1 | /*********************************************************************************
2 | * File: 6_Panel.C
3 | * Controller: PIC18F45K22
4 | * Compiler: CC18
5 | * Date: 25.5.2020
6 | * Author:
7 | * Description: Solarstation groß
8 | ************************************************************************************
9 | Header files
10 | ************************************************************************************/
11 | #include <p18f45k22.h>
12 | #include <stdlib.h>
13 | /***********************************************************************************
14 | Configuration Bits
15 | ************************************************************************************/
16 |
17 | #pragma config FOSC=INTIO67, PWRTEN=ON, BOREN=ON, PLLCFG = ON, MCLRE=INTMCLR, WDTEN=ON, WDTPS = 256, LVP=OFF, PBADEN=OFF //, P2BMX = PORTD2, T3CMX = PORTB5
18 | /***********************************************************************************
19 | Konstanten
20 | ************************************************************************************/
21 | #define REL1 LATAbits.LATA4
22 | #define REL2 LATEbits.LATE1
23 | #define REL3 LATBbits.LATB4
24 | #define REL4 LATBbits.LATB1
25 | #define REL5 LATDbits.LATD6
26 | #define REL6 LATCbits.LATC5
27 | #define ENABLE PORTBbits.RB5
28 | #define LCD_OFF LATCbits.LATC4
29 | #define CREN RC1STAbits.CREN
30 | #define RCIF PIR1bits.RC1IF
31 | #define OERR RC1STAbits.OERR
32 | #define SPEN RCSTA1bits.SPEN
33 | #define FERR RCSTA1bits.FERR
34 | #define RELAIS2 LATEbits.LATE2
35 | #define NETZ PORTCbits.RC0
36 | #define UP PORTAbits.RA7
37 | #define DOWN PORTAbits.RA6
38 |
39 | /**********************************************************************************
40 | Variablen
41 | ***********************************************************************************/
42 | unsigned char DATA, MWERT, TEMP1, INSEL, ANZ, INV_FLAG, TAST_FLAG;
43 | unsigned int DATA1, TEMP2, U1, U2, U3, U4, U5, U6, I1, I2, I3, I4, I5, I6, P_IN, I_REIN, P_OUT, P_MAX;
44 | unsigned int U_INV, U_BAT, I_INV, O_V, U_V, U_MAX, U_MIN, ANZ_FLAG;
45 | long LCD_TIMER;
46 |
47 | /**********************************************************************************
48 | Deklaration der Funktionen, Unterprograme
49 | ***********************************************************************************/
50 | #pragma code
51 | void init (void); // ...eben Initialisierung :-)
52 | void Delaykurz (void); // ...war zu faul, um eine Delayroutine mit
53 | void Delaylang (void);
54 | void Delay (void);
55 | void LCDAD (void);
56 | void LCDAD1 (void);
57 | void LCDBefehl(const rom char *buffer); // Text aus Buffer auf LCD
58 | void LCDWrite (char TEMP);
59 | void FFF (void); //wird nach jedem Befehl gesendet
60 | void ADWert (void); // Spannungsmessungen
61 | void Menue (void);
62 | void Steuerung (void);
63 | void Anzeige (void);
64 | void Panel_Anz (void);
65 | void Panel_Anz2 (void);
66 | void EELese (void);
67 | void EESchreibe (void);
68 | /**********************************************************************************
69 | Main
70 | ***********************************************************************************/
71 | void main (void)
72 | {
73 | init ();
74 | REL2 = 0;
75 | FFF();
76 | Delay();
77 | ClrWdt();
78 | SPEN = 0;
79 | SPEN = 1;
80 | CREN = 0;
81 | CREN = 1;
82 | LCD_OFF = 0;
83 | LCDBefehl("page 1");
84 | Delay();
85 | FFF();
86 | ANZ_FLAG = 0;
87 | ANZ = 0;
88 | CCPR1L = 0;
89 | LCD_TIMER = 0;
90 | TAST_FLAG = 0;
91 | while (CCPR1L < 140)
92 | {
93 | CCPR1L++;
94 | Delay();
95 | }
96 | if (INSEL == 0)
97 | CCPR1L = 140; // PWM, 192 => 100 % / 41,5 kHz
98 | if (INSEL == 1)
99 | CCPR1L = 192;
100 | LCD_TIMER = 0;
101 | INV_FLAG = 1; // 1 = Inverter an
102 | while (1)
103 | {
104 | ClrWdt();
105 | if (LCD_TIMER < 700000) // Nach ca. 2 Minuten ausschalten
106 | LCD_TIMER++;
107 | if (LCD_TIMER > 699999)
108 | LCD_OFF = 1;
109 | if (ENABLE == 0)
110 | {
111 | LCD_TIMER = 0;
112 | SPEN = 0;
113 | LCD_OFF = 0; // an
114 | SPEN = 1;
115 | }
116 | ADWert();
117 | Steuerung();
118 | ANZ_FLAG++;
119 | if (ANZ_FLAG == 1500)
120 | Panel_Anz();
121 | if (ANZ_FLAG == 3000)
122 | Panel_Anz2();
123 | if (ANZ_FLAG > 8000)
124 | Anzeige();
125 | if (RCIF == 1)
126 | {
127 | TEMP1 = RCREG;
128 | if (TEMP1 == 101)
129 | {
130 | LCDBefehl("page 2");
131 | Delay();
132 | FFF();
133 | Delaykurz();
134 | Menue();
135 | }
136 | SPEN = 0;
137 | SPEN = 1;
138 | CREN = 0;
139 | CREN = 1;
140 | }
141 | }
142 | }
143 |
144 | /***********************************************************************************
145 | Unterprogramme, wie Delays, LCD, Texte, Initialisierung und der Rest...
