Arduino: Jeff Rowberg MPU6050_DMP6 mit 2x MPU6050
OP #6825539
ich möchte den Code von Jeff Rowberg MPU6050_DMP6 mit 2 (oder mehr)
MPU6050 nutzen um die QUATERNION für 2 MPU's zu bekommen, leider findet
man keinen einen Post wie man den Code adaptieren könnte.
Ich bin noch neu mit Arduino und Microcontoller deshalb die Frage.
Vlt. wäre jemand so nett und könnte mir helfen bzw. weiß einen Post wo
sowas schon mal gemacht wurde.
Danke
mfg
Hier der Code:
// I2C device class (I2Cdev) demonstration Arduino sketch for MPU6050 class using DMP (MotionApps v2.0)
// 6/21/2012 by Jeff Rowberg <jeff@rowberg.net>
// Updates should (hopefully) always be available at https://github.com/jrowberg/i2cdevlib
// Changelog:
//      2019-07-08 - Added Auto Calibration and offset generator
//       - and altered FIFO retrieval sequence to avoid using blocking code
//      2016-04-18 - Eliminated a potential infinite loop
//      2013-05-08 - added seamless Fastwire support
//                 - added note about gyro calibration
//      2012-06-21 - added note about Arduino 1.0.1 + Leonardo compatibility error
//      2012-06-20 - improved FIFO overflow handling and simplified read process
//      2012-06-19 - completely rearranged DMP initialization code and simplification
//      2012-06-13 - pull gyro and accel data from FIFO packet instead of reading directly
//      2012-06-09 - fix broken FIFO read sequence and change interrupt detection to RISING
//      2012-06-05 - add gravity-compensated initial reference frame acceleration output
//                 - add 3D math helper file to DMP6 example sketch
//                 - add Euler output and Yaw/Pitch/Roll output formats
//      2012-06-04 - remove accel offset clearing for better results (thanks Sungon Lee)
//      2012-06-01 - fixed gyro sensitivity to be 2000 deg/sec instead of 250
//      2012-05-30 - basic DMP initialization working
24
I2Cdev device library code is placed under the MIT license
25
Copyright (c) 2012 Jeff Rowberg
26
Permission is hereby granted, free of charge, to any person obtaining a copy
27
of this software and associated documentation files (the "Software"), to deal
28
in the Software without restriction, including without limitation the rights
29
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
30
copies of the Software, and to permit persons to whom the Software is
31
furnished to do so, subject to the following conditions:
32
The above copyright notice and this permission notice shall be included in
33
all copies or substantial portions of the Software.
34
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
35
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
36
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
37
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
38
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
39
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
40
THE SOFTWARE.
41
42
43
44
// I2Cdev and MPU6050 must be installed as libraries, or else the .cpp/.h files
45
// for both classes must be in the include path of your project
46
#include "I2Cdev.h"
47
48
#include "MPU6050_6Axis_MotionApps20.h"
49
//#include "MPU6050.h" // not necessary if using MotionApps include file
50
51
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
52
// is used in I2Cdev.h
53
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
54
    #include "Wire.h"
55
#endif
56
57
// class default I2C address is 0x68
58
// specific I2C addresses may be passed as a parameter here
59
// AD0 low = 0x68 (default for SparkFun breakout and InvenSense evaluation board)
60
// AD0 high = 0x69
61
MPU6050 mpu;
62
//MPU6050 mpu(0x69); // <-- use for AD0 high
63
64
65
   NOTE: In addition to connection 3.3v, GND, SDA, and SCL, this sketch
66
   depends on the MPU-6050's INT pin being connected to the Arduino's
67
   external interrupt #0 pin. On the Arduino Uno and Mega 2560, this is
68
   digital I/O pin 2.
69
70
71
72
   NOTE: Arduino v1.0.1 with the Leonardo board generates a compile error
73
   when using Serial.write(buf, len). The Teapot output uses this method.
