Projekte & Code
Thread
IR Arduino Remote Receiver für TSOP7000 und Beo4
Moin.
Hatte lange gegoogeln aber nichts wirklich fertiges gefunden.
Einzig ein Hinweis auf die Adafruit IR-Raw Lib/Code brachte dann den
Erfolg:
https://learn.adafruit.com/ir-sensor/reading-ir-commands
https://github.com/adafruit/Raw-IR-decoder-for-Arduino
https://github.com/adafruit/Adafruit_Learning_System_Guides/tree/main/IR_Sensor/Arduino
Mit IR-Raw den Code als C Array ausgeben lassen.
1 /* Raw IR decoder sketch!
3 This sketch/program uses the Arduno and a PNA4602 to
4 decode IR received. This can be used to make a IR receiver
5 (by looking for a particular code)
6 or transmitter (by pulsing an IR LED at ~38KHz for the
7 durations detected
9 Code is public domain, check out www.ladyada.net and adafruit.com
10 for more tutorials!
11 */
13 // We need to use the 'raw' pin reading methods
14 // because timing is very important here and the digitalRead()
15 // procedure is slower!
16 //uint8_t IRpin = 2;
17 // Digital pin #2 is the same as Pin D2 see
18 // http://arduino.cc/en/Hacking/PinMapping168 for the 'raw' pin mapping
19 #define IRpin_PIN PIND
20 #define IRpin 2
22 // the maximum pulse we'll listen for - 65 milliseconds is a long time
23 #define MAXPULSE 65000
24
25 // what our timing resolution should be, larger is better
26 // as its more 'precise' - but too large and you wont get
27 // accurate timing
28 #define RESOLUTION 20
29
30 // we will store up to 100 pulse pairs (this is -a lot-)
31 uint16_t pulses [ 100 ][ 2 ]; // pair is high and low pulse
32 uint8_t currentpulse = 0 ; // index for pulses we're storing
33
34 void setup ( void ) {
35 Serial . begin ( 115200 );
36 Serial . println ( "Ready to decode IR!" );
37 }
38
39 void loop ( void ) {
40 uint16_t highpulse , lowpulse ; // temporary storage timing
41 highpulse = lowpulse = 0 ; // start out with no pulse length
42
43
44 // while (digitalRead(IRpin)) { // this is too slow!
45 while ( IRpin_PIN & ( 1 << IRpin )) {
46 // pin is still HIGH
47
48 // count off another few microseconds
49 highpulse ++ ;
50 delayMicroseconds ( RESOLUTION );
51
52 // If the pulse is too long, we 'timed out' - either nothing
53 // was received or the code is finished, so print what
54 // we've grabbed so far, and then reset
55 if (( highpulse >= MAXPULSE ) && ( currentpulse != 0 )) {
56 printpulses ();
57 currentpulse = 0 ;
58 return ;
59 }
60 }
61 // we didn't time out so lets stash the reading
62 pulses [ currentpulse ][ 0 ] = highpulse ;
63
64 // same as above
65 while ( ! ( IRpin_PIN & _BV ( IRpin ))) {
66 // pin is still LOW
67 lowpulse ++ ;
68 delayMicroseconds ( RESOLUTION );
69 if (( lowpulse >= MAXPULSE ) && ( currentpulse != 0 )) {
70 printpulses ();
71 currentpulse = 0 ;
72 return ;
73 }
74 }
75 pulses [ currentpulse ][ 1 ] = lowpulse ;
76
77 // we read one high-low pulse successfully, continue!
