Frage zu Attiny-Programm
Gast #6475339
Hallo, ich habe keinen Peil von Attinys, deshalb wende ich mich an euch.
Folgendes Programm soll je nach Potistellung einen Ultraschallton
ausgeben.
Was ich wissen möchte, welcher Tastgrad hat der Ton? 0,5?
//Attiny25 , running @ 1MHZ
// Using timer 1
//  Ain0       (D  5)  PB5  1|    |8   VCC
//  Ain3       (D  3)  PB3  2|    |7   PB2  (D  2)  INT0  Ain1 <- Potmeter input
//  Ain2       (D  4)  PB4  3|    |6   PB1  (D  1)        pwm1 <- Speaker output
//                     GND  4|    |5   PB0  (D  0)        pwm0 <- Led output
//  calculate output frequency
//  clockspeed / prescaler / OCR1C = frequency(Hz)
//  clockspeed / prescaler / frequency = OCR1C
//  OCR1C = OCR1A
#include <avr/sleep.h>
#include <avr/interrupt.h>
#include <avr/wdt.h>
#define potmeter A1
#define adcDisable() (ADCSRA &= ~(1<<ADEN)) // disable ADC
23
#define adcEnable()  (ADCSRA |=  (1<<ADEN)) // re-enable ADC
24
byte compareValue = 0;
25
26
void setup() {
27
  disableWatchdog();
28
  adcEnable();
29
  compareValue = map(analogRead(potmeter), 0, 1023, 25, 10);
30
  startTimer1(); //20 - 50 kHz -> OCR0A: 25 - 10
31
  adcDisable();
32
  pinMode(0, OUTPUT);
33
  digitalWrite(0, HIGH);
34
  delay(1000);
35
  digitalWrite(0, LOW);
36
  stopTimer1();
37
  enableWatchdog();
38
  enterSleep();
39
40
41
void loop() {
42
43
44
void startTimer1(void) {
45
  pinMode(1, OUTPUT);
46
  TCNT1 = 0;
47
  TCCR1 = 0;
48
  GTCCR |= (1 << PSR1); //section 13.3.2 reset the prescaler
49
  TCCR1 |= (1 << CTC1); // section 12.3.1 CTC mode
50
  TCCR1 |= (1 << COM1A0); //togle pin PB1 table 12-4
51
  TCCR1 |= (1 << CS10); //prescaler 1 table 12-5
52
  //TCCR1 |= (1 << CS11);
53
  //TCCR1 |= (1 << CS12);
54
  //TCCR1 |= (1 << CS13);
55
  OCR1C = compareValue;
56
  OCR1A = compareValue;
57
58
59
void stopTimer1(void) {
60
  TCNT1 = 0;
61
  TCCR1 = 0;
62
63
64
void enableWatchdog(void) {
65
  wdt_enable(WDTO_8S); //enable watchdog
66
67
68
void disableWatchdog(void) {
69
  MCUSR &= ~(1<<WDRF); // reset status flag
70
  wdt_disable(); //reset watchdog
71
72
73
void enterSleep(void) {
74
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
75
  sleep_mode();
76
Beitrag #6475530 wurde von einem Moderator gelöscht.
Gast #6475552
c-hater, deine persönlichen Angriffe sind unter aller Kanone. Dagegen
hilft kein Fachwissen. Dein Auftreten hier ist fast genau so peinlich,
wie das des Bademeisters, ist dir das nicht bewusst?
Gast #6475553
c-hater schrieb im Beitrag #6475530:
> Aber du hast es ja nicht
> einmal für nötig gehalten, zu erwähnen, welcher es denn konkret ist.
Verdammt, in der Schaltungs-Skizze taucht doch eine konkreter Tiny auf,
das hatte ich glatt übersehen. Ein Tiny25.
Also für den ist das Programm nicht nur wahrscheinlich, sondern sogar
ganz sicher falsch.
Wie's richtig wäre, steht im Datenblatt.
Beitrag #6475561 wurde von einem Moderator gelöscht.
Beitrag #6475563 wurde von einem Moderator gelöscht.
Gast #6475566
Ja genau. Und das Programm sieht gar nicht schlecht aus. Lass den
c-hater mal über c haten, den kannst du nicht mehr für voll nehmen.
Irgendwie hat er sich in seiner Rolle verloren und kommt da nicht mehr
heraus.
Gast #6475571
c-hater schrieb im Beitrag #6475561:
> Wenn du Flachwichser auch irgendwas kompetent zur Sache beigetragen
> hättest, könnte ich den Angriff akzeptieren. Hast du aber nicht.
Du hast schon wieder ein paar Sekunden zu schnell geschossen. Ich habe
sein Programm geprüft, Zeile für Zeile mit den DB verglichen. Das dauert
eine Weile. Dabei bin ich zu dem oben genannten Schluss gekommen.
Gast #6475579
8 Beiträge und nicht eine Antwort die den TO hilft.
Sauber.