74
   The solution requires a modification to the Arduino USBAPI.h file, which
75
   is fortunately simple, but annoying. This will be fixed in the next IDE
76
   release. For more info, see these links:
77
   http://arduino.cc/forum/index.php/topic,109987.0.html
78
   http://code.google.com/p/arduino/issues/detail?id=958
79
80
81
82
83
// uncomment "OUTPUT_READABLE_QUATERNION" if you want to see the actual
84
// quaternion components in a [w, x, y, z] format (not best for parsing
85
// on a remote host such as Processing or something though)
86
//#define OUTPUT_READABLE_QUATERNION
87
88
// uncomment "OUTPUT_READABLE_EULER" if you want to see Euler angles
89
// (in degrees) calculated from the quaternions coming from the FIFO.
90
// Note that Euler angles suffer from gimbal lock (for more info, see
91
// http://en.wikipedia.org/wiki/Gimbal_lock)
92
//#define OUTPUT_READABLE_EULER
93
94
// uncomment "OUTPUT_READABLE_YAWPITCHROLL" if you want to see the yaw/
95
// pitch/roll angles (in degrees) calculated from the quaternions coming
96
// from the FIFO. Note this also requires gravity vector calculations.
97
// Also note that yaw/pitch/roll angles suffer from gimbal lock (for
98
// more info, see: http://en.wikipedia.org/wiki/Gimbal_lock)
99
#define OUTPUT_READABLE_YAWPITCHROLL
100
101
// uncomment "OUTPUT_READABLE_REALACCEL" if you want to see acceleration
102
// components with gravity removed. This acceleration reference frame is
103
// not compensated for orientation, so +X is always +X according to the
104
// sensor, just without the effects of gravity. If you want acceleration
105
// compensated for orientation, us OUTPUT_READABLE_WORLDACCEL instead.
106
//#define OUTPUT_READABLE_REALACCEL
107
108
// uncomment "OUTPUT_READABLE_WORLDACCEL" if you want to see acceleration
109
// components with gravity removed and adjusted for the world frame of
110
// reference (yaw is relative to initial orientation, since no magnetometer
111
// is present in this case). Could be quite handy in some cases.
112
//#define OUTPUT_READABLE_WORLDACCEL
113
114
// uncomment "OUTPUT_TEAPOT" if you want output that matches the
115
// format used for the InvenSense teapot demo
116
//#define OUTPUT_TEAPOT
117
118
119
120
#define INTERRUPT_PIN 2  // use pin 2 on Arduino Uno & most boards
121
#define LED_PIN 13 // (Arduino is 13, Teensy is 11, Teensy++ is 6)
122
bool blinkState = false;
123
124
// MPU control/status vars
125
bool dmpReady = false;  // set true if DMP init was successful
126
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
127
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
128
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
129
uint16_t fifoCount;     // count of all bytes currently in FIFO
130
uint8_t fifoBuffer[64]; // FIFO storage buffer
131
132
// orientation/motion vars
133
Quaternion q;           // [w, x, y, z]         quaternion container
134
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
135
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
136
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
137
VectorFloat gravity;    // [x, y, z]            gravity vector
138
float euler[3];         // [psi, theta, phi]    Euler angle container
139
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
140
141
// packet structure for InvenSense teapot demo
142
uint8_t teapotPacket[14] = { '$', 0x02, 0,0, 0,0, 0,0, 0,0, 0x00, 0x00, '\r', '\n' };
143
144
145
146
147
// ===               INTERRUPT DETECTION ROUTINE                ===
148
149
150
volatile bool mpuInterrupt = false;     // indicates whether MPU interrupt pin has gone high
151
void dmpDataReady() {
152
    mpuInterrupt = true;
153
154
155
156
157
158
// ===                      INITIAL SETUP                       ===
159
160
161
void setup() {
162
    // join I2C bus (I2Cdev library doesn't do this automatically)
163
164
        Wire.begin();
165
        Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
166
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
167
        Fastwire::setup(400, true);
168
    #endif
169
170
    // initialize serial communication
171
    // (115200 chosen because it is required for Teapot Demo output, but it's
172
    // really up to you depending on your project)
173
    Serial.begin(115200);
174
    while (!Serial); // wait for Leonardo enumeration, others continue immediately
175
176
    // NOTE: 8MHz or slower host processors, like the Teensy @ 3.3V or Arduino
177
    // Pro Mini running at 3.3V, cannot handle this baud rate reliably due to
178
    // the baud timing being too misaligned with processor ticks. You must use
179
    // 38400 or slower in these cases, or use some kind of external separate
180
    // crystal solution for the UART timer.