78 currentpulse ++ ;
79 }
80
81 void printpulses ( void ) {
82 Serial . println ( " \n\r\n\r Received: \n\r OFF \t ON" );
83 for ( uint8_t i = 0 ; i < currentpulse ; i ++ ) {
84 Serial . print ( pulses [ i ][ 0 ] * RESOLUTION , DEC );
85 Serial . print ( " usec, " );
86 Serial . print ( pulses [ i ][ 1 ] * RESOLUTION , DEC );
87 Serial . println ( " usec" );
88 }
89
90 // print it in a 'array' format
91 Serial . println ( "int IRsignal[] = {" );
92 Serial . println ( "// ON, OFF (in 10's of microseconds)" );
93 for ( uint8_t i = 0 ; i < currentpulse - 1 ; i ++ ) {
94 Serial . print ( " \t " ); // tab
95 Serial . print ( pulses [ i ][ 1 ] * RESOLUTION / 10 , DEC );
96 Serial . print ( ", " );
97 Serial . print ( pulses [ i + 1 ][ 0 ] * RESOLUTION / 10 , DEC );
98 Serial . println ( "," );
99 }
100 Serial . print ( " \t " ); // tab
101 Serial . print ( pulses [ currentpulse - 1 ][ 1 ] * RESOLUTION / 10 , DEC );
102 Serial . print ( ", 0};" );
103 }
Diesen in ircommander.h erfassen.
1 /******************* our codes ************/
3 int Beo4_TV_0 [] = {
4 // ON, OFF (in 10's of microseconds)
5 22 , 298 ,
6 24 , 298 ,
7 22 , 1582 ,
8 24 , 296 ,
9 24 , 618 ,
10 22 , 620 ,
11 24 , 618 ,
12 22 , 620 ,
13 24 , 618 ,
14 22 , 620 ,
15 22 , 618 ,
16 22 , 620 ,
17 24 , 618 ,
18 22 , 620 ,
19 24 , 618 ,
20 22 , 620 ,
21 24 , 618 ,
22 22 , 620 ,
23 24 , 618 ,
24 22 , 620 ,
25 22 , 1260 ,
26 24 , 0 };
27
28 int Beo4_TV_1 [] = {
29 // ON, OFF (in 10's of microseconds)
30 24 , 296 ,
31 22 , 298 ,
32 24 , 1582 ,
33 22 , 298 ,
34 22 , 620 ,
35 24 , 618 ,
36 22 , 620 ,
37 24 , 618 ,
38 22 , 620 ,
39 22 , 618 ,
40 24 , 618 ,
41 24 , 618 ,
42 22 , 620 ,
43 24 , 618 ,
44 22 , 620 ,
45 24 , 618 ,
46 22 , 620 ,
47 22 , 620 ,
48 22 , 618 ,
49 24 , 940 ,
50 22 , 1262 ,
51 22 , 0 };
52
53 int Beo4_TV_2 [] = {
54 // ON, OFF (in 10's of microseconds)
55 24 , 298 ,
56 22 , 298 ,
57 24 , 1580 ,
58 24 , 298 ,
59 22 , 620 ,
60 22 , 620 ,
61 20 , 620 ,
62 24 , 618 ,
63 22 , 620 ,
64 24 , 618 ,
65 22 , 620 ,
66 24 , 618 ,
67 22 , 620 ,
68 22 , 618 ,
69 24 , 618 ,
70 24 , 618 ,
71 22 , 620 ,
72 24 , 618 ,
73 22 , 940 ,
74 24 , 298 ,
75 22 , 1260 ,
76 24 , 0 };
77
78 int Beo4_TV_3 [] = {
79 // ON, OFF (in 10's of microseconds)
80 24 , 296 ,
81 22 , 298 ,
82 24 , 1582 ,
83 22 , 298 ,
84 22 , 620 ,
85 24 , 618 ,
86 22 , 620 ,
87 24 , 618 ,
88 22 , 620 ,
89 22 , 620 ,
90 20 , 620 ,
91 24 , 618 ,
92 22 , 620 ,
93 24 , 618 ,
94 22 , 620 ,
95 24 , 618 ,
96 22 , 620 ,
97 22 , 618 ,
98 24 , 940 ,
