TLS1.2/TLS1.1 ist schon wieder aus
Gast #6596831
Es scheint jetzt hängt auch noch Cloudflare dazwischen?
Schon etwas beunruhigend, wie da fast das ganze Internet mittlerweile
dran zu hängen scheint...
Und in der Datenschutzerklärung scheint davon auch nichts erwähnt zu
werden.
Gast #6596861
SSL connection using TLSv1.2
 SSL certificate verify ok.
*   Trying 168.119.227.254...
* TCP_NODELAY set
* Connected to www.mikrocontroller.net (168.119.227.254) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection:
ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.2 (OUT), TLS header, Certificate Status (22):
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
*  subject: CN=www.mikrocontroller.net
*  start date: Jan  9 16:08:09 2021 GMT
*  expire date: Apr  9 16:08:09 2021 GMT
*  subjectAltName: host "www.mikrocontroller.net" matched cert's
*  issuer: C=US; O=Let's Encrypt; CN=R3
*  SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after
upgrade: len=0
* Using Stream ID: 1 (easy handle 0x127de80)
> GET /topic/513561 HTTP/1.1
Gast #6596874
* ALPN, offering h2
*   CAfile: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* CONNECT phase completed!
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
*  subject: C=US; ST=California; L=San Francisco; O=Cloudflare, Inc.; CN=sni.cloudflaressl.com
*  start date: Feb 21 00:00:00 2021 GMT
*  expire date: Feb 20 23:59:59 2022 GMT
*  subjectAltName: host "www.mikrocontroller.net" matched cert's "*.mikrocontroller.net"
23
*  issuer: C=US; O=Cloudflare, Inc.; CN=Cloudflare Inc ECC CA-3
24
25
26
27
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
28
* Using Stream ID: 1 (easy handle 0x7fffd0f30f50)
Gast #6596908
TLS 1.1 gilt als unsicher und sollte nicht mehr verwendet werden. Und da
das dann die Sicherheit aller Nutzer schwächt ist das eigentlich gar
nicht schlecht dass das nicht geht. Viele Browser unterstützen das schon
gar nicht mehr oder werden es bald entfernen
Und auch TLS 1.2... eigentlich sollte jeder hinreichend moderne Browser
TLS1.3 hinbekommen (also seit 2018 können Firefox und Chrome +
Chrome-Derivate das), daher ist interessant wie dir das überhaupt
aufgefallen ist...
Gast #6596939
@Einstein:
Deinen Klugschiss kannst du fuer dich behalten.
Deine als so sicher angepriesenen Browser werden ja wohl hoffentlich
mit den besten Verfahren anfangen.
> $openssl ciphers -v | awk '{print $2}' | sort | uniq
> SSLv3
> TLSv1
> TLSv1.2
TLSv1.2 ist bei mir an. Und es tut sich trotzdem nichts.
Der Browser baut die Verbindung auf, und bleibt dann bei
4/5 geladenen Seitenelementen haengen.
Ursaechlich wohl bei einer Verbindung zu 151.101.114.109
Fastly/FFM.
Gast #6596984
Scheint diesmal eine andere Ursache zu haben (bei mir waren es vorher
die fehlenden CBC-Modi - Browser ging nicht, openssl ging).  Laut
SSLLabs werden die jetzt angeboten, aber trotzdem bekomme ich nur einen
lapidaren Handshake-Fehler:
# openssl s_client -connect www.mikrocontroller.net:443
CONNECTED(00000003)
4156778760:error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure:s23_clnt.c:757:
    (server sendet nur 7 bytes: fatal handshake_failure, sonst nichts)
    (ohne handshake nur noch dummy daten)
# openssl version
OpenSSL 1.0.1t  3 May 2016
Pfuscht cloudflare evtl dazwischen?
#6596995
Es hängt davon ab, welche Ciphers der Client bei 1.0/1.1 mag.
In 1.0/1.1 bietet der Server nur ECDHE_ECDSA_WITH_AES_128/256_CBC_SHA
an. Wer das bei 1.0/1.1 nicht verdaut, sondern z.B. auf die älteren
RSA/DHE Varianten besteht, der hat Pech.
Gast #6596999
Update: zusätzlich "-servername www.mikrocontroller.net" und dann klappt
es - bin mir aber ziemlich sicher, dass der Browser SNI kann, der
bekommt trotzdem keine Verbindung.
Gast #6597012
an.
Jau, das wird es sein - CBC wird exklusiv nur bei Verfahren mit
Elliptischen Kurven angeboten, die mein Browser nicht kann.
Schon verrückt: Clients die EC können, können auch GCM und brauchen kein
CBC; die, die kein GCM können, können meist auch kein EC.
Gast #6597024
Tipp: die HTTP -> HTTPS redirection entfernen und den Inhalt einfach
wieder in beiden Varianten anbieten!
