[V] LPC1768 LandTiger BaseBoard Development Board
OP #6359034
1 Stück LPC1768 LandTiger BaseBoard Development Board
mit folgenden Komponenten:
* 2 RS232 serial interfaces (using straight-through serial cable),
(RS232 Transceiver: SP3232). One serial port supports ISP download of
programs.
* 2 CAN bus communication interfaces (CAN Transceiver: SN65VHD230).
* RS485 communication interface (485 Transceiver: SP3485).
* RJ45-10/100M Ethernet network interface (Ethernet PHY: DP83848).
* DAC output interface, on-board speaker and speaker output driver
(LM386).
* ADC input interface, on-board adjustable potentiometer input.
* Color LCD display interface (supports 2.8-inch or 3.2-inch color TFT
320X240). Touchscreen supported through SPI interface.
* USB2.0 Interface (USB host and USB Device interface).
* SD/MMC card (SPI) interface.
* I2C Interface, connected to onboard 2Kbit EEPROM (24LC02).
* SPI serial interface connected to onboard 16Mbit Flash (AT45DB161D).
* 2 user keys, 2 function keys (INT0 and Reset button).
* 8 LEDs (Digital outputs).
* Five-way joystick button (Digital Inputs).
* Serial ISP download support.
* Standard JTAG download, simulation debugging interface.
* Integrated JLINK compatible emulator (USB): supports online simulation
and debug capabilities (KEIL, IAR and other mainstream development
environments).
* External 5V power supply or USB input to provide 5V power supply.
* Breakout available for all the IOs for external application
development circuits.
Ich habe leider nie die Zeit gefunden, mich mit dem Board zu
beschäftigen und werde es wohl auch nicht, daher wird es jetzt "frei"
gegeben.
Preisvorstellung: 45,- EUR inklusive Päckchenversand
English: Hello,
I am interested in purchasing the item. Is it still available? Would you be able to ship it to Italy? Are there any additional shipping costs I should be aware of?
Thank you in advance for your response.
Best regards, Gabriele Piovano
Deutsch: Hallo,
Ich bin daran interessiert, den Artikel zu kaufen. Ist er noch verfügbar? Könnten Sie ihn nach Italien versenden? Fallen zusätzliche Versandkosten an, die ich berücksichtigen sollte?
Vielen Dank im Voraus für Ihre Antwort.
Mit freundlichen Grüßen, Gabriele Piovano
