ESP32 - Software ab Werk?
Gast #5941901
Ich habe heute ein ESP32-Development Board Wroom32 aus China bekommen.
Das Ding wird fühlbar warm, passt zu den rund 150mA Stromaufnahme.
Terminal dran, gibt der einiges aus:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5656
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:13844
entry 0x40078fc4
I (30) boot: ESP-IDF v3.0.7 2nd stage bootloader
I (30) boot: compile time 09:04:31
I (30) boot: Enabling RNG early entropy source...
I (35) boot: SPI Speed      : 40MHz
I (39) boot: SPI Mode       : DIO
I (43) boot: SPI Flash Size : 4MB
I (47) boot: Partition Table:
I (51) boot: ## Label            Usage          Type ST Offset   Length
I (58) boot:  0 phy_init         RF data          01 01 0000f000 00001000
I (65) boot:  1 otadata          OTA data         01 00 00010000 00002000
I (73) boot:  2 nvs              WiFi data        01 02 00012000 0000e000
I (80) boot:  3 at_customize     unknown          40 00 00020000 000e0000
23
I (88) boot:  4 ota_0            OTA app          00 10 00100000 00180000
24
I (95) boot:  5 ota_1            OTA app          00 11 00280000 00180000
25
I (103) boot: End of partition table
26
I (107) boot: No factory image, trying OTA 0
27
I (112) esp_image: segment 0: paddr=0x00100020 vaddr=0x3f400020 size=0x20614 (132628) map
28
I (167) esp_image: segment 1: paddr=0x0012063c vaddr=0x3ffc0000 size=0x02d7c ( 11644) load
29
I (172) esp_image: segment 2: paddr=0x001233c0 vaddr=0x40080000 size=0x00400 (  1024) load
30
I (175) esp_image: segment 3: paddr=0x001237c8 vaddr=0x40080400 size=0x0c848 ( 51272) load
31
I (204) esp_image: segment 4: paddr=0x00130018 vaddr=0x400d0018 size=0xdfc80 (916608) map
32
I (526) esp_image: segment 5: paddr=0x0020fca0 vaddr=0x4008cc48 size=0x02504 (  9476) load
33
I (530) esp_image: segment 6: paddr=0x002121ac vaddr=0x400c0000 size=0x00064 (   100) load
34
I (541) boot: Loaded app from partition at offset 0x100000
35
I (541) boot: Disabling RNG early entropy source...
36
1.1.3
37
I (590) wifi: wifi firmware version: 703e53b
38
I (590) wifi: config NVS flash: enabled
39
I (590) wifi: config nano formating: disabled
40
I (600) wifi: Init dynamic tx buffer num: 32
41
I (601) wifi: Init data frame dynamic rx buffer num: 32
42
I (601) wifi: Init management frame dynamic rx buffer num: 32
43
I (606) wifi: wifi driver task: 3ffdeeb8, prio:23, stack:3584
44
I (611) wifi: Init static rx buffer num: 10
45
I (615) wifi: Init dynamic rx buffer num: 32
46
I (619) wifi: wifi power manager task: 0x3ffe369c prio: 21 stack: 2560
47
I (652) wifi: mode : softAP (a4:cf:12:55:88:a9)
48
I (660) wifi: mode : sta (a4:cf:12:55:88:a8) + softAP (a4:cf:12:55:88:a9)
49
I (663) wifi: mode : softAP (a4:cf:12:55:88:a9)
50
I (668) wifi: set country: cc=CN schan=1 nchan=13 policy=1
Mein PC findet ein Drahtlosnetzwerk "ESP32-5-irgendwas", verbindet sich
und bekommt eine IP 192.168.4.2 zugewiesen, der ESP hat .1.
I (49013) wifi: n:1 1, o:1 0, ap:1 1, sta:255 255, prof:1
I (49015) wifi: station: 74:f0:6d:52:56:59 join, AID=1, n, 40U
Ein Portscan sagt mir, dass zwei TCP-Ports, 80 und 8080, offen sind.
Der Firefox bekommt aber nichts geliefert "Verbindung unterbrochen" -
was fängt man damit an?
Ist das einfach nur Spielekram, um die Funktion WiFi darzustellen oder
hat das einen Nutzwert?
Gast #5941918
Natürlich hat der ESP32 ab Werk SW drauf. Eigentlich war das Ding ja
"nur" als WiFi-Baustein angedacht. Das er genug Leistungsreserven hat
und schneller als viele andere uC am Markt läuft hat dafür gesorgt das
man Ihn als uC zweckentfremdet.
#5942678
Manfred schrieb:
> Die Developmentboards kommen mit aktivem WLAN aus der Tüte und weisen
> einem Client eine IP zu, wenn er sich zu diesem verbindet.
> Ich sehe aber
> nichts, was ich damit anstellen könnte.
eben, du weißt gar nicht was drauf ist.
Da kann ja der Chinese ja rauf spielen was er will, würde mich nicht
drauf verlassen, dass da eine AT-Firmware oder µPython oder Lua drauf
ist. Vom Hersteller ist da erstmal nur der Bootloader drauf und wer auch
immer das Dev-Board gerade gefertigt hat, irgendeine Firmware mit ggf.
OTA sodass du via OTA deine Firmware drauf schmeissen kannst.
Darum sagte ich ja, spiele erstmal was drauf (webserver example oder so)
wo du weißt was er tut
