PIC Mikrocontroller UART READ
OP #7105661
Hey everybody, its nice to be part of the forum. I could use a little
help.
I got stuck.
So basically i have the Travos 3 modul and i am sending data ("Hello
World!") via HTerm, to my other Travos 3 funkmodul on my board. I want
to store the data in an array and send it back ( with my PIC18F27Q43)
But it does not work :((
char payload[16] = {0};
     while (UART5_is_rx_ready()){
     payload[i] = UART5_Read();
     i++;
      if (payload[1] == 0x81){
            UART5_Write(0x02);
            UART5_Write(0x00);
            UART5_Write(0x0C);
            UART5_Write(0x48);
#7105808
Transmitting a byte over the UART need time. Thus the receive buffer was
empty, most of the time.
You need to establish a protocol, whereby the receiver was able to
determine the end of a message. And then collect all received bytes
until the end was detected.
On text messages it was easy, to use CR+LF as end sign.
A poor solution was also, to use a timeout counter, to assume, the
message was finished, if a certain time no more bytes are received.
OP #7105834
Thats helpfull, thanks.
But i just find out that i can store only to bytes.
// from data sheet
The UART module includes the following capabilities:
- Half and Full-duplex asynchronous transmit and receive
- Two-byte input buffer    !!!!!
- One-byte output buffer
And its true, cause when i put an led in the while loop. It will blink
only two times and then leave the while loop.
while (UART5_is_rx_ready()) {
            LATBbits.LATB3 = 1;
            __delay_ms(100);
            i++;
            LATBbits.LATB3 = 0;
            __delay_ms(100);
Is it a way i can extend the buffer??
Thanks a lot for answering
#7138108
"It does not work" is a very general description.
I use a lot of UART in my pic projects. Likely it is a configuration
issue.
My suggestions:
* most likely your receive loop is broken. It will wait infinitely for
new characters and out does not break after 16 characters which will
overwrite other memory.
* try immediate echo within the loop. There is enough time if you set
the pic tact rate high enough.
If this is not a problem for you, then:
* set up a test project just for the uart and use mcc for the
configuration. It will set pin mapping, baud rate, and IO right.
* use the pin grid view to check the pin assignment
* I remember that maybe not all uarts have the same capabilities. You
use uart5 which means there many squeezed in the pic
* check baud rates
* check the signal with an oscilloscope
* you cannot do step by step debugging while receiving. It will spoil
the timing.
* you would want to design a more sophisticated protocol to mark begin
and end of a message.
Gast #7138608
Leonidas T. schrieb:
> I got stuck.
> So basically i have...
I think, you need some more skills. So I try to explain the basics of
any serial transmissions:
On the receiver side you will never know, if and when a character is
received and ready to use. So your serial driver needs to establish some
kind of buffering to separate the transmission side from the usage side.
With bigger controllers usually a circular buffer for 32 or more
characters is established, but programming a PIC needs some kind of
economical behaviour, so the circular buffer for the receiving direction
may be made smaller. If you write your code in a rather not blocking
manner, I think, a buffer of 8 places will work good enough.
On the transmitting side you usually want to have a bigger buffer, 64
places or more. This is, because you often want to send a message
without need to calculate the needed time for the actual transmission,
so the message needs enough place in the buffer. Keep in mind, that the
actual transmission ist rather slow, but it is to be handled in the
interrupt service routines.
So your kind of programming should be rather event-driven. Please note
the differences in the 2 Examples:
At first the rather stupid version:
int main (...)
forever:
{ wait_for_UART_is_ready();
  Ch = Get_the_character_from_UART();
  Do_something_with_it(Ch);
  Do_somehing_else();
Here the event driven version:
int main (...)
forever:
{ if (Is_Character_available())
  { Ch = Get_the_character_from_UART();
  Do_somehing_else();
Please note, that "Is_Character_available()" does not necessary refer to
a UART, it shows instead, if some useable character is waiting
(somewhere) to be fetched, but the calling program does not need, to
handle any of the duties of the driver - or even know, if it's a UART or
a riding messenger from Mars delivering a character.
In short: never handle low level duties in your firmware parts, let them
be handled in a device driver, who separates the actual transmission
problems from the "user"-level.
W.S.