146 | ***********************************************************************************/
147 |
148 | void Steuerung (void)
149 | {
150 |
151 | if (ANZ_FLAG == 1500)
152 | {
153 | if (U_BAT > U_MAX)
154 | {
155 | if (ANZ < 7)
156 | ANZ++;
157 | if ((REL1 == 1) && (ANZ > 6)) // Wenn Akku voll
158 | REL1 = 0; // dann aus
159 | if ((REL2 == 1) && (ANZ > 5))
160 | REL2 = 0;
161 | if ((REL3 == 1) && (ANZ > 4))
162 | REL3 = 0;
163 | if ((REL4 == 1) && (ANZ > 3))
164 | REL4 = 0;
165 | if ((REL5 == 1) && (ANZ > 2))
166 | REL5 = 0;
167 | if ((REL6 == 1) && (ANZ > 1))
168 | REL6 = 0;
169 | }
170 | if (U_BAT < U_MAX)
171 | {
172 | if (ANZ > 0)
173 | ANZ--;
174 | if ((U1 > U_BAT+10) & (ANZ < 6)) // Wenn Panelspannung > Akkuspannung
175 | REL1 = 1;
176 | if ((U2 > U_BAT+10) & (ANZ < 5))
177 | REL2 = 1;
178 | if ((U3 > U_BAT+10) & (ANZ < 4))
179 | REL3 = 1;
180 | if ((U4 > U_BAT+10) & (ANZ < 3))
181 | REL4 = 1;
182 | if ((U5 > U_BAT+10) & (ANZ < 2))
183 | REL5 = 1;
184 | if ((U6 > U_BAT+10) & (ANZ < 1))
185 | REL6 = 1;
186 | }
187 | }
188 |
189 | if (ANZ_FLAG == 2500)
190 | {
191 | if (I1 < 13) // Wenn Strom < 0,1 Ampere, dann aus
192 | REL1 = 0;
193 | if (I2 < 13)
194 | REL2 = 0;
195 | if (I3 < 13)
196 | REL3 = 0;
197 | if (I4 < 13)
198 | REL4 = 0;
199 | if (I5 < 13)
200 | REL5 = 0;
201 | if (I6 < 13)
202 | REL6 = 0;
203 | }
204 |
205 |
206 | if ((U_BAT > U_MAX)&&(ANZ_FLAG == 1000))
207 | RELAIS2 = 1;
208 |
209 | if ((U_BAT < (U_MAX - 40))&&(ANZ_FLAG == 1000))
210 | RELAIS2 = 0;
211 |
212 | if ((U_BAT < U_MIN)&&(CCPR1L > 0)&&(INSEL == 0)&&(ANZ_FLAG == 200)&&(INV_FLAG == 1))
213 | CCPR1L--;
214 |
215 | if ((U_BAT < U_MIN-5)&&(CCPR1L > 0)&&(INSEL == 1)&&(ANZ_FLAG == 200)&&(INV_FLAG == 1))
216 | CCPR1L = 0;
217 |
218 | if ((P_OUT > P_MAX)&&(INSEL == 0)&&(U_BAT > U_MIN)&&(ANZ_FLAG == 500)&&(CCPR1L > 0)&&(INV_FLAG == 1))
219 | CCPR1L--;
220 |
221 | if ((P_OUT < P_MAX)&&(INSEL == 0)&&(U_BAT > U_MIN)&&(ANZ_FLAG == 500)&&(CCPR1L < 192)&&(INV_FLAG == 1))
222 | CCPR1L++;
223 |
224 | if (INV_FLAG == 0)
225 | CCPR1L = 0; // Inverter aus
226 |
227 | if ((U_BAT > U_MIN)&&(INSEL == 0)&&(INV_FLAG == 1)&&(CCPR1L < 192)&&(UP == 0)&&(TAST_FLAG == 0))
228 | {
229 | P_MAX++;
230 | TAST_FLAG = 1;
231 | }
232 |
233 | if ((U_BAT > U_MIN)&&(INSEL == 0)&&(INV_FLAG == 1)&&(CCPR1L > 0)&&(DOWN == 0)&&(TAST_FLAG == 0))
234 | {
235 | P_MAX--;
236 | TAST_FLAG = 1;
237 | }
238 |
239 | if ((UP == 1)&&(DOWN == 1)&&(ANZ_FLAG == 100))
240 | TAST_FLAG = 0;
241 |
242 |
243 | }
244 |
245 |
246 | void Panel_Anz (void)
247 | {
248 | if (REL1 == 0)
249 | {
250 | LCDBefehl("t9.txt=");
251 | LCDWrite(34);