181
182
    // initialize device
183
    Serial.println(F("Initializing I2C devices..."));
184
    mpu.initialize();
185
    pinMode(INTERRUPT_PIN, INPUT);
186
187
    // verify connection
188
    Serial.println(F("Testing device connections..."));
189
    Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
190
191
    // wait for ready
192
    Serial.println(F("\nSend any character to begin DMP programming and demo: "));
193
    while (Serial.available() && Serial.read()); // empty buffer
194
    while (!Serial.available());                 // wait for data
195
    while (Serial.available() && Serial.read()); // empty buffer again
196
197
    // load and configure the DMP
198
    Serial.println(F("Initializing DMP..."));
199
    devStatus = mpu.dmpInitialize();
200
201
    // supply your own gyro offsets here, scaled for min sensitivity
202
    mpu.setXGyroOffset(220);
203
    mpu.setYGyroOffset(76);
204
    mpu.setZGyroOffset(-85);
205
    mpu.setZAccelOffset(1788); // 1688 factory default for my test chip
206
207
    // make sure it worked (returns 0 if so)
208
    if (devStatus == 0) {
209
        // Calibration Time: generate offsets and calibrate our MPU6050
210
        mpu.CalibrateAccel(6);
211
        mpu.CalibrateGyro(6);
212
        mpu.PrintActiveOffsets();
213
        // turn on the DMP, now that it's ready
214
        Serial.println(F("Enabling DMP..."));
215
        mpu.setDMPEnabled(true);
216
217
        // enable Arduino interrupt detection
218
        Serial.print(F("Enabling interrupt detection (Arduino external interrupt "));
219
        Serial.print(digitalPinToInterrupt(INTERRUPT_PIN));
220
        Serial.println(F(")..."));
221
        attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
222
        mpuIntStatus = mpu.getIntStatus();
223
224
        // set our DMP Ready flag so the main loop() function knows it's okay to use it
225
        Serial.println(F("DMP ready! Waiting for first interrupt..."));
226
        dmpReady = true;
227
228
        // get expected DMP packet size for later comparison
229
        packetSize = mpu.dmpGetFIFOPacketSize();
230
    } else {
231
        // ERROR!
