AVR C array Programmierung wo liegt der Fehler?
OP #6516636
ich experimentiere gerade mit einem HUB75 Panel 32x64 LEDS an einem
ATMEGA644p
Dazu habe ich folgende Funktion zum schreiben des Display geschrieben:
volatile uint64_t
R_displayline[32]={0b111111111111111111111111111111111111111111111111111
1111111111111};  //Array für displaydaten R
volatile uint64_t G_displayline[32]; //Array für displaydaten G
volatile uint64_t B_displayline[32]; //Array für displaydaten B
void write_display()
  uint64_t R1_temp;
  uint64_t G1_temp;
  uint64_t B1_temp;
  B_displayline[1]=0b11111111111111111111111111111111111111111111111111111
11111111111;
  for(uint8_t i=0;i<16;i++)  //16 Zeilen x 2 schreiben
      //LINE=i;
      //LINE<< 2; //Passend für PORTA 2 nach links schieben
      //PORTA |= LINE; //Line schreiben
      switch(i)
        case 0:
        PORTA=0b00000000;
        break;
        case 1:
        PORTA=0b00000100;
        break;
        case 2:
        PORTA=0b00001000;
        break;
        case 3:
        PORTA=0b00001100;
        break;
        case 4:
        PORTA=0b00010000;
        break;
        case 5:
        PORTA=0b00010100;
        break;
        case 6:
        PORTA=0b00011000;
        break;
        case 7:
        PORTA=0b00011100;
        break;
        case 8:
        PORTA=0b00100000;
        break;
        case 9:
        PORTA=0b00100100;
        break;
        case 10:
        PORTA=0b00101000;
        break;
        case 11:
        PORTA=0b00101100;
        break;
        case 12:
        PORTA=0b00110000;
        break;
        case 13:
        PORTA=0b00110100;
        break;
        case 14:
        PORTA=0b00111000;
        break;
        case 15:
        PORTA=0b00111100;
        break;
      R1_temp=0b10000010000000000000000000000000000000000000000000000000000000
01
G1_temp=0b01000010000000000000000000000000000000000000000000000000000000
01;
      B1_temp=B_displayline[i];
      for(uint8_t row=0;row<64;row++)
          if (R1_temp & 0x1){
            PORTD |= (1<<R1);}
            else{
            PORTD &= ~ (1<<R1);
            R1_temp = R1_temp >> 1;
          if (G1_temp & 0x1){
            PORTC |=(1<<G1);}
            else{
            PORTC &= ~ (1<<G1);
            G1_temp = G1_temp >> 1;
          if (B1_temp & 0x1){
            PORTC |= (1<<B1);}
            else{
            PORTC &= ~(1<<B1);
          B1_temp = B1_temp >> 1;
          PORTA &= ~(1<<R2); //obere Hälfte
          PORTD &= ~(1<<G2);
          PORTD |=(1<<B2);
          //Clock Signal erzeugen
          PORTC |= (1<<CLK);
          _delay_us(0.1);
          PORTC &= ~(1<<CLK);
        //Ein"latchen" der Reihe
        PORTC |= (1<<PC5);
        _delay_us(0.1);
        PORTC &= ~(1<<PC5);
    PORTC |=(1<<PC3);
    _delay_us(0.1);
    //Output Enable =1
    PORTC &= ~(1<<OE);
Leider habe ich in B_displayline[1] bzw in B_temp am ende nicht die oben
gesetzte
11111111111;  drin.
Wo liegt hier der Fehler? Ich hab mir die C Doku öfters angeschaut und
es müsste alles passen, über welchen Fallstrick bin ich hier gestolpert?
au weia schrieb:
> Also wir haben damals auch mit der Hand die Bits einzeln in
> die Lochkarten gestanzt.
Wir konnten das schon mit Bleistift machen für die HP. Wurden aber
gewarnt nur Bleistifte der Härte HB herzunehmen und aufzupassen die
Karten nicht aneinander zu reiben, weil sonst die Markierung verwischt.
OP
au weia schrieb:
> Johannes M. schrieb:
>> _delay_us(0.1);
> Ist das Ernst oder kann das weg?
> ROFL!
Ich habe mich langsam an das Mögliche Timing herangeastet und am Ende
einfach per Suchen und Ersetzen 0.1 eingetragen. Ich weiß das es
eigentlich auch weg kann. Aber auch das tut ja hier nichts zur Sache und
war auch nicht meine Frage.
> Habe ich doch geschrieben. Es sollte bei Zeile 1 also i=1 in
> B_displayline 0b111111111111111111111111111111 stehen. tut es aber
> nicht.
Nein!
Du hast geschrieben:
> gesetzte
> 11111111111;  drin.
Ein  B_temp gibt es in dem Code nicht.
Und dein B1_temp wird leer geschoben.
Also ist es hinterher auch leer.
Warum erwartest du was anderes?
Zudem wird B_displayline[1] nirgendwo anders geändert.
Also muss da auch noch das drin stehen, was du rein geschrieben hast.
Es sei denn, du hast irgendwo einen Zeiger, welcher aus dem Ruder läuft,
und die Daten dort werden versehentlich überschrieben.
> nicht.
Du hast aber Element [0] mit Daten gefüllt, Element [1] und alle
weiteren 30 sind 0.
Außerdem ist in deinem Programm nicht erkennbar, wo du R_displayline
irgendwohin ausgibst. Wie stellst du fest, dass es nicht funktioniert?
Wenn du das als Init von Element 1 benötigst, dann wäre es vielleicht
geeigneter zu schreiben:
  volatile uint64_t R_displayline[32]={0, 0xFFFFFFFFFFFFFFFF};
HildeK schrieb:
> Mist, und Makulatur - habe mich aufs falsche Array konzentriert.