252 | LCDBefehl("1");
253 | LCDWrite(34);
254 | }
255 | if (REL1 == 1)
256 | {
257 | LCDBefehl("t15.txt=");
258 | LCDWrite(34);
259 | LCDBefehl("1");
260 | LCDWrite(34);
261 | }
262 | FFF();
263 | Delay();
264 |
265 | if (REL2 == 0)
266 | {
267 | LCDBefehl("t10.txt=");
268 | LCDWrite(34);
269 | LCDBefehl("2");
270 | LCDWrite(34);
271 | }
272 | if (REL2 == 1)
273 | {
274 | LCDBefehl("t16.txt=");
275 | LCDWrite(34);
276 | LCDBefehl("2");
277 | LCDWrite(34);
278 | }
279 | FFF();
280 | Delay();
281 |
282 | if (REL3 == 0)
283 | {
284 | LCDBefehl("t11.txt=");
285 | LCDWrite(34);
286 | LCDBefehl("3");
287 | LCDWrite(34);
288 | }
289 | if (REL3 == 1)
290 | {
291 | LCDBefehl("t17.txt=");
292 | LCDWrite(34);
293 | LCDBefehl("3");
294 | LCDWrite(34);
295 | }
296 | FFF();
297 | Delay();
298 | }
299 |
300 |
301 | void Panel_Anz2 (void)
302 | {
303 | if (REL4 == 0)
304 | {
305 | LCDBefehl("t12.txt=");
306 | LCDWrite(34);
307 | LCDBefehl("4");
308 | LCDWrite(34);
309 | }
310 | if (REL4 == 1)
311 | {
312 | LCDBefehl("t18.txt=");
313 | LCDWrite(34);
314 | LCDBefehl("4");
315 | LCDWrite(34);
316 | }
317 | FFF();
318 | Delay();
319 |
320 | if (REL5 == 0)
321 | {
322 | LCDBefehl("t13.txt=");
323 | LCDWrite(34);
324 | LCDBefehl("5");
325 | LCDWrite(34);
326 | }
327 | if (REL5 == 1)
328 | {
329 | LCDBefehl("t19.txt=");
330 | LCDWrite(34);
331 | LCDBefehl("5");
332 | LCDWrite(34);
333 | }
334 | FFF();
335 | Delay();
336 |
337 | if (REL6 == 0)
338 | {
339 | LCDBefehl("t14.txt=");
340 | LCDWrite(34);
341 | LCDBefehl("6");
342 | LCDWrite(34);
343 | }
344 | if (REL6 == 1)
345 | {
346 | LCDBefehl("t20.txt=");
347 | LCDWrite(34);
348 | LCDBefehl("6");
349 | LCDWrite(34);
350 | }
351 | FFF();
352 | Delay();
353 | }
354 |
355 |
356 | void Anzeige (void)
357 | {
358 | LCDBefehl("upan.txt=");
359 | LCDWrite(34);
360 | if (U1 > 10)
361 | DATA1 = U1;
362 | if (U2 > 10)
363 | DATA1 = U2;
364 | if (U3 > 10)
365 | DATA1 = U3;
366 | if (U4 > 10)
367 | DATA1 = U4;
368 | if (U5 > 10)
369 | DATA1 = U5;
370 | if (U6 > 10)
371 | DATA1 = U6;
372 | if ((U1 < 11)&&(U2 < 11)&&(U3 < 11)&&(U4 < 11)&&(U5 < 11)&&(U6 < 11))
373 | DATA1 = 0;
374 | LCDAD1();
375 | LCDWrite(34);
376 | FFF();
377 | Delay();
378 | LCDBefehl("ubat.txt=");
379 | LCDWrite(34);
380 | DATA1 = U_BAT;
381 | LCDAD1();
382 | LCDWrite(34);
383 | FFF();
384 | LCDBefehl("pin.txt=");
385 | LCDWrite(34);
386 | I_REIN = I1 + I2 + I3 + I4 + I5 + I6;
387 | P_IN = (((U_BAT/5) * (I_REIN/5))/60);
388 | if (P_IN < 4)
389 | P_IN = 0;
390 | DATA1 = P_IN;
391 | LCDAD();
392 | LCDWrite(34);
393 | FFF();
394 | Delay();
395 | LCDBefehl("pout.txt=");
