AVR mit VScode
OP #6276211
ich kämpfe nun seit gut 3 Stunden im VScode den Compiler am start zu
bekommen. Ich bekomme folgende Fehlermeldungen im Terminal
Kommen die Meldungen vom Compiler? Denn mein VSCode erkennt die LIB's
Vielleicht sieht jemand einen Fehler?
make
gcc    -c main.c -o main.o
main.c:27: avr/io.h: No such file or directory
main.c:28: avr/interrupt.h: No such file or directory
main.c:33: stdint.h: No such file or directory
main.c:37: util/delay.h: No such file or directory
das Makefile habe ich mir aus dem Debug Ordner meines Projektes bei
Atmel Studio rauskoppiert.
Makefile
# Automatically-generated file. Do not edit!
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS :=
PROJ :=
O_SRCS :=
C_SRCS :=
S_SRCS :=
S_UPPER_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
PREPROCESSING_SRCS :=
OBJS :=
OBJS_AS_ARGS :=
C_DEPS :=
C_DEPS_AS_ARGS :=
EXECUTABLES :=
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=$$$AVR_APP_PATH$$$
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:=
LIB_DEP:=
LINKER_SCRIPT_DEP:=
# Every subdirectory with source files must be described here
SUBDIRS :=
# Add inputs and outputs from these tool invocations to the build
variables
C_SRCS +=  \
main.c
PREPROCESSING_SRCS +=
ASM_SRCS +=
OBJS +=  \
main.o
OBJS_AS_ARGS +=  \
main.o
C_DEPS +=  \
main.d
C_DEPS_AS_ARGS +=  \
main.d
OUTPUT_FILE_PATH +=MultiSwitch_4.elf
OUTPUT_FILE_PATH_AS_ARGS +=MultiSwitch_4.elf
OUTPUT_FILE_DEP:= ./makedep.mk
LIB_DEP+=
LINKER_SCRIPT_DEP+=
# AVR32/GNU C Compiler
./%.o: .././%.c
  @echo Building file: $<
  @echo Invoking: AVR/GNU C Compiler : 4.9.2
  $(QUOTE)C:\Program Files
(x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe
$(QUOTE)   -x c -funsigned-char -funsigned-bitfields -DDEBUG
-I"C:\Program Files
(x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.1.130\include"  -O1
-ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2
-Wall -mmcu=atmega168p -B "C:\Program Files
(x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.1.130\gcc\dev\atmega168p
"  -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)"
-MT"$(@:%.o=%.o)"   -o "$@" "$<"
  @echo Finished building: $<
# AVR32/GNU Preprocessing Assembler
# AVR32/GNU Assembler
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
variables
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP)
$(LINKER_SCRIPT_DEP)
  @echo Building target: $@
  @echo Invoking: AVR/GNU Linker : 4.9.2
$(QUOTE)  -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS)
$(LIBS) -Wl,-Map="MultiSwitch_4.map" -Wl,--start-group -Wl,-lm
-Wl,--end-group -Wl,--gc-sections -mmcu=atmega168p -B "C:\Program Files
  @echo Finished building target: $@
  "C:\Program Files
(x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy
.exe"  -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R
.user_signatures  "MultiSwitch_4.elf" "MultiSwitch_4.hex"
  "C:\Program Files
.exe"  -j .eeprom  --set-section-flags=.eeprom=alloc,load
--change-section-lma .eeprom=0  --no-change-warnings -O ihex
"MultiSwitch_4.elf" "MultiSwitch_4.eep" || exit 0
  "C:\Program Files
(x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump
.exe"  -h -S "MultiSwitch_4.elf" > "MultiSwitch_4.lss"
  "C:\Program Files
.exe"  -O srec -R .eeprom -R .fuse -R .lock -R .signature -R
.user_signatures "MultiSwitch_4.elf" "MultiSwitch_4.srec"
  "C:\Program Files
(x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.ex
e"  "MultiSwitch_4.elf"
# Other Targets
clean:
  -$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES)
  -$(RM) $(C_DEPS_AS_ARGS)
  rm -rf "MultiSwitch_4.elf" "MultiSwitch_4.a" "MultiSwitch_4.hex"
"MultiSwitch_4.lss" "MultiSwitch_4.eep" "MultiSwitch_4.map"
"MultiSwitch_4.srec" "MultiSwitch_4.usersignatures"
meine c_cpp_properties.json
    "configurations": [
            "name": "Win32",
            "includePath": [
                "${workspaceFolder}/**",
                "C:\\Program Files (x86)\\Atmel\\Atmel Toolchain\\AVR8
GCC\\Native\\3.4.1061\\avr8-gnu-toolchain\\avr\\include"
            "browse": {
                "limitSymbolsToIncludedHeaders": false,
                "path": [
Toolchain\\AVR8 GCC\\Native\\3.4.1061\\avr8-gnu-toolchain\\avr\\include"
            "defines": [
                "__AVR_ATmega168PA__"
            "windowsSdkVersion": "10.0.10586.0",
            "compilerPath": "C:\\Program Files
(x86)\\Atmel\\Studio\\7.0\\toolchain\\avr8\\avr8-gnu-toolchain\\bin\\avr
-gcc.exe",
            "cStandard": "c11",
            "cppStandard": "c++17",
            "intelliSenseMode": "gcc-x64"
    "version": 4
Huhu,
schau dir mal die "AVR Helper" Extension an. Da must du zwar den avr-gcc
und co selber installieren und kannst nicht das Atmel Studio nutzen,
aber vielleicht ist das einfacher zu handhaben.
btw. msys2 lohnt sich dabei immer zu installieren und dananch noch das
bin Verzeichnis von zum pfad hinzufügen.
Falls das dein compiler ouput ist:
Dann wird nicht avr-gcc aufgerufen, sondern ein anderer gcc.
Der hat wiederrum nicht die benötigten Header.
Schau mal mit sysinternals process monitor nach welche gcc executable
wirklich aufgerufen wird.
Ganz einfach gehts, wenn du dir platformio im vscode installierst.
Das verwaltet dann Compiler & Tools in den gewünschten Versionen,
Frameworks, Bibliotheken, Flash-tools usw. vollautomatisch.
