[Python] Wie ist der Offset relativ zum Dateistart in Sekunden zum ersten Beat?
Gast #5808767
Es geht um
https://github.com/scaperot/the-BPM-detector-python/blob/master/bpm_detection/bpm_detection.py
Wie müßte ich den Code ändern, damit mir die Verschiebung des ersten
Beats ausgegeben wird?
Anders gesagt, wie ist der Offset relativ zum Dateistart in Sekunden zum
ersten Beat?
Im Folgenden der gesamte Code:
import wave, array, math, time, argparse, sys
import numpy, pywt
from scipy import signal
import pdb
import matplotlib.pyplot as plt
def read_wav(filename):
    #open file, get metadata for audio
    try:
        wf = wave.open(filename,'rb')
    except IOError, e:
        print e
        return
    # typ = choose_type( wf.getsampwidth() ) #TODO: implement choose_type
    nsamps = wf.getnframes();
    assert(nsamps > 0);
    fs = wf.getframerate()
    assert(fs > 0)
    # read entire file and make into an array
24
    samps = list(array.array('i',wf.readframes(nsamps)))
25
    #print 'Read', nsamps,'samples from', filename
26
    try:
27
        assert(nsamps == len(samps))
28
    except AssertionError, e:
29
        print  nsamps, "not equal to", len(samps)
30
31
    return samps, fs
32
33
# print an error when no data can be found
34
def no_audio_data():
35
    print "No audio data for sample, skipping..."
36
    return None, None
37
38
# simple peak detection
39
def peak_detect(data):
40
    max_val = numpy.amax(abs(data))
41
    peak_ndx = numpy.where(data==max_val)
42
    if len(peak_ndx[0]) == 0: #if nothing found then the max must be negative
43
        peak_ndx = numpy.where(data==-max_val)
44
    return peak_ndx
45
46
def bpm_detector(data,fs):
47
    cA = []
48
    cD = []
49
    correl = []
50
    cD_sum = []
51
    levels = 4
52
    max_decimation = 2**(levels-1);
53
    min_ndx = 60./ 220 * (fs/max_decimation)
54
    max_ndx = 60./ 40 * (fs/max_decimation)
55
56
    for loop in range(0,levels):
57
        cD = []
58
        # 1) DWT
59
        if loop == 0:
60
            [cA,cD] = pywt.dwt(data,'db4');
61
            cD_minlen = len(cD)/max_decimation+1;
62
            cD_sum = numpy.zeros(cD_minlen);
63
        else:
64
            [cA,cD] = pywt.dwt(cA,'db4');
65
        # 2) Filter
66
        cD = signal.lfilter([0.01],[1 -0.99],cD);
67
68
        # 4) Subtractargs.filename out the mean.
69
70
        # 5) Decimate for reconstruction later.
71
        cD = abs(cD[::(2**(levels-loop-1))]);
72
        cD = cD - numpy.mean(cD);
73
        # 6) Recombine the signal before ACF
74
        #    essentially, each level I concatenate
75
        #    the detail coefs (i.e. the HPF values)
76
        #    to the beginning of the array
77
        cD_sum = cD[0:cD_minlen] + cD_sum;
78
79
    if [b for b in cA if b != 0.0] == []:
80
        return no_audio_data()
81
    # adding in the approximate data as well...
82
    cA = signal.lfilter([0.01],[1 -0.99],cA);
83
    cA = abs(cA);
84
    cA = cA - numpy.mean(cA);
85
    cD_sum = cA[0:cD_minlen] + cD_sum;
86
87
    # ACF
88
    correl = numpy.correlate(cD_sum,cD_sum,'full')
89
90
    midpoint = len(correl) / 2
91
    correl_midpoint_tmp = correl[midpoint:]
92
    peak_ndx = peak_detect(correl_midpoint_tmp[min_ndx:max_ndx]);
93
    if len(peak_ndx) > 1:
94
95
96
    peak_ndx_adjusted = peak_ndx[0]+min_ndx;
97
    bpm = 60./ peak_ndx_adjusted * (fs/max_decimation)
98
    print bpm
99
    return bpm,correl
100
101
102
if __name__ == '__main__':
103
    parser = argparse.ArgumentParser(description='Process .wav file to determine the Beats Per Minute.')
104
    parser.add_argument('--filename', required=True,
105
                   help='.wav file for processing')
106
    parser.add_argument('--window', type=float, default=3,
107
                   help='size of the the window (seconds) that will be scanned to determine the bpm.  Typically less than 10 seconds. [3]')
108
109
    args = parser.parse_args()
110
    samps,fs = read_wav(args.filename)
111
112
    data = []
113
    correl=[]
114
    bpm = 0
115
    n=0;
116
    nsamps = len(samps)
117
    window_samps = int(args.window*fs)
118
    samps_ndx = 0;  #first sample in window_ndx
119
    max_window_ndx = nsamps / window_samps;
120
    bpms = numpy.zeros(max_window_ndx)
121
122
    #iterate through all windows
123
    for window_ndx in xrange(0,max_window_ndx):
124
125
        #get a new set of samples
126
        #print n,":",len(bpms),":",max_window_ndx,":",fs,":",nsamps,":",samps_ndx
127
        data = samps[samps_ndx:samps_ndx+window_samps]
128
        if not ((len(data) % window_samps) == 0):
129
            raise AssertionError( str(len(data) ) )
130
131
        bpm, correl_temp = bpm_detector(data,fs)
132
        if bpm == None:
133
            continue
134
        bpms[window_ndx] = bpm
135
        correl = correl_temp
136
137
        #iterate at the end of the loop
138
        samps_ndx = samps_ndx+window_samps;
139
        n=n+1; #counter for debug...
140
141
    bpm = numpy.median(bpms)
142
    print 'Completed.  Estimated Beats Per Minute:', bpm
143
144
    n = range(0,len(correl))
145
    plt.plot(n,abs(correl));
146
    plt.show(False); #plot non-blocking
147
    time.sleep(10);
148
    plt.close();