99 22 , 620 ,
100 22 , 1260 ,
101 24 , 0 };
102
103 int Beo4_TV_4 [] = {
104 // ON, OFF (in 10's of microseconds)
105 24 , 298 ,
106 22 , 298 ,
107 24 , 1580 ,
108 24 , 298 ,
109 22 , 620 ,
110 22 , 620 ,
111 20 , 620 ,
112 24 , 618 ,
113 22 , 620 ,
114 24 , 618 ,
115 22 , 620 ,
116 24 , 618 ,
117 22 , 618 ,
118 24 , 618 ,
119 24 , 618 ,
120 24 , 618 ,
121 22 , 620 ,
122 24 , 938 ,
123 24 , 298 ,
124 22 , 618 ,
125 24 , 1260 ,
126 24 , 0 };
127
128 int Beo4_TV_5 [] = {
129 // ON, OFF (in 10's of microseconds)
130 22 , 300 ,
131 22 , 298 ,
132 22 , 1582 ,
133 24 , 296 ,
134 24 , 618 ,
135 24 , 618 ,
136 24 , 618 ,
137 22 , 620 ,
138 24 , 618 ,
139 22 , 620 ,
140 22 , 620 ,
141 22 , 620 ,
142 22 , 618 ,
143 22 , 620 ,
144 24 , 618 ,
145 22 , 620 ,
146 24 , 618 ,
147 22 , 940 ,
148 24 , 298 ,
149 22 , 940 ,
150 22 , 1262 ,
151 22 , 0 };
152
153 int Beo4_TV_6 [] = {
154 // ON, OFF (in 10's of microseconds)
155 22 , 298 ,
156 24 , 296 ,
157 22 , 1584 ,
158 22 , 298 ,
159 24 , 618 ,
160 22 , 620 ,
161 22 , 618 ,
162 24 , 618 ,
163 24 , 618 ,
164 22 , 620 ,
165 24 , 618 ,
166 22 , 620 ,
167 24 , 618 ,
168 22 , 620 ,
169 22 , 620 ,
170 20 , 620 ,
171 24 , 618 ,
172 22 , 940 ,
173 24 , 618 ,
174 24 , 298 ,
175 22 , 1262 ,
176 22 , 0 };
177
178 int Beo4_TV_7 [] = {
179 // ON, OFF (in 10's of microseconds)
180 24 , 298 ,
181 20 , 300 ,
182 24 , 1580 ,
183 24 , 298 ,
184 22 , 618 ,
185 24 , 618 ,
186 22 , 620 ,
187 24 , 618 ,
188 22 , 620 ,
189 24 , 618 ,
190 22 , 620 ,
191 22 , 620 ,
192 20 , 620 ,
193 24 , 618 ,
194 22 , 620 ,
195 24 , 618 ,
196 22 , 620 ,
197 24 , 938 ,
198 22 , 620 ,
199 24 , 618 ,
200 22 , 1262 ,
201 22 , 0 };
202
203 int Beo4_TV_8 [] = {
204 // ON, OFF (in 10's of microseconds)
205 24 , 296 ,
206 22 , 300 ,
207 24 , 1580 ,
208 24 , 298 ,
209 22 , 618 ,
210 24 , 618 ,
211 22 , 620 ,
212 24 , 618 ,
213 22 , 620 ,
214 24 , 618 ,
215 22 , 618 ,
216 24 , 618 ,
217 22 , 620 ,
218 24 , 618 ,
219 22 , 620 ,
220 24 , 618 ,
221 22 , 940 ,
222 24 , 298 ,
223 22 , 620 ,
224 20 , 620 ,
225 24 , 1260 ,
226 24 , 0 };
227
228 int Beo4_TV_9 [] = {
229 // ON, OFF (in 10's of microseconds)
230 22 , 300 ,
231 22 , 298 ,
232 22 , 1582 ,
233 24 , 298 ,
234 24 , 618 ,
235 22 , 620 ,
236 22 , 618 ,
237 24 , 618 ,
238 24 , 618 ,
239 22 , 620 ,
240 24 , 618 ,
241 22 , 620 ,
242 22 , 618 ,
243 24 , 618 ,
244 24 , 618 ,
245 22 , 620 ,
246 24 , 938 ,
247 24 , 298 ,
248 22 , 620 ,
249 24 , 938 ,
250 22 , 1262 ,
251 22 , 0 };
Beispielverarbeitung siehe: IR_Commander.ino.