396 | LCDWrite(34);
397 | P_OUT = ((U_BAT/4) * (I_INV/4))/65;
398 | if (P_OUT < 4)
399 | P_OUT = 0;
400 | DATA1 = P_OUT;
401 | LCDAD();
402 | LCDWrite(34);
403 | FFF();
404 | Delay();
405 | ANZ_FLAG = 0;
406 | }
407 |
408 |
409 | void Menue (void)
410 | {
411 | TEMP1 = RCREG;
412 | TEMP1 = 100;
413 | LCD_TIMER = 0;
414 | LCDBefehl("umin.txt=");
415 | LCDWrite(34);
416 | DATA1 = U_MIN;
417 | LCDAD1();
418 | LCDWrite(34);
419 | FFF();
420 | Delay();
421 | CREN = 0;
422 | CREN = 1;
423 | LCDBefehl("umax.txt=");
424 | LCDWrite(34);
425 | DATA1 = U_MAX;
426 | LCDAD1();
427 | LCDWrite(34);
428 | FFF();
429 | Delay();
430 | CREN = 0;
431 | CREN = 1;
432 | LCDBefehl("pmax.txt=");
433 | LCDWrite(34);
434 | DATA1 = P_MAX;
435 | LCDAD();
436 | LCDWrite(34);
437 | FFF();
438 | Delay();
439 | CREN = 0;
440 | CREN = 1;
441 | LCDBefehl("b7.txt=");
442 | LCDWrite(34);
443 | if (INSEL == 1)
444 | LCDBefehl("Island");
445 | if (INSEL == 0)
446 | LCDBefehl("Grid");
447 | LCDWrite(34);
448 | FFF();
449 | Delay();
450 | LCDBefehl("b5.txt=");
451 | LCDWrite(34);
452 | if (CCPR1L == 0)
453 | LCDBefehl("Inv.Off");
454 | if (CCPR1L > 0)
455 | LCDBefehl("Inv.On");
456 | LCDWrite(34);
457 | FFF();
458 | Delay();
459 | TEMP1 = RCREG;
460 | CREN = 0;
461 | CREN = 1;
462 | SPEN = 0;
463 | SPEN = 1;
464 | TEMP1 = 100;
465 | while ((TEMP1 < 15)||(TEMP1 > 15))
466 | {
467 | if (ENABLE == 0)
468 | {
469 | LCD_OFF = 0;
470 | LCD_TIMER = 0;
471 | Reset();
472 | }
473 | if ((TEMP1 == 100)||((TEMP1 < 15)&&(TEMP1 > 2))||(TEMP1 == 255))
474 | ClrWdt();
475 | if (RCIF == 1)
476 | TEMP1 = RCREG;
477 |
478 | if (TEMP1 == 7)
479 | {
480 | if ((U_MIN < 1024)&&(U_MIN < U_MAX-50))
481 | U_MIN = (U_MIN + 2);
482 | LCDBefehl("umin.txt=");
483 | LCDWrite(34);
484 | DATA1 = U_MIN;
485 | LCDAD1();
486 | LCDWrite(34);
487 | FFF();
488 | DATA1 = U_MIN;
489 | CREN = 0;
490 | CREN = 1;
491 | EEDATA = DATA1 & 0b0000000011111111;
492 | EEADR = 2;
493 | EESchreibe();
494 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
495 | EEADR = 1;
496 | EESchreibe();
497 | TEMP1 = 100;
498 | }
499 |
500 | if (TEMP1 == 8)
501 | {
502 | if (U_MIN > 0)
503 | U_MIN = (U_MIN - 2);
504 | LCDBefehl("umin.txt=");
505 | LCDWrite(34);
506 | DATA1 = U_MIN;
507 | LCDAD1();
508 | LCDWrite(34);
509 | FFF();
510 | DATA1 = U_MIN;
511 | CREN = 0;
512 | CREN = 1;
513 | EEDATA = DATA1 & 0b0000000011111111;
514 | EEADR = 2;
515 | EESchreibe();
516 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
517 | EEADR = 1;
518 | EESchreibe();
519 | TEMP1 = 100;
520 | }
521 |
522 | if (TEMP1 == 9)
523 | {
524 | if (U_MAX < 1024)
525 | U_MAX = (U_MAX + 2);