@TO
Lerne mal den Unterschied zwischen SETUP und LOOP.  Kleiner Tipp. Setup
wird EINMAL ausgeführt und nie wieder.
LOOP wird immer ausgeführt es sei den der Code ist in einer Unterroutine
beschäftigt.
Du schaltet in dein Setup den Timer EIN und danach wieder aus. Ergo, hat
das Programm 0 Funktion, außer das es mal für genau 1 Sek. zuckt.
Ich würde den Bereich.
  delay(1000);
in das LOOP stecken.
Dann wird je Sekunden umgeschaltet.
Aber in einen gebe ich den Leuten hier recht. Dein Code ist Mist.
Gast #6475581
Stefan ⛄ F. schrieb:
> Du hast schon wieder ein paar Sekunden zu schnell geschossen. Ich sein
> Programm geprüft, Zeile für Zeile mit den DB verglichen. Das dauert eine
Aha, es war dir also bei weitem wichtiger, gegen mich zu feuern, als dem
TO zu helfen. Das läßt tief blicken...
Im Übrigen hast du fachlich allerdings wirklich Recht. Das Programm
sieht zwar arduinomäßig Scheiße aus, ist aber tatsächlich korrekt.
Gast #6475589
c-hater hater schrieb:
>>Dein Code ist Mist.
> @Schlaumaier
> Mann ... der Code ist von Elektor. Nicht von Tom.
Woher soll ich das denn wissen. Trotzdem. Ich würde dann doch gerne mal
den Original-Code sehen.
Ich würde fast wette das die Befehle :
  delay(1000);
In die LOOP-Routine gehören.
Aber verrate mir mal woher du das weißt. Habe ich da was übersehen ??!?
(Firma: @home) #6475594
> Sprich: auf ganzer Linie wegen völliger Unfähigkeit verloren. Sogar die
> Frage im Forum verhauen, weil nichtmal dafür die Kompetenz genügt. Such'
> dir ein anderes Hobby. Briefmarkensammeln z.B...
... könnte von mir sein, alles wird nur noch zugemüllt bzw. das Niveau
sinkt hier nur!
Gast #6475598
> Ja. Scroll mal nach oben.
Ok. Hab ich bei der Zankerei wirklich.
Habe mir gerade mal den Original-code angesehen. Die wollen wirklich das
das Teil wirklich nur einmal Krach macht. Gut für die Ohren. ;)
Gast #6475600
Aber mir hat das was gebracht. Ich kannte die Seite noch nicht. Danke
C-Hater dafür.
Ach ich schreibe selbst nicht direkt in Arduino-C weil ich C nicht mag.
Hab mich mit der Syntax nur nebenbei beschäftigt. Was aber nix an meinen
Aussagen ändert.
Gast #6475651
>   delay(1000);
Das Ding soll alle 10 Sekunden "Piep" machen.
Der Watchdog Timer löst alle 10 Sekunden einen Reset aus. Dann soll das
Ding jeweils eine Sekunde lang einen Ton von sich geben. Dafür ist das
delay(). Danach legt er sich schlafen, um Strom zu sparen.... bis der
Watchdog ihn in 9s wieder weckt.
Der Quelltext ist einwandfrei. Die haben von Arduino verwendet, was da
ist, und die fehlenden Features selbst "zu Fuß" implementiert. Das ist
völlig Ok. Man muss nicht für jeden Furz eine Library verwenden.
Gast #6475679
>> Danke nicht c-hater, sondern c-hater hater.
> och nö.
> Ich glaub zwar nicht das er mich mag, aber was Recht ist muss Recht
> bleiben. Und bei mir gilt halt. Wen dir einer etwas guter Tut, sag
> DANKE.
Warum dankst du nicht dem, der den Link schrieb?
Das war "c-hater hater" und nicht der andere ohne Manieren...
(Firma: Hobbytheoretiker) #6475680
Well Done. Die Details von Dir danach hätte eigentlich der TO liefern
muessen.
> Du hast nicht nur keine Ahnung von ATtinys,
> Such' dir ein anderes Hobby. Briefmarkensammeln z.B...
Einen solchen Beitrag als erstes Feedback sieht sehr cholerische aus.
Jeder backt erst einmal kleine Brötchen und stolpert über Grundlagen,
wenn nicht im engeren Kreis von Familie, Freunden oder Bekannten jemand
dabei ist, von dem erstmal vieles abzuschauen war.
Gast #6475683
Weil ich beide Verwechselt habe und deinen Text Fehlinterpretiert habe.
Ihr macht mich mit den Mist ganz kirre.
Aber du hast Recht.
DANKE den "c-hater hater" und nicht den anderen.
Gast #6475711
Fast. WD ist auf 8s eingestellt = 8s Schlaf, 1s macht er den Ton, also
Wiederholung alle 9s. Ist aber marginal ...
Ansonsten richtig analysiert.