1 /* Raw IR commander
4 decode IR received. It then attempts to match it to a previously
5 recorded IR signal. Limor Fried, Adafruit Industries
7 MIT License, please attribute
8 check out learn.adafruit.com for more tutorials!
10 2021-06-25 - P. Sieg: used with TSOP7000 ir receiver to decode Beo4 B&O ir remote control
11 */
20 #define IRpin 2
24 #define NUMPULSES 50
25
26 // what our timing resolution should be, larger is better
27 // as its more 'precise' - but too large and you wont get
28 // accurate timing
29 #define RESOLUTION 20
30
31 // What percent we will allow in variation to match the same code
32 #define FUZZINESS 20
33
34 // we will store up to 100 pulse pairs (this is -a lot-)
35 uint16_t pulses [ NUMPULSES ][ 2 ]; // pair is high and low pulse
36 uint8_t currentpulse = 0 ; // index for pulses we're storing
37
38 #include "ircommander.h"
39
40 void setup ( void ) {
41 Serial . begin ( 115200 );
42 Serial . println ( "Ready to decode IR!" );
43 }
44
45 void loop ( void ) {
46 int numberpulses ;
47
48 numberpulses = listenForIR ();
49 #ifdef DEBUG
50 Serial . print ( "Heard " );
51 Serial . print ( numberpulses );
52 Serial . println ( "-pulse long IR signal" );
53 #endif
54 if ( IRcompare ( numberpulses , Beo4_TV_0 , sizeof ( Beo4_TV_0 ) / 4 )) {
55 Serial . println ( "Beo4_TV_0" );
56 }
57 if ( IRcompare ( numberpulses , Beo4_TV_1 , sizeof ( Beo4_TV_1 ) / 4 )) {
58 Serial . println ( "Beo4_TV_1" );
59 }
60 if ( IRcompare ( numberpulses , Beo4_TV_2 , sizeof ( Beo4_TV_2 ) / 4 )) {
61 Serial . println ( "Beo4_TV_2" );
62 }
63 if ( IRcompare ( numberpulses , Beo4_TV_3 , sizeof ( Beo4_TV_3 ) / 4 )) {
64 Serial . println ( "Beo4_TV_3" );
65 }
66 if ( IRcompare ( numberpulses , Beo4_TV_4 , sizeof ( Beo4_TV_4 ) / 4 )) {
67 Serial . println ( "Beo4_TV_4" );
68 }
69 if ( IRcompare ( numberpulses , Beo4_TV_5 , sizeof ( Beo4_TV_5 ) / 4 )) {
70 Serial . println ( "Beo4_TV_5" );
71 }
72 if ( IRcompare ( numberpulses , Beo4_TV_6 , sizeof ( Beo4_TV_6 ) / 4 )) {
73 Serial . println ( "Beo4_TV_6" );
74 }
75 if ( IRcompare ( numberpulses , Beo4_TV_7 , sizeof ( Beo4_TV_7 ) / 4 )) {
76 Serial . println ( "Beo4_TV_7" );
77 }
78 if ( IRcompare ( numberpulses , Beo4_TV_8 , sizeof ( Beo4_TV_8 ) / 4 )) {
79 Serial . println ( "Beo4_TV_8" );
80 }
81 if ( IRcompare ( numberpulses , Beo4_TV_9 , sizeof ( Beo4_TV_9 ) / 4 )) {
82 Serial . println ( "Beo4_TV_9" );
83 }
84 if ( IRcompare ( numberpulses , ApplePlaySignal , sizeof ( ApplePlaySignal ) / 4 )) {
85 Serial . println ( "PLAY" );
86 }
87 if ( IRcompare ( numberpulses , AppleRewindSignal , sizeof ( AppleRewindSignal ) / 4 )) {
88 Serial . println ( "REWIND" );
89 }
90 if ( IRcompare ( numberpulses , AppleForwardSignal , sizeof ( AppleForwardSignal ) / 4 )) {
91 Serial . println ( "FORWARD" );
92 }
93 delay ( 500 );
94 }
95
96 //KGO: added size of compare sample. Only compare the minimum of the two