526 | LCDBefehl("umax.txt=");
527 | LCDWrite(34);
528 | DATA1 = U_MAX;
529 | LCDAD1();
530 | LCDWrite(34);
531 | FFF();
532 | DATA1 = U_MAX;
533 | CREN = 0;
534 | CREN = 1;
535 | EEDATA = DATA1 & 0b0000000011111111;
536 | EEADR = 4;
537 | EESchreibe();
538 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
539 | EEADR = 3;
540 | EESchreibe();
541 | TEMP1 = 100;
542 | }
543 |
544 | if (TEMP1 == 10)
545 | {
546 | if ((U_MAX > 100)&&(U_MAX > U_MIN+50))
547 | U_MAX = (U_MAX -2);;
548 | LCDBefehl("umax.txt=");
549 | LCDWrite(34);
550 | DATA1 = U_MAX;
551 | LCDAD1();
552 | LCDWrite(34);
553 | FFF();
554 | DATA1 = U_MAX;
555 | CREN = 0;
556 | CREN = 1;
557 | EEDATA = DATA1 & 0b0000000011111111;
558 | EEADR = 4;
559 | EESchreibe();
560 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
561 | EEADR = 3;
562 | EESchreibe();
563 | TEMP1 = 100;
564 | }
565 |
566 | if (TEMP1 == 11)
567 | {
568 | if (P_MAX < 200)
569 | P_MAX++;
570 | LCDBefehl("pmax.txt=");
571 | LCDWrite(34);
572 | DATA1 = P_MAX;
573 | LCDAD();
574 | LCDWrite(34);
575 | FFF();
576 | DATA1 = P_MAX;
577 | CREN = 0;
578 | CREN = 1;
579 | EEDATA = DATA1 & 0b0000000011111111;
580 | EEADR = 6;
581 | EESchreibe();
582 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
583 | EEADR = 5;
584 | EESchreibe();
585 | TEMP1 = 100;
586 | }
587 |
588 | if (TEMP1 == 12)
589 | {
590 | if (P_MAX > 10)
591 | P_MAX--;
592 | LCDBefehl("pmax.txt=");
593 | LCDWrite(34);
594 | DATA1 = P_MAX;
595 | LCDAD();
596 | LCDWrite(34);
597 | FFF();
598 | DATA1 = P_MAX;
599 | CREN = 0;
600 | CREN = 1;
601 | EEDATA = DATA1 & 0b0000000011111111;
602 | EEADR = 6;
603 | EESchreibe();
604 | EEDATA = DATA1 >> 8 & 0b0000000011111111;
605 | EEADR = 5;
606 | EESchreibe();
607 | TEMP1 = 100;
608 | }
609 |
610 | if (TEMP1 == 13)
611 | {
612 | LCDBefehl("b5.txt=");
613 | LCDWrite(34);
614 | if (CCPR1L > 0)
615 | {
616 | LCDBefehl("Inv.Off");
617 | INV_FLAG = 0;
618 | CCPR1L = 0;
619 | }
620 | else
621 | {
622 | LCDBefehl("Inv.On");
623 | INV_FLAG = 1;
624 | if (INSEL == 1)
625 | {
626 | while (CCPR1L < 192)
627 | {
628 | CCPR1L++;
629 | Delay();
630 | }
631 | }
632 | if (INSEL == 0)
633 | {
634 | while (CCPR1L < 140)
635 | {
636 | CCPR1L++;
637 | Delay();
638 | }
639 | }
640 | }
641 |
642 | LCDWrite(34);
643 | FFF();
644 | Delay();
645 | CREN = 0;
646 | CREN = 1;
647 | TEMP1 = 100;
648 | }
649 |
650 | if (TEMP1 == 14)
651 | {
652 | LCDBefehl("b7.txt=");
653 | LCDWrite(34);
654 | if (INSEL == 0)
655 | {
656 | LCDBefehl("Island");
657 | INSEL = 1;
658 | }
659 | else
660 | {
661 | LCDBefehl("Grid");
662 | INSEL = 0;
663 | }
664 | LCDWrite(34);
