tcl Variablen Inhalt (Pfad übergeben)
Gast #6152465
Hallo Leute,
ich versuche gerade bei Vivado die .bit Datei nach dem erstellen in die
.mcs umzuwandeln.
Leider funktioniert das Skript nicht.
#finde den Pfad und schreibe diesen in orig_proj_dir
set orig_proj_dir [get_property directory [current_project]]
#gebe den Pfad aus
puts $orig_proj_dir
set orig_proj_dir "[file normalize "$orig_proj_dir/project_1.runs/impl_2/test.bit"]"
#gebe den Pfad aus
puts $orig_proj_dir
#bis hierhin funktioniert es eigentlich wie gedacht
#ab hier gehts schief
write_cfgmem  -format mcs -size 8 -interface SERIALx1 -loadbit {up 0x00000000 {$orig_proj_dir} } -force -file "C:/x/FW.mcs"
Wie kriegt man den Inhalt(Pfad) von orig_proj_dir an write_cfgmem
übergeben??
Vivado Ausgabe:
source C:/x/create_MCS.tcl
# set orig_proj_dir [get_property directory [current_project]]
# puts $orig_proj_dir
C:/x/project_1
# set orig_proj_dir "[file normalize
C:/x/project_1/project_1.runs/impl_2/test.bit
# write_cfgmem  -format mcs -size 8 -interface SERIALx1 -loadbit {up
0x00000000 [$orig_proj_dir] } -force -file "C:/x/FW.mcs"
Command: write_cfgmem -format mcs -size 8 -interface SERIALx1 -loadbit
{up 0x00000000 [$orig_proj_dir] } -force -file C:/x/FW.mcs
Creating config memory files...
Creating bitstream load up from address 0x00000000
Loading bitfile [$orig_proj_dir]
ERROR: [Bitstream 40-47] File [$orig_proj_dir] does not exist.
ERROR: [Bitstream 40-46] File [$orig_proj_dir] cannot be opened for
input.
ERROR: [Writecfgmem 68-7] Could not load bitfile [$orig_proj_dir].
0 Infos, 0 Warnings, 0 Critical Warnings and 3 Errors encountered.
write_cfgmem failed
ERROR: [Common 17-39] 'write_cfgmem' failed due to earlier errors.
    while executing
"write_cfgmem  -format mcs -size 8 -interface SERIALx1 -loadbit {up
0x00000000 [$orig_proj_dir] } -force -file "C:/x/FW.mcs""
    (file "C:/x/create_MCS.tcl" line 9)
#6152520
Die {} um $orig_proj_dir (bzw schon um up) verhindern die evaluation der
Variable
-loadbit "up 0x00000000 $orig_proj_dir"
löst zumindest die Variable auf
besser wäre aber ein
-loadbit [list up 0x00000000 $orig_proj_dir]
Gast #6152536
Danke!
Funktioniert!
Funktioniert nicht!
C:/x/project_1
# set orig_proj_dir "[file normalize "$orig_proj_dir/project_1.runs/impl_2/test.bit"]"
invalid command name "up"
ambiguous command name "up": update update_clock_routing update_compile_order update_design update_files update_ip_catalog update_macro update_module_reference update_noc_qos update_sw_parameters update_timing upgrade_ip uplevel upvar
    while executing
    invoked from within
"write_cfgmem  -format mcs -size 8 -interface SERIALx1 -loadbit [up 0x00000000 $orig_proj_dir] -force -file "C:/x/FW.mcs""
#6152573
Der list Befehl ist die bessere Option, vor allem dann, wenn du Inhalte
mit Leerzeichen einbauen willst.
Zudem muss aus dem Stringliteral auch erstmal wieder eine Liste gebaut
werden.
Passiert zwar alles im Hintergrund, aber es passiert.