232
        // 1 = initial memory load failed
233
        // 2 = DMP configuration updates failed
234
        // (if it's going to break, usually the code will be 1)
235
        Serial.print(F("DMP Initialization failed (code "));
236
        Serial.print(devStatus);
237
        Serial.println(F(")"));
238
239
240
    // configure LED for output
241
    pinMode(LED_PIN, OUTPUT);
242
243
244
245
246
247
// ===                    MAIN PROGRAM LOOP                     ===
248
249
250
void loop() {
251
    // if programming failed, don't try to do anything
252
    if (!dmpReady) return;
253
    // read a packet from FIFO
254
    if (mpu.dmpGetCurrentFIFOPacket(fifoBuffer)) { // Get the Latest packet
255
        #ifdef OUTPUT_READABLE_QUATERNION
256
            // display quaternion values in easy matrix form: w x y z
257
            mpu.dmpGetQuaternion(&q, fifoBuffer);
258
            Serial.print("quat\t");
259
            Serial.print(q.w);
260
            Serial.print("\t");
261
            Serial.print(q.x);
262
            Serial.print("\t");
263
            Serial.print(q.y);
264
            Serial.print("\t");
265
            Serial.println(q.z);
266
        #endif
267
268
        #ifdef OUTPUT_READABLE_EULER
269
            // display Euler angles in degrees
270
271
            mpu.dmpGetEuler(euler, &q);
272
            Serial.print("euler\t");
273
            Serial.print(euler[0] * 180/M_PI);
274
            Serial.print("\t");
275
            Serial.print(euler[1] * 180/M_PI);
276
            Serial.print("\t");
277
            Serial.println(euler[2] * 180/M_PI);
278
        #endif
279
280
        #ifdef OUTPUT_READABLE_YAWPITCHROLL
281
282
283
            mpu.dmpGetGravity(&gravity, &q);
284
            mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
285
            Serial.print("ypr\t");
286
            Serial.print(ypr[0] * 180/M_PI);
287
            Serial.print("\t");
288
            Serial.print(ypr[1] * 180/M_PI);
289
            Serial.print("\t");
290
            Serial.println(ypr[2] * 180/M_PI);
291
        #endif
292
293
        #ifdef OUTPUT_READABLE_REALACCEL
294
            // display real acceleration, adjusted to remove gravity
295
296
            mpu.dmpGetAccel(&aa, fifoBuffer);
297
298
            mpu.dmpGetLinearAccel(&aaReal, &aa, &gravity);
299
            Serial.print("areal\t");
300
            Serial.print(aaReal.x);
301
            Serial.print("\t");
302
            Serial.print(aaReal.y);
303
            Serial.print("\t");
304
            Serial.println(aaReal.z);
305
        #endif
306
307
        #ifdef OUTPUT_READABLE_WORLDACCEL
308
            // display initial world-frame acceleration, adjusted to remove gravity
309
            // and rotated based on known orientation from quaternion
310
311
312
313
314
            mpu.dmpGetLinearAccelInWorld(&aaWorld, &aaReal, &q);
315
            Serial.print("aworld\t");
316
            Serial.print(aaWorld.x);
317
            Serial.print("\t");
318
            Serial.print(aaWorld.y);
319
            Serial.print("\t");
320
            Serial.println(aaWorld.z);
321
        #endif
322
323
        #ifdef OUTPUT_TEAPOT
324
            // display quaternion values in InvenSense Teapot demo format:
325
            teapotPacket[2] = fifoBuffer[0];
326
            teapotPacket[3] = fifoBuffer[1];
327
            teapotPacket[4] = fifoBuffer[4];
328
            teapotPacket[5] = fifoBuffer[5];
329
            teapotPacket[6] = fifoBuffer[8];
330
            teapotPacket[7] = fifoBuffer[9];
331
            teapotPacket[8] = fifoBuffer[12];
332
            teapotPacket[9] = fifoBuffer[13];
333
            Serial.write(teapotPacket, 14);
334
            teapotPacket[11]++; // packetCount, loops at 0xFF on purpose
335
        #endif
336
337
        // blink LED to indicate activity
338
        blinkState = !blinkState;
339
        digitalWrite(LED_PIN, blinkState);
340
341
Gast #6855116
> (oder mehr) MPU6050 nutzen um die QUATERNION für 2 MPU's zu > bekommen, leider
findet man keinen einen Post wie man den
Warst Du schon auf der GitHub-Seite von Jeff Rowberg? In der dortigen
Beschreibung erwähnt Jeff jedenfalls, daß er erst kürzlich etwas
verbessert hat, weil einige User bis zu vier MPU6050 gleichzeitig nutzen
wollten. Folglich solltest Du dort wahrscheinlich recht gute Chancen
haben, jemanden zu finden, der sowas bereits gemacht hat.
Nachdem Du die wichtigen Regeln offenbar übersehen hast, hier übrigens
noch einmal der klare Hinweis:
    Längeren Sourcecode nicht im Text einfügen,
    sondern als Dateianhang