665 | FFF();
666 | CREN = 0;
667 | CREN = 1;
668 | EEDATA = INSEL;
669 | EEADR = 7;
670 | EESchreibe();
671 | TEMP1 = 100;
672 | }
673 |
674 | }
675 | TEMP1 = RCREG;
676 | LCDBefehl("page 1");
677 | Delay();
678 | FFF();
679 | Delaykurz();
680 | CREN = 0;
681 | CREN = 1;
682 | SPEN = 0;
683 | SPEN = 1;
684 | }
685 |
686 |
687 | void ADWert (void)
688 | {
689 | ADCON0 = 0b00001011; // AD2 an
690 | while (ADCON0bits.GO_DONE);
691 | U1 = ADRESH;
692 | U1 = (U1<<8);
693 | U1 = (U1|ADRESL);
694 |
695 | ADCON0 = 0b00001111; // AD3 an
696 | while (ADCON0bits.GO_DONE);
697 | I1 = ADRESH;
698 | I1 = (I1<<8);
699 | I1 = (I1|ADRESL);
700 |
701 | ADCON0 = 0b00010011; // AD4 an
702 | while (ADCON0bits.GO_DONE);
703 | U2 = ADRESH;
704 | U2 = (U2<<8);
705 | U2 = (U2|ADRESL);
706 |
707 | ADCON0 = 0b00010111; // AD5 an
708 | while (ADCON0bits.GO_DONE);
709 | I2 = ADRESH;
710 | I2 = (I2<<8);
711 | I2 = (I2|ADRESL);
712 |
713 | ADCON0 = 0b01010011; // AD20 an
714 | while (ADCON0bits.GO_DONE);
715 | U_BAT = ADRESH;
716 | U_BAT = (U_BAT<<8);
717 | U_BAT = (U_BAT|ADRESL);
718 |
719 | ADCON0 = 0b01010111; // AD21 an
720 | while (ADCON0bits.GO_DONE);
721 | I_INV = ADRESH;
722 | I_INV = (I_INV<<8);
723 | I_INV = (I_INV|ADRESL);
724 |
725 | ADCON0 = 0b00100111; // AD9 an
726 | while (ADCON0bits.GO_DONE);
727 | I3 = ADRESH;
728 | I3 = (I3<<8);
729 | I3 = (I3|ADRESL);
730 |
731 | ADCON0 = 0b00110011; // AD12 an
732 | while (ADCON0bits.GO_DONE);
733 | I4 = ADRESH;
734 | I4 = (I4<<8);
735 | I4 = (I4|ADRESL);
736 |
737 | ADCON0 = 0b00100011; // AD8 an
738 | while (ADCON0bits.GO_DONE);
739 | U3 = ADRESH;
740 | U3 = (U3<<8);
741 | U3 = (U3|ADRESL);
742 |
743 | ADCON0 = 0b01101111; // AD27 an
744 | while (ADCON0bits.GO_DONE);
745 | U4 = ADRESH;
746 | U4 = (U4<<8);
747 | U4 = (U4|ADRESL);
748 |
749 | ADCON0 = 0b01100111; // AD25 an
750 | while (ADCON0bits.GO_DONE);
751 | I5 = ADRESH;
752 | I5 = (I5<<8);
753 | I5 = (I5|ADRESL);
754 |
755 | ADCON0 = 0b01100011; // AD24 an
756 | while (ADCON0bits.GO_DONE);
757 | U5 = ADRESH;
758 | U5 = (U5<<8);
759 | U5 = (U5|ADRESL);
760 |
761 | ADCON0 = 0b01011111; // AD23 an
762 | while (ADCON0bits.GO_DONE);
763 | I6 = ADRESH;
764 | I6 = (I6<<8);
765 | I6 = (I6|ADRESL);
766 |
767 | ADCON0 = 0b01011011; // AD22 an
768 | while (ADCON0bits.GO_DONE);
769 | U6 = ADRESH;
770 | U6 = (U6<<8);
771 | U6 = (U6|ADRESL);
772 | }
773 |
774 |
775 | void init (void)
776 | {
777 | PORTA = 0;
778 | PORTB = 0;
779 | PORTC = 0;
780 | PORTD = 0;
781 | LATA = 0;
782 | LATB = 0;
783 | LATC = 0;
784 | LATD = 0;
785 | ANSELA = 0b00101100;
786 | ANSELB = 0b00001101;
