    return numBytesRead ;
227
228
229
230
231
232
233
    *uart1_obj.txTail = byte;
234
235
    uart1_obj.txTail++;
236
237
    if (uart1_obj.txTail == (uart1_txByteQ + UART1_CONFIG_TX_BYTEQ_LENGTH))
238
239
240
241
242
    uart1_obj.txStatus.s.empty = false;
243
244
    if (uart1_obj.txHead == uart1_obj.txTail)
245
246
        uart1_obj.txStatus.s.full = true;
247
248
249
    IEC0bits.U1TXIE = 1 ;
250
251
252
unsigned int UART1_WriteBuffer( const uint8_t *buffer , const unsigned int bufLen )
253
254
    unsigned int numBytesWritten = 0 ;
255
256
    while ( numBytesWritten < ( bufLen ))
257
258
        if((uart1_obj.txStatus.s.full))
259
260
            break;
261
262
        else
263
264
            UART1_Write (buffer[numBytesWritten++] ) ;
265
266
267
268
    return numBytesWritten ;
269
270
271
272
273
    UART1_TRANSFER_STATUS status = 0;
274
275
    /* The TX empty must be checked before the full in order to prevent a race
276
     * condition where a TX transmission could start between these two checks
277
     * resulting in both full and empty set at the same time.
278
279
    if(uart1_obj.txStatus.s.empty)
280
281
        status |= UART1_TRANSFER_STATUS_TX_EMPTY;
282
283
284
    if(uart1_obj.txStatus.s.full)
285
286
        status |= UART1_TRANSFER_STATUS_TX_FULL;
287
288
289
    /* The RX full must be checked before the empty in order to prevent a race
290
     * condition where a RX reception could start between these two checks
291
     * resulting in both empty and full set at the same time.
292
293
    if(uart1_obj.rxStatus.s.full)
294
295
        status |= UART1_TRANSFER_STATUS_RX_FULL;
296
297
298
    if(uart1_obj.rxStatus.s.empty)
299
300
        status |= UART1_TRANSFER_STATUS_RX_EMPTY;
301
302
    else
303
304
        status |= UART1_TRANSFER_STATUS_RX_DATA_PRESENT;
305
306
    return status;
307
308
309
310
    Uart Peek function returns the character in the read sequence with
311
    the provided offset, without extracting it.
312
313
314
315
    if( (uart1_obj.rxHead + offset) >= (uart1_rxByteQ + UART1_CONFIG_RX_BYTEQ_LENGTH))
316
317
      return uart1_rxByteQ[offset - (uart1_rxByteQ + UART1_CONFIG_RX_BYTEQ_LENGTH - uart1_obj.rxHead)];
318
319
    else
320
321
      return *(uart1_obj.rxHead + offset);
322
323
324
325
326
    Uart PeekSafe function validates all the possible conditions and get the character
327
    in the read sequence with the provided offset, without extracting it.
328
329
330
331
    uint16_t index = 0;
332
    bool status = true;
333
334
    if((offset >= UART1_CONFIG_RX_BYTEQ_LENGTH) || (uart1_obj.rxStatus.s.empty) || (!dataByte))
335
336
        status = false;
337
338
    else
339
340
        //Compute the offset buffer overflow range
341
        index = ((uart1_obj.rxHead - uart1_rxByteQ) + offset) % UART1_CONFIG_RX_BYTEQ_LENGTH;
342
343
344
         * Check for offset input value range is valid or invalid. If the range
345
         * is invalid, then status set to false else true.
346
347
        if(uart1_obj.rxHead < uart1_obj.rxTail)
348
349
            if((uart1_obj.rxHead + offset) > (uart1_obj.rxTail - 1))
350
351
                status = false;
352
353
354
        else if(uart1_obj.rxHead > uart1_obj.rxTail)
355
356
            if((uart1_rxByteQ + index) < uart1_obj.rxHead)
357
358
                if( (uart1_rxByteQ + index) >= uart1_obj.rxTail )
359
360
                    status = false;
361
362
363
364
365
        if(status == true)
366
367
            *dataByte = UART1_Peek(offset);
368
369
370
    return status;
371
372
373
374
375
    if(!uart1_obj.rxStatus.s.full)
376
377
378
379
            return(uart1_obj.rxHead - uart1_obj.rxTail);
380
381
        else
382
383
            return(UART1_CONFIG_RX_BYTEQ_LENGTH - (uart1_obj.rxTail - uart1_obj.rxHead));
384
385
386
    return 0;
387
388
389
390
391
    if(!uart1_obj.txStatus.s.full)
392
393
        if(uart1_obj.txHead > uart1_obj.txTail)
394
395
            return(uart1_obj.txHead - uart1_obj.txTail);
396
397
        else
398
399
            return(UART1_CONFIG_TX_BYTEQ_LENGTH - (uart1_obj.txTail - uart1_obj.txHead));
400
401
402
    return 0;
403
404
405
406
407
    return(uart1_obj.rxStatus.s.empty);
408
409
410
bool UART1_TransmitBufferIsFull(void)
411
412
    return(uart1_obj.txStatus.s.full);
413
414
415
uint16_t UART1_StatusGet (void)
416
417
    return U1STA;
418
419
420
421
422
    U1MODEbits.UARTEN = 1;
423
    U1STAbits.UTXEN = 1;
424
425
426
427
428
    U1MODEbits.UARTEN = 0;
429
    U1STAbits.UTXEN = 0;
430
Mein Problem ist, dass ich vom Rx-Interrupt beim Debuggen nichts
empfange, habe ich etwas falsch eingestellt oder ist eine Funktion
falsch aufgebaut?
Schreiben bzw. senden über UART funktioniert.
Hatte jemand schon ein ähnliches Problem?
Gast #5775986
> falsch aufgebaut?
Wie geprüft?
Da kannst Du aber sicher sein ;)
Trotzdem, ohne den Code, den Du geschrieben hast ist die Fehlersuche
nicht sinnvoll. Hast Du denn den RX-Interrupt auch "enabled" und global
freigegeben?
OP #5776473
Hallo Edson,
vielen Dank für deine schnelle Antwort. Geprüft habe ich das "Senden"
mit einem USB zu UART converter und Hterm.
Den UART1 Interrupt habe ich enabled, dies wird doch in der
UART1_Initialize Funktion mit dieser zeile
 enabled?
Wie meinst du Global freigegben, muss ich im main noch eine Funktion
aufrufen?
mein Main sieht momentan so aus:
#include <stdio.h>
#include <xc.h>
#include "mcc_generated_files/system.h"
#include "mcc_generated_files/traps.h"
#include "uart1.h"
#define FCY 16000000Ul
#include "libpic30.h"
UART_OBJECT newObj;
char test;
                         Main application
int main(void)
23
24
25
26
    // initialize the device
27
    SYSTEM_Initialize();
28
29
    TRISEbits.TRISE0 = 0;   //Port = Output
30
31
    while (1)
32
33
        LATEbits.LATE0 = ~LATEbits.LATE0;   //LED Toggeln
34
35
        printf("hallo Welt"); //String ausgeben auf UART1
36
37
        test = newObj.rxTail; //Von Variable einlesen
38
39
        printf(test);          //Eingelesene ausgeben
40
41
        __delay_ms(10);
42
43
44
    return 1;
45
46
47
 End of File
48
Findest du gerade einen Fehler oder habe ich etwas vergessen?
Gruss
MootSeeker
