IR recoder topic
OP #6382002
Hello everyone,
I am try to make IR learning remote by using microcontroller ( my item
is EFR32 of Silicon labs)
I used to refer IRMP_English and IRSND to decoder and encoder IR signal
and I was successful with protocols which are available in the IRMP
Protocols.
but it will not work with strange protocols.
Do we need to decode it to be able to save it and emit it?
Is there any way we could capture the infrared signal, then save it and
emit it without encoding end decoding it? because if encoding and
recording will not work if there is a strange protocol.
I searched a lot of information on various forums but couldn't find it.
#6382004
Not necessarily. I'd use constant time interval sampling of the
demodulated signal.
Good old Nyquist says if your sample distance t_s is less than twice the
shortest distinguishable timespan t_d of the protocol, it should work.
N.b. the shortest distinguishable time span would be t_d=1msec if 4msec
pulses and 5msec pulses must be distinct.
Lê Q. schrieb:
> because if encoding and recording will not work if there is a strange
> protocol.
Maybe you analyze the demodulated signal and compare to existing codes.
If it partly fits, reuse some code from existing code implementation.
Is there a way for you to record the demodulated signal to a file? E.g.
Logic analyzer? I suggest posting the file here.
OP #6382009
Until now, there is no way for me to record the demodulated signal to a
file.
So As you say: "Not necessarily. I'd use constant time interval sampling
of the demodulated signal." Can you give me more information? I still
don't quite understand.
#6382163
Recording
TSOP1136 -> MCU-pin -> sample with 10kHz task -> 10kHz bitstream
Replay
Timer 40kHz     -> MCU-Pin0
10kHz bitstream -> MCU-Pin1
(MCU-Pin0 & MCU-Pin1) -> IR-LED
By the way, the IRMP does allow for offline-Analysis.
Can you share some information about the device which you want to
control?
Brand, type of device etc...?
br, mf
#6382172
PS "demodulated signal"
Most IR remote controls use a carrier about 40kHz, which is then
modulated
IR    ____|||||____||||||____ ...
      ____     ____      ____
demod     |___|    |____|     ...
demod is inverted, because most receiver IC have open-collecor-output
Simple receiver IC like the TSOP1136 or more modern ones (no idea what's
available in your country) will demodulate i.e. remove the 40kHz carrier