97 boolean IRcompare ( int numpulses , int Signal [], int refsize ) {
98 int count = min ( numpulses , refsize );
99 #ifdef DEBUG
100 Serial . print ( "count set to: " );
101 Serial . println ( count );
102 #endif
103 for ( int i = 0 ; i < count - 1 ; i ++ ) {
104 int oncode = pulses [ i ][ 1 ] * RESOLUTION / 10 ;
105 int offcode = pulses [ i + 1 ][ 0 ] * RESOLUTION / 10 ;
106
107 #ifdef DEBUG
108 Serial . print ( oncode ); // the ON signal we heard
109 Serial . print ( " - " );
110 Serial . print ( Signal [ i * 2 + 0 ]); // the ON signal we want
111 #endif
112
113 // check to make sure the error is less than FUZZINESS percent
114 if ( abs ( oncode - Signal [ i * 2 + 0 ]) <= ( Signal [ i * 2 + 0 ] * FUZZINESS / 100 )) {
115 #ifdef DEBUG
116 Serial . print ( " (ok)" );
117 #endif
118 } else {
119 #ifdef DEBUG
120 Serial . print ( " (x)" );
121 #endif
122 // we didn't match perfectly, return a false match
123 return false ;
124 }
125
126
127 #ifdef DEBUG
128 Serial . print ( " \t " ); // tab
129 Serial . print ( offcode ); // the OFF signal we heard
130 Serial . print ( " - " );
131 Serial . print ( Signal [ i * 2 + 1 ]); // the OFF signal we want
132 #endif
133
134 if ( abs ( offcode - Signal [ i * 2 + 1 ]) <= ( Signal [ i * 2 + 1 ] * FUZZINESS / 100 )) {
135 #ifdef DEBUG
136 Serial . print ( " (ok)" );
137 #endif
138 } else {
139 #ifdef DEBUG
140 Serial . print ( " (x)" );
141 #endif
142 // we didn't match perfectly, return a false match
143 return false ;
144 }
145
146 #ifdef DEBUG
147 Serial . println ();
148 #endif
149 }
150 // Everything matched!
151 return true ;
152 }
153
154 int listenForIR ( void ) {
155 currentpulse = 0 ;
156
157 while ( 1 ) {
158 uint16_t highpulse , lowpulse ; // temporary storage timing
159 highpulse = lowpulse = 0 ; // start out with no pulse length
160
161 // while (digitalRead(IRpin)) { // this is too slow!
162 while ( IRpin_PIN & ( 1 << IRpin )) {
163 // pin is still HIGH
164
165 // count off another few microseconds
166 highpulse ++ ;
167 delayMicroseconds ( RESOLUTION );
168
169 // If the pulse is too long, we 'timed out' - either nothing
170 // was received or the code is finished, so print what
171 // we've grabbed so far, and then reset
172
173 // KGO: Added check for end of receive buffer
174 if ((( highpulse >= MAXPULSE ) && ( currentpulse != 0 )) || currentpulse == NUMPULSES ) {
175 return currentpulse ;
176 }
177 }
178 // we didn't time out so lets stash the reading
179 pulses [ currentpulse ][ 0 ] = highpulse ;
180
181 // same as above
182 while ( ! ( IRpin_PIN & _BV ( IRpin ))) {
183 // pin is still LOW
184 lowpulse ++ ;
185 delayMicroseconds ( RESOLUTION );
186 // KGO: Added check for end of receive buffer
187 if ((( lowpulse >= MAXPULSE ) && ( currentpulse != 0 )) || currentpulse == NUMPULSES ) {
188 return currentpulse ;
189 }
190 }
191 pulses [ currentpulse ][ 1 ] = lowpulse ;
192
193 // we read one high-low pulse successfully, continue!
