Atan function implementation
OP #5974827
In
Beitrag "Goertzel-Algorithmus und Signed Fractional Format"
I presented a cordic implementation of the atan function for integer
arguments.
Now I expanded the algorithm to 61-Bit arguments and results referring
to
Beitrag "Näherung für ArcusTangens?"
The precision should be better than 51 Bit. My measure for the precision
tests is the IEEE 754 double-type implementation of atan, so its
built-in precision of ~51 Bit is the limiting factor. The implemantation
is mere C language.
It is again cordic type, a 64Bit integer complex number is rotated with
known angles from a 62 x 64Bit table.
It was a bit tricky, I left the debug stuff for inspection, learning and
fun.
Comments etc. welcome!
It was real big fun!
math rulez!
Cheers
Detlef
Gast #6028627
This looks interesting since CORDIC is easy to implement into
FPGA-Systems. I wonder if the built in CORES can reach that recision. To
my understanding this is the case, since they can be configured to
nearly any precision and depth.
