ESP32 GPIO 1V@LOW
OP #6638212
ich habe mal wieder ein Streit mit einem ESP32. Der ESP liegt hier nackt
in einem Brennermodul.
Mit diesem Code hier (Auszug)
#ifndef MCPWM_H // Header wrapper
#define MCPWM_H // Header wrapper
  #define GPIO_PWM0A_OUT  5
  #define GPIO_INA1_OUT   18
  #define GPIO_INA2_OUT   19
  #define GPIO_FAULT0_IN  17
  #include "driver/mcpwm.h"
  #include "soc/mcpwm_reg.h"
  #include "soc/mcpwm_struct.h"
  //PWM initialisieren
  void pwm_init();
  //Drive the motor
  void brushed_motor_forward(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num , float duty_cycle);
  void brushed_motor_backward(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num , float duty_cycle);
  void brushed_motor_coast(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num);
  void brushed_motor_hard_stop(mcpwm_unit_t mcpwm_num, mcpwm_timer_t timer_num);
#endif // MCPWM_H // Header wrapper
#include "esp_log.h"
#include <pwm.h>
#define GPIO_OUTPUT_PIN_SEL  ((1ULL<<GPIO_INA1_OUT) | (1ULL<<GPIO_INA2_OUT))
static const char *TAG = "mcpwm";
void gpio_initialize() {
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, GPIO_PWM0A_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0B, GPIO_PWM0B_OUT);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_0, GPIO_FAULT0_IN);
    mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM_FAULT_1, GPIO_FAULT1_IN);
    gpio_config_t io_conf;
    //disable interrupt
    io_conf.intr_type = GPIO_PIN_INTR_DISABLE;
23
    //set as output mode
24
    io_conf.mode = GPIO_MODE_OUTPUT;
25
    //bit mask of the pins that you want to set,e.g.GPIO18/19
26
    io_conf.pin_bit_mask = GPIO_OUTPUT_PIN_SEL  ;
27
    //disable pull-down mode
28
    io_conf.pull_down_en = 1;
29
    //disable pull-up mode
30
    io_conf.pull_up_en = 0;
31
    //configure GPIO with the given settings
32
    gpio_config(&io_conf);
33
34
Messe ich 0,9V an GPIO18, was natürlich nicht für ein LOW reicht.
Ich habe keine Idee wer/was das macht. Kann das mit dem PWM
zusammenhängen?
Schaltungsproblem ist ausgeschlossen. Mit Code hier liegen am GPIO18
NULL Volt an:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <driver/gpio.h>
void app_main() {
  //disable interrupt
23
24
25
26
27
28
29
30
31
32