787 | ANSELC = 0b00000000;
788 | ANSELD = 0b10111111;
789 | TRISA = 0b11101100;
790 | TRISB = 0b11101101;
791 | TRISC = 0b10001011;
792 | TRISD = 0b10111111;
793 | TRISE = 0b00000000;
794 | ADCON0 = 0b00000001; // AD0 an
795 | ADCON1 = 0b00001000; // Interne Referenz
796 | ADCON2 = 0b10100001; // Rechts justiert
797 | VREFCON0 = 0b11110000; // Interne Referenz 4,096 Volt an
798 | OSCCON = 0b01100100; // Internen Oszillator 4 MHz + 4xPLL = 32 MHz
799 | OSCTUNE = 0b01000000;
800 | INTCON = 0b11100000; // Interrupts erlauben
801 | INTCON2 = 0b00000000;
802 | Delaylang();
803 | RCSTA1 = 0b10010000;
804 | SPBRGH1 =3;
805 | SPBRG1 = 66; // 9600 Baud = 832
806 | TXSTA1= 0b10100100;
807 | BAUDCON1 = 0b00001000;
808 | WPUB = 0b00100000; // Pull Up PortB5 an
809 |
810 | CCPR1L = 0;
811 | CCP1CON = 0b00001100; // PWM Mode
812 | PR2 = 0b10111111;
813 | PIR2 = 0b00000000;
814 | T2CON = 0b00000100; // Timer2 ON, kein Pre- kein Post-counter
815 |
816 | EEADR = 1;
817 | EELese();
818 | U_MIN = EEDATA;
819 | U_MIN = U_MIN<<8;
820 | EEADR = 2;
821 | EELese();
822 | U_MIN = (U_MIN | EEDATA);
823 | if (U_MIN > 1024)
824 | U_MIN = 350;
825 |
826 | EEADR = 3;
827 | EELese();
828 | U_MAX = EEDATA;
829 | U_MAX = U_MAX<<8;
830 | EEADR = 4;
831 | EELese();
832 | U_MAX = (U_MAX | EEDATA);
833 | if (U_MAX > 1024)
834 | U_MAX = 450;
835 |
836 | EEADR = 5;
837 | EELese();
838 | P_MAX = EEDATA;
839 | P_MAX = P_MAX<<8;
840 | EEADR = 6;
841 | EELese();
842 | P_MAX = (P_MAX | EEDATA);
843 | if (P_MAX > 1024)
844 | P_MAX = 100;
845 |
846 | EEADR = 7;
847 | EELese();
848 | INSEL = EEDATA;
849 | if (INSEL > 1)
850 | INSEL = 1;
851 |
852 | }
853 |
854 |
855 | void LCDAD (void) // konvertiert DATA1 nach TEMP2 und sendet auf LCD
856 | {
857 | TEMP2 = DATA1;
858 | if (TEMP2 > 9999) // größer 999, Tausender Stellen
859 | {
860 |
861 | TEMP2 = (TEMP2 / 10000);
862 | TEMP2 = (TEMP2 + 48);
863 | LCDWrite(TEMP2);
864 | }
865 | TEMP2 = DATA1;
866 | while (TEMP2 >= 10000)
867 | TEMP2 = (TEMP2 - 10000);
868 |
869 | if (TEMP2 > 999) // größer 999, Tausender Stellen
870 | {
871 |
872 | TEMP2 = (TEMP2 / 1000);
873 | TEMP2 = (TEMP2 + 48);
874 | LCDWrite(TEMP2);
875 | }
876 | // else LCDBefehl("0");
877 | TEMP2 = DATA1;
878 | while (TEMP2 >= 1000)
879 | TEMP2 = (TEMP2 - 1000);
880 |
881 | if (TEMP2 > 99) // größer 99, Hunderter Stellen
882 | {
883 |
884 | TEMP2 = (TEMP2 / 100);
885 | TEMP2 = (TEMP2 + 48);
886 | LCDWrite(TEMP2);
887 | }
888 | // else LCDBefehl("0");
889 |
890 | TEMP2 = DATA1;
891 | while (TEMP2 >= 100)
892 | TEMP2 = (TEMP2 - 100);
893 |
894 | if (TEMP2 > 9) // Größer 9, Zehner Stellen
895 | {
