esp32, CPU1 ganz für mich
OP #7071895
der esp32 ist Dank seines RTOS nicht ganz echtzeitfähig. Man kann aber
die CPU1 einfach ganz für sich bekommen.
Beispiel ist einfacher Rechteckgenerator:
Ich habe auf esp32-s3 getested mit der idf (bleeding edge), das sollte
aber auch auf esp32 WROOM32 laufen:
 * SPDX-FileCopyrightText: 2022 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Unlicense OR CC0-1.0
#include <stdint.h>
#include "esp_log.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
static const char *TAG = "example";
#define OUT_PORT 9
static volatile int cpu1Cnt=0;
void IRAM_ATTR task_cpu1(void *dummy)
23
24
  // first config the outputs
25
    gpio_config_t io_conf = {};
26
    //disable interrupt
27
    io_conf.intr_type = GPIO_INTR_DISABLE;
28
    //set as output mode
29
    io_conf.mode = GPIO_MODE_OUTPUT;
30
    //bit mask of the pins that you want to set,e.g.GPIO18/19
31
    io_conf.pin_bit_mask = (1<<OUT_PORT);
32
    //disable pull-down mode
33
    io_conf.pull_down_en = 0;
34
    //disable pull-up mode
35
    io_conf.pull_up_en = 0;
36
    //configure GPIO with the given settings
37
    gpio_config(&io_conf);
38
39
  // now disable interrupts for CPU1
40
  portDISABLE_INTERRUPTS();
41
  // never enable it again, so Taskscheduler will not steal cycles
42
  // DMA will steal them nevertheless
43
  // if you uncomment it, you will see interrutions of about 10 us every RTOS tick
44
45
#if 1  // slow version, generates about 1 MHz at fCPU = 160 MHz on ESP32-S3
46
  while(1)
47
48
    gpio_set_level(OUT_PORT, 0);
49
    cpu1Cnt ++;
50
    gpio_set_level(OUT_PORT, 1);
51
52
#else   // fast Version with direct access to the GPIO register
53
    // generates about 8 MHz square at fCPU = 160 MHz on esp32-s3
54
  // register addresses are valid only for esp32-s3
55
  volatile uint32_t * pGPIOw1tc = (uint32_t *)0x6000400c;
56
        volatile uint32_t * pGPIOw1ts = (uint32_t *)0x60004008;
57
        volatile uint32_t * pGPIOin = (uint32_t *)0x6000403c;
58
  while(1)
59
60
    *pGPIOw1tc = (1 << OUT_PORT); // clear Port
61
    *pGPIOw1ts = (1 << OUT_PORT); // set Port
62
63
#endif
64
65
66
67
68
void tuwas(void)
69
70
    volatile int i,k,jj=0;
71
    for(k=0;k<10000;k++)
72
73
        for(i=0;i<1000;i++) jj+= k+i;
74
75
76
77
78
79
void app_main(void)
80
81
    ESP_LOGI(TAG, "Start CPU1");
82
    xTaskCreatePinnedToCore(task_cpu1, "tskCpu1", 2048, NULL, 10, NULL, 1);
83
84
  int Cnt=0;
85
  while (1)
86
87
    ESP_LOGI(TAG,"Cnt = %d, cpu1Cnt = %d",Cnt,cpu1Cnt);
88
    Cnt++;
89
    tuwas();
90
91
Damit das läuft, müssen Watchdogs disabled werden. Also idf Anleitung:
idf.py settarget esp32-s3
idf.py menuconfig
   bei menuconfig unter component config/esp system settings
   1) disable: Initialize task watchdog timer on startup
   2) disable: also watch cpu1 timer tick
idf.py - p yourComPort flash monitor
Wenn es mal einer mit dem normale esp probiert, mag der ja seine
Ergenisse hier berichten. Ich habe gerade keinen zur Hand.
idf-projekt habe ich als zip angehängt. Vielleicht hilft es ja jemandem
-Martin