Eine positive Bewertung von mir, wegen zugeben eines Irrtums.
Wäre eigentlich nicht erwähnenswert.
.. aber in diesem Forum ist einiges "anders" ...
HildeK schrieb:
> Mich ärgert das ja selber:
Muss es nicht!
Jeder Fehler/Irrtum ist eine Gelegenheit was zu lernen.
Und sei es auch nur das Schärfen der Aufmerksamkeit.
Einer meiner Leitmotive:
> Irren ist menschlich.
> Im Irrtum verharren, Dummheit.
Einen eigenen Irrtum eingesehen zu haben, verbuche ich als einen Erfolg.
Es ist also eher ein Grund zur Freude, als zum ärgern.
Leider ist das zugeben von Irrtümern, hier im Forum, eher selten.
Darum habe ich mir vorgenommen das "positiv zu besetzen".
Denn ich halte es für eine Art mentaler Stärke/Festigkeit, zu einem
Irrtum oder einem "nicht genau wissen" zu stehen.
Andererseits, könnte es auch sein, dass hier Unmengen an Unfehlbaren
Genies unterwegs sind.
Dann werde ich mit der Methode nicht weit kommen....
OP
Die b1_temp soll ja später seriell rausgeschrieben werden, deswegen
möchte ich ja die aktuelle Zeile vom array in die Temp Variable
schreiben. Aber das klappt ja leider nicht.
Also ich schreibe:
volatile uint64_t B_Displayline[32];
volatile uint64_t B1_temp;
B_Displayline[0]=0xFF;
B1_temp=B_Displayline[0];
Dann sollte doch in B1_temp 0xFF stehen. tut es aber nicht! Was mache
ich falsch?
Wo kommt denn das R1 da her:
            PORTD |= (1<<R1);}
Der Code ist nicht komplett, es ist die alte Leier.
Poste den completten code im Anhang, dann get es weiter.
Hier fehlt ein Strichpunkt:
01
Willst du uns verarschen? Das läuft nicht mal durch den Compiler!
So auf die schnelle:
#include <stdio.h>
#include <inttypes.h>
int main() {
uint64_t B1_temp;
B1_temp = 1234;
printf("\nB1_temp = %d", B1_temp);
printf("\nB1_temp = %04x", B1_temp);
return 0;
compiliert - fkt; Ausgabe
B1_temp = 1234
B1_temp = 255
B1_temp = 00ff
Wo ist das Problem?
Beitrag #6518076 wurde von einem Moderator gelöscht.
Beitrag #6518079 wurde von einem Moderator gelöscht.
Beitrag #6518086 wurde von einem Moderator gelöscht.
> Also ich schreibe:
> ich falsch?
Weiß ich nicht!
Bei mir tuts das:
#include <Streaming.h>
#include <CombieBigInt.h>
void setup()
  Serial.begin(9600);
  Serial << "Start: "<< __FILE__ << endl;
  char buffer[100];
  Serial << "Result: 0x" << bigToStr(buffer,B1_temp,16) << endl;
void loop()
Sagt:
Start: c:\temp\arduino_modified_sketch_696171\CombieBigInt.ino
Result: 0xFF
Teo D. schrieb im Beitrag #6518086:
> "Insiderkreisen" == Kindergarten Gewäsch
Freut mich, dass du zumindest das erkannt hast.
Jetzt wird es für dich etwas komplizierter!
Das nennt sich Sarkasmus. Hier kannst du es nachlesen, sind auch Bilder
dabei. Bilder scheinen ja dein Spezialgebiet zu sein, neben
Kompressoren.
https://de.wikipedia.org/wiki/Sarkasmus
Hmmm, schwer zu erkennen, aber nicht unwahrscheinlich. Allerdings in
Anbetracht dessen, dass du das mit dem Link setzen, an satt Urzeit und
Datum zu einem Beitrag anzugeben, bis zuletzt nicht verstanden hastest,
lies mir einfach keine Wahl! ... Vorhausgesetz, du erinnerst dich noch
an GESTERN! ;P
Ach Sche.., da gibts leider noch dutzende Beiträge von dir.....
Hast du auch brav überall Minus geklickt? Ja?
Dann darfst du jetzt ins Bett. Aber zieh vorher deine Unterhose aus und
mach dich gründlich sauber.
Es freut mich wirklich aufrichtig, dass du jetzt eine Aufgabe für dich
gefunden hast. Ich denk, es ist auch recht fordernd für dich überall zu
suchen wo ich was schreib. Mach dir nicht die Arbeit meine Texte zu
lesen, die überfordern dich offensichtlich, klicken ist in deiner
Situation schon ein beachtlicher Fortschritt.
Alles gute weiterhin und wenn es dir schlechter geht, klingle nach der
Nachtschwester.
Ja, hier und jetzt. Damit du nicht glaubst, ich sei der Einzige....
PS;: Ohh, Sorry, ich vergaß, dies wird dich wieder geistig überfordern.
PPS: Oje, und das nach meinem Epic-Fail von Gestern..... :PPP
PPPSL: Ich bin raus! Is ja nich zum aushalten, so ein offtopic
Kindergarten gegenlenke. JA, natürlich meine ich uns BEIDE. Also las
noch einen ab und gut is dat!
Na, immerhin hast du damit schon mal zugegeben einer der zwei zu sein.
Der Andere ist vermutlich seniler als du.
Du hast dir heute in die Hose gemacht. Gestern war das mit dem nackt
im Park rumlaufen. Aber die Polizistinnen kennen dich und haben dich
unter Würgreiz zurück ins Heim gebracht. Bedank dich aber bitte nicht
mehr bei denen, denn das letzte Mal war mehr als appetitlos.
Das solls jetzt gewesen sein, Danke!