896 | TEMP2 = (TEMP2 / 10);
897 | TEMP2 = (TEMP2 + 48);
898 | LCDWrite(TEMP2);
899 | }
900 | else LCDBefehl("0");
901 |
902 | TEMP2 = DATA1;
903 | while (TEMP2 >= 100)
904 | TEMP2 = (TEMP2 -100);
905 | while (TEMP2 >= 10)
906 | TEMP2 = (TEMP2 -10);
907 | TEMP2 = (TEMP2 + 48);
908 | LCDWrite (TEMP2);
909 | }
910 |
911 |
912 | void LCDAD1 (void) // konvertiert DATA1 nach TEMP2 und sendet auf LCD mit Komma
913 | {
914 | DATA1 = (DATA1 * 0.645);
915 | TEMP2 = DATA1;
916 | while (TEMP2 >= 1000)
917 | TEMP2 = (TEMP2 - 1000);
918 |
919 | if (TEMP2 > 99) // größer 99, Hunderter Stellen
920 | {
921 |
922 | TEMP2 = (TEMP2 / 100);
923 | TEMP2 = (TEMP2 + 48);
924 | LCDWrite(TEMP2);
925 | }
926 | else LCDBefehl("0");
927 | TEMP2 = DATA1;
928 | while (TEMP2 >= 100)
929 | TEMP2 = (TEMP2 - 100);
930 |
931 | if (TEMP2 > 9) // Größer 9, Zehner Stellen
932 | {
933 | TEMP2 = (TEMP2 / 10);
934 | TEMP2 = (TEMP2 + 48);
935 | LCDWrite(TEMP2);
936 | }
937 | else LCDBefehl("0");
938 | LCDBefehl(",");
939 | TEMP2 = DATA1;
940 | while (TEMP2 >= 100)
941 | TEMP2 = (TEMP2 -100);
942 | while (TEMP2 >= 10)
943 | TEMP2 = (TEMP2 -10);
944 | TEMP2 = (TEMP2 + 48);
945 | LCDWrite (TEMP2);
946 | }
947 |
948 |
949 | void EELese (void)
950 | {
951 | EECON1bits.EEPGD = 0;
952 | EECON1bits.CFGS = 0;
953 | EECON1bits.RD = 1; // EEDATA = eingelesener Wert
954 | }
955 |
956 |
957 | void EESchreibe (void)
958 | {
959 | EECON1bits.EEPGD = 0;
960 | EECON1bits.CFGS = 0;
961 | EECON1bits.WREN = 1;
962 | INTCONbits.GIE = 0;
963 | EECON2 = 0b01010101;
964 | EECON2 = 0b10101010;
965 | EECON1bits.WR = 1;
966 | while (EECON1bits.WR == 1); // Warten, bis Schreiben fertig
967 | INTCONbits.GIE = 1;
968 | EECON1bits.WREN = 0;
969 | }
970 |
971 |
972 | void LCDWrite (char TEMP)
973 | {
974 | TXREG = TEMP; //Wert in TXREG rein und raus
975 | Delay();
976 | }
977 |
978 |
979 | void LCDBefehl (const rom char *buffer)
980 | {
981 | while (*buffer)
982 | {
983 | LCDWrite(*buffer);
984 | *buffer++;
985 | }
986 | }
987 |
988 |
989 | void FFF (void)
990 | {
991 | Delay();
992 | TXREG = 255;
993 | Delay();
994 | TXREG = 255;
995 | Delay();
996 | TXREG = 255;
997 | Delay();
998 | }
999 |
1000 |
1001 | void Delaykurz (void)
1002 | {
1003 | unsigned int i;
1004 | for (i = 0; i < 12000; i++);
1005 | }
1006 |
1007 |
1008 | void Delaylang (void)
1009 | {
1010 | unsigned int i,a;
1011 | for (i = 0; i < 48000; i++)
1012 | ClrWdt();
1013 | for (a = 0; a < 10; a++);
1014 | }
1015 |
1016 |
1017 | void Delay(void)
1018 | {
1019 | int i;
1020 | {
1021 | for(i=0;i<425;i++)
1022 | {
1023 | Nop();
1024 | }
1025 | }
1026 | return;
1027 | }