Da Google&Co inzw eh nur die HTTPS-Variante verlinken und bei den
modernen Browsern HTTPS das default-Protokoll ist, landet der normale
Traffic eh auf HTTPS - nur Leute wie ich, die explizit HTTP auswählen,
landen auf der unverschlüsselten Seite.
Gast #6597045
Ach du Heiland, hier merkt man echt gut, was für Dinosaurier hier
unterwegs sind. Spiegelt die Digitalisierungsggedanken in der Politik
sehr gut wieder.
Gast #6597055
Ich frage mich noch, unter welchen Umständen kommt man über Cloudflare,
und unter welchen geht's direkt?
@pong Scheint ja direkt drauf gekommen zu sein, während es bei mir über
Cloudflare ging.
Gast #6597072
> ssl3 wird nicht akzeptiert.  -tls1, -tls1_2
Das hatte ich ausprobiert, daran liegt es nicht:
# openssl s_client -connect www.mikrocontroller.net:443 -tls1
CONNECTED(00000003)
4156778760:error:14094410:SSL routines:SSL3_READ_BYTES:sslv3 alert handshake failure:s3_pkt.c:1315:SSL alert number 40
4156778760:error:1409E0E5:SSL routines:SSL3_WRITE_BYTES:ssl handshake failure:s3_pkt.c:637:
# openssl s_client -connect www.mikrocontroller.net:443 -tls1_2
CONNECTED(00000003)
4156778760:error:1408F10B:SSL routines:SSL3_GET_RECORD:wrong version number:s3_pkt.c:348:
Was ich allerdings festgestellt habe: ein openssl s_client-connect nach
www.mikrocontroller.net braucht zusätzlich ein "-servername
www.mikronctroller.net".  Ein connect nach mikrocontroller.net (ohne
www.) geht auch ohne.
Gast #6597078
Ah, mal getestet: mikrocontroller.net geht direkt (und braucht kein
SNI), schickt aber nur einen 301 nach https://www.mikrocontroller/xxx
zurück, der dann über Cloudflare geht (und SNI braucht).
Gast #6597124
> Cloudflare ging.
Kann ich dir nicht sagen,
mglw. kannst du dir etwas herauslesen.
Verwendet wird noch OpenSSL 1.1.0
$openssl s_client -showcerts -connect mikrocontroller.net:443
CONNECTED(00000003)
depth=2 O = Digital Signature Trust Co., CN = DST Root CA X3
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = www.mikrocontroller.net
verify return:1
Certificate chain
 0 s:/CN=www.mikrocontroller.net
   i:/C=US/O=Let's Encrypt/CN=R3
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
 1 s:/C=US/O=Let's Encrypt/CN=R3
   i:/O=Digital Signature Trust Co./CN=DST Root CA X3
Server certificate
subject=/CN=www.mikrocontroller.net
issuer=/C=US/O=Let's Encrypt/CN=R3
No client certificate CA names sent
Peer signing digest: SHA256
Server Temp Key: X25519, 253 bits
SSL handshake has read 3158 bytes and written 269 bytes
Verification: OK
New, TLSv1.2, Cipher is ECDHE-RSA-AES128-GCM-SHA256
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
 usw.
Gast #6597178
> Cloudflare ging.
der genaue Ablauf ist mir noch nicht klar,
Namensauflösung?!
zitat:
DNS Certificate Authority Authorization (CAA)
Utilizing a DNS resource record lets domain owners decide which CAs are
allowed to issue certificates for a given domain. If a CAA record
exists, only the CAs listed in that record can issue the host’s
certificate.
https://protonmail.com/blog/tls-ssl-certificate/
$dig mikrocontroller.net type257
; <<>> DiG 9.10.3-P4-Debian <<>> mikrocontroller.net type257
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56959
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;mikrocontroller.net.           IN      CAA
;; AUTHORITY SECTION:
mikrocontroller.net.    10800   IN      SOA     ns1.first-ns.de.
dns.hetzner.com. 2021020403 14400 1800 604800 86400
;; Query time: 238 msec
;; SERVER: 91.239.100.100#53(91.239.100.100)
;; WHEN: Mon Feb 22 16:12:06 CET 2021
;; MSG SIZE  rcvd: 114
Nimm ggf. testweise andere Server in die resolv.conf auf,
z.B. censurfridns.dk,freedns
 mglw. kommts dann von anderer Stelle? ;)
Gast #6597195
Ich hab's doch bereits geschrieben:
  "mikrocontroller.net" geht direkt nach Hetzner,
  "www.mikrocontroller.net" geht über CloudFlare.
DNS hat entsprechend unterschiedliche Adress-Records:
  mikrocontroller.net.    197 IN A 168.119.227.254
vs
  www.mikrocontroller.net. 12 IN A 172.67.70.44
  www.mikrocontroller.net. 12 IN A 104.26.12.250
  www.mikrocontroller.net. 12 IN A 104.26.13.250
Gast #6597230
> Weil, jetzt geht es wieder.