194 currentpulse ++ ;
195 }
196 }
197 void printpulses ( void ) {
198 Serial . println ( " \n\r\n\r Received: \n\r OFF \t ON" );
199 for ( uint8_t i = 0 ; i < currentpulse ; i ++ ) {
200 Serial . print ( pulses [ i ][ 0 ] * RESOLUTION , DEC );
201 Serial . print ( " usec, " );
202 Serial . print ( pulses [ i ][ 1 ] * RESOLUTION , DEC );
203 Serial . println ( " usec" );
204 }
205
206 // print it in a 'array' format
207 Serial . println ( "int IRsignal[] = {" );
208 Serial . println ( "// ON, OFF (in 10's of microseconds)" );
209 for ( uint8_t i = 0 ; i < currentpulse - 1 ; i ++ ) {
210 Serial . print ( " \t " ); // tab
211 Serial . print ( pulses [ i ][ 1 ] * RESOLUTION / 10 , DEC );
212 Serial . print ( ", " );
213 Serial . print ( pulses [ i + 1 ][ 0 ] * RESOLUTION / 10 , DEC );
214 Serial . println ( "," );
215 }
216 Serial . print ( " \t " ); // tab
217 Serial . print ( pulses [ currentpulse - 1 ][ 1 ] * RESOLUTION / 10 , DEC );
218 Serial . print ( ", 0};" );
219 }
VG Peter
K
Kurt
#6920499
Du zeigst da eine langweilige Reihe von (glaube ich) Code-Abläufen von
irgendeiner IR-Fernsteuerung für irgendein Gerät mit 455 kHz
Trägerfrequenz.
Wonach hast du denn gesucht?
Gibt es da ein zu steuerndes Gerät, das du bedienen willst - oder eine
Fernsteuerung, die du entschlüsseln willst? Oder wie, oder was?
Rede einfach mal Klartext:
- Es geht um ...
- Ich will ...
- Ich habe schon ...
Frage schei3e bzw nicht vorhanden, Format ebenso €÷×¥₩%$#@.
Was ist denn daran so schwer sich mal in den Leser rein zu versetzten?
FW, Klaus.
Hmm. Liebe Forumsteilnehmer Kurt und Klaus.
Der Forumsbereich hier heißt "Projekte und Code". Ich habe hier ggf. für
weitere Interessierte aufgezeigt, wie ich das für mein Projekt gelöst
hatte, eine Beo4 = Bang & Olufson Beo4 Fernbedienung zu nutzen.
Eine Frage ist darin nicht enthalten ;-)
Details zum Projekt (hier: Fernbedienung der Spiele) - wen es
interessiert:
https://github.com/petersieg/ScopeClock-alt
Ansonsten aber noch frohe Weihnachtsfesttage.
VG Peter
Ok, muss man erstmal wissen...etwas mehr prosa schadet nicht. Und irmp
ist dafür auch geeignet, oder was ist das besondere an deiner Lsg.?
Dito!
Klaus.
S
Schlaumaier
#6920857
Der Thread ist zwar schon 6 Monate alt, die Lösung ist viel einfacher.
Man braucht den Unsinn nicht i.d.R.
Man nehme ein Empfänger (richtige Khz-Zahl sonst ausprobieren, so teuer
sind die Empfänger nicht) !!!, baue ihn in die Schaltung ein. Nehme
seine FB und das IR-Scan Prg. (findet man im Netz). Draufdrücken und
auf den Serial-Monitor die Zahl ablesen und mit der Taste aufschreiben.
Nun die Zahl an die IR-Send-Diode schicken und das war's.
So habe ich von ALLEN FB's "Backups" gemacht. Und genau so funktioniert
eine Commando-Steuerung von mir. Die via Tasten-Makros jede Menge
Befehle an jeden Menge Geräte sendet.
↑ Nach oben
← Zurück zu Projekte & Code
