Quartus Prime Lite Failed to find INSTANCE
Gast #6303097
Hey,
eine Freundin und ich verzweifeln seit einigen Stunden an einer
Fehlermeldung von Quartus Prime Lite:
Error (suppressible): (vsim-SDF-3250)
Counter_6_1200mv_85c_vhd_slow.sdo(0): Failed to find INSTANCE '/i1'.
Error (suppressible): (vsim-SDF-3894) : Errors occured in reading and
resolving instances from compiled SDF file(s).
Aber wir haben keine Ahnung woran das liegen könnte. Das *.bdf ist
bereits die top entity, das ändert nichts am Bug. Gibt es vielleicht im
Code ein Problem? Der Compiler läuft durch.
Der Code:
-- ADC reader: reads data from ADXL345
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity g_reader is port (
  clk_50: in std_logic;  -- 50 MHz clock
  reset_n : in std_logic; -- reset signal (active low)
  -- SPI interface
  CS_N : out std_logic;   -- connected to chip select of g sensor
  SCLK : out std_logic;   -- spi clock
  SDIO : inout std_logic; -- spi data (bidirectional)
  -- data output
  dataX : out std_logic_vector(12 downto 0);
  dataY : out std_logic_vector(12 downto 0);
  dataZ : out std_logic_vector(12 downto 0)
end g_reader;
23
24
25
architecture behavior of g_reader is
26
  signal SCLK_counter : integer := 0;     -- starts clock
27
  signal SCLK_1 : std_logic;           -- 1 MHz clock
28
29
  constant half_period : time := 10 ns;
30
31
begin
32
33
  -- SCLK
34
  process(clk_50)
35
  begin
36
37
    if (falling_edge(clk_50)) then
38
39
      if (SCLK_counter <= 24) then
40
        SCLK_1 <= '0';
41
      else
42
        SCLK_1 <= '1';
43
      end if;
44
45
      if (SCLK_counter >= 49) then
46
        SCLK_counter <= 0;
47
      else
48
        SCLK_counter <= SCLK_counter + 1;
49
      end if;
50
51
    end if;
52
53
  end process;
54
55
  CS_N <= '0';
56
  SCLK <= '0';
57
  dataX <= "0000000000000";
58
  dataY <= "0000000000000";
59
  dataZ <= "0000000000000";
60
61
62
end behavior;
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY g_reader_vhd_tst IS
END g_reader_vhd_tst;
ARCHITECTURE g_reader_arch OF g_reader_vhd_tst IS
-- constants
-- signals
signal clk : std_logic := '0';
SIGNAL clk_50 : STD_LOGIC;
SIGNAL CS_N : STD_LOGIC;
SIGNAL dataX : STD_LOGIC_VECTOR(12 DOWNTO 0);
SIGNAL dataY : STD_LOGIC_VECTOR(12 DOWNTO 0);
SIGNAL dataZ : STD_LOGIC_VECTOR(12 DOWNTO 0);
SIGNAL reset_n : STD_LOGIC;
SIGNAL SCLK : STD_LOGIC;
SIGNAL SDIO : STD_LOGIC;
COMPONENT g_reader
  PORT (
  clk_50 : IN STD_LOGIC;
  CS_N : OUT STD_LOGIC;
23
  dataX : OUT STD_LOGIC_VECTOR(12 DOWNTO 0);
24
  dataY : OUT STD_LOGIC_VECTOR(12 DOWNTO 0);
25
  dataZ : OUT STD_LOGIC_VECTOR(12 DOWNTO 0);
26
  reset_n : IN STD_LOGIC;
27
  SCLK : OUT STD_LOGIC;
28
  SDIO : INOUT STD_LOGIC
29
30
END COMPONENT;
31
BEGIN
32
  i1 : g_reader
33
  PORT MAP (
34
-- list connections between master ports and signals
35
  clk_50 => clk_50,
36
  CS_N => CS_N,
37
  dataX => dataX,
38
  dataY => dataY,
39
  dataZ => dataZ,
40
  reset_n => reset_n,
41
  SCLK => SCLK,
42
  SDIO => SDIO
43
44
init : PROCESS
45
-- variable declarations
46
BEGIN
47
        -- code that executes only once
48
WAIT;
49
END PROCESS init;
50
51
clk_proc : process
52
begin
53
  clk <= not clk after half_period;
54
end process clk_proc;
55
56
end g_reader_arch;
Danke im Voraus.
Grüße
Jonas
Moderator (Firma: Titel) Persönliche Seite #6303153
Im angehängten Code sollte zwar der clk dem clk_50 zugewiesen werden:
  clk_50 => clk,
aber generell brauche ich zum Simulieren ausser den beiden Dateien keine
wie auch immer geartete bdf Datei. Das Problem dürfte also vorrangig
nicht im Code, sondern in der Projektverwaltung liegen.
BTW:
Du brauchst da keinen Prozess:
-- clk_proc : process
-- begin
clk <= not clk after half_period; -- nebenläufig ganz ohne Prozess geht's auch
-- end process clk_proc;
Hey,
danke für die Antwort. Ich konnte das Problem jetzt halbwegs ausfindig
machen, gemäß dieser Anleitung hier:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd05152000_7434.html
Allerdings steht da ich muss die SDF Files auswählen, aber im Ordner
sind mehrere? Wenn ichs dann ausgewählt habe, kann ich auch irgendwie
nicht "Ok" drüken.
#6303459
>   clk_50 => clk,
das ist wahrscheinlich tatsächlich der Grund, aber das hilft ihm jetzt
nicht viel, Lothar.
Tatsächlich ist es so, dass Quartus (bzw. das dazugehörige ModelSim) in
der Lite Edition keine (echte) mixed mode simulation unterstützt.
Stattdessen wird aus der Netzliste "rückwärts" wieder eine (.vho)
VHDL-Datei (die mit den ursprünglichen Quellen naturgemäss herzlich
wenig zu tun hat) erzeugt, die ModelSim dann simulieren kann.
Meiner Meinung nach ist der Nutzen einer solchen Simulation für die
Verifikation reichlich gering (weil man bei Fehlern schon ein gewisses
Abstraktionsvermögen haben muss, um die anschliessend in den
eigentlichen Quellen "reparieren" zu können).
Der eigentliche Grund für das Problem ist also in der (m.E. unnötigen)
Realisierung des Toplevels als grafische .bsf Datei zu suchen. Warum
wurde das so gemacht? Das Modell ist doch - so zumindest mein Eindruck -
so simpel, dass das Toplevel problemlos in ein paar Zeilen
hingeschrieben wäre?
Dann könnte ModelSim nämlich den "tatsächlichen" VHDL Code simulieren
und  "plötzlich" würden auch Fehlermeldungen wieder Sinn ergeben.
  • [vhdl]VHDL-Code[/vhdl]