Nachtrag: Natuerlich nicht von alleine.
Als kleiner Wuergaround gibt mein DNS fuer www... die alte
Adresse zurueck.
Mal guggn wie lang das haelt.
Gast #6597240
well www, censurfridns schickt mich zu 168.119.227.254
$dig @91.239.100.100 www.mikrocontroller.net
; <<>> DiG 9.10.3-P4-Debian <<>> @91.239.100.100 www.mikrocontroller.net
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 45450
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 3, ADDITIONAL: 4
;www.mikrocontroller.net.       IN      A
;; ANSWER SECTION:
www.mikrocontroller.net. 10532  IN      A       168.119.227.254
mikrocontroller.net.    84486   IN      NS      robotns3.second-ns.com.
mikrocontroller.net.    84486   IN      NS      robotns2.second-ns.de.
mikrocontroller.net.    84486   IN      NS      ns1.first-ns.de.
;; ADDITIONAL SECTION:
robotns2.second-ns.de.  58684   IN      A       213.133.105.6
robotns3.second-ns.com. 4349    IN      A       193.47.99.3
robotns3.second-ns.com. 172352  IN      AAAA    2001:67c:192c::add:a3
;; Query time: 250 msec
;; WHEN: Mon Feb 22 17:15:02 CET 2021
;; MSG SIZE  rcvd: 226
Gast #6597374
&#55357;&#56359; DPA &#55357;&#56359; schrieb:
> Ich vermute, dass da einfach noch die alte Adresse gecached ist.
   Domain Name: MIKROCONTROLLER.NET
   Registry Domain ID: 26384769_DOMAIN_NET-VRSN
   Registrar WHOIS Server: whois.your-server.de
   Registrar URL: http://www.hetzner.com
*  Updated Date: 2021-02-21T18:49:55Z *
   Creation Date: 2000-05-04T22:02:31Z
   Registry Expiry Date: 2021-05-04T22:02:31Z
   Registrar: Hetzner Online GmbH
   Registrar IANA ID: 828
   Registrar Abuse Contact Email: abuse@hetzner.com
   Registrar Abuse Contact Phone: +49 9831 5050
   Domain Status: ok https://icann.org/epp#ok
*  Name Server: CRAIG.NS.CLOUDFLARE.COM *
*  Name Server: LILITH.NS.CLOUDFLARE.COM *
   DNSSEC: unsigned
   URL of the ICANN Whois Inaccuracy Complaint Form:
Gast #6603654
Ich habe das Gefühl, dass das Forum um einiges unzuverlässiger geworden
ist, seit es Cloudflare nutzt. Immer wieder sehe ich z.B. "504 Gateway
time-out" Fehler...
#6603692
Es gab auch vorher gelegentliche Serverausfälle. Und den Server gibts ja
wohl immer noch, Cloudflare ist nur zwischengeschaltet. Wenn dann wie
vorhin der Server ausfällt, gibts nur eine andere Fehleranzeige, hübsch
grafisch von Cloudflare statt lakonischer Nummer.
Man kann wohl davon ausgehen, dass Cloudflare recht zuverlässig
arbeitet. Und dass du es ziemlich schnell merkst, wenn nicht, denn dann
kriegt das WWW insgesamt mehr Löcher als ein Schweizer Käse.
Beitrag #6603738 wurde von einem Moderator gelöscht.
Gast #6603740
Mmh.
https://support.cloudflare.com/hc/de/articles/205177068-Wie-funktioniert-Cloudflare-
was man schnell merkt ist das die meisten freien anonproxies erstmal
nicht mehr funktionieren, php-proxy, glype etc.
klasse, prompt :(
504 Gateway Time-out
nginx/1.19.5
@dpa
/etc/hosts
168.119.227.254 www.mikrocontroller.net
ändert aber an der Sache nichts.
der 91.239.100.100 anycast.censurfridns.dk.
hat drei Tage gebraucht, jetzt zeigt er auch auf cloudflares DNS
Gast #6604227
Ein gataway timeout ist hier aber ein Spezialfall. Webbrowser haben oft
recht lange timeouts, ein zwei Minuten liegen da schon drin. Bei
Cloudflare bekomme ich den timeout viel schneller. Vermutlich zu
schnell. Eventuell wäre die Seite ja noch gekomnen, wenn CF nicht
aufgegeben hätte?
#6604240
So speziell ist der 504 nicht. Den kann man beispielsweise auch von
Webservern kriegen, die Probleme mit ihrem fast-cgi Backend auf der
gleichen Kiste haben.
Klar, es kann sein, dass Cloudflare früher schlapp macht. Das heisst
aber nicht zwangsläufig, dass ein längeres Timeout sinnvoller sei. Sowas
kommt ja nicht von garnix
