APA102 LED Strip mit Arduino Nano ansteuern
Gast #7319420
ich verzweifel bei der Ansteuerung eiens APA102 LED Strips mit meinem Arduino nano.
Folgendes Schaltbild verwende ich D8->ClockIn, D9->DataIn und ich arbeite mit einer externen Stromversorgung fuer den LED Streifen und habe den Ground vom externen Netzteil an den GND PIN vom Arduino Nano angeschlossen. Arduino Nano wird selbst mit von USB (PC) gespeist
Hier ist das Programm:
/* This example shows how to display a moving rainbow pattern on
 * an APA102-based LED strip. */
/* By default, the APA102 library uses pinMode and digitalWrite
 * to write to the LEDs, which works on all Arduino-compatible
 * boards but might be slow.  If you have a board supported by
 * the FastGPIO library and want faster LED updates, then install
 * the FastGPIO library and uncomment the next two lines: */
// #include <FastGPIO.h>
// #define APA102_USE_FAST_GPIO
#include <APA102.h>
// Define which pins to use.
const uint8_t dataPin = 11;
const uint8_t clockPin = 12;
// Create an object for writing to the LED strip.
APA102<dataPin, clockPin> ledStrip;
// Set the number of LEDs to control.
const uint16_t ledCount = 5;
23
24
// Create a buffer for holding the colors (3 bytes per color).
25
rgb_color colors[ledCount];
26
27
// Set the brightness to use (the maximum is 31).
28
const uint8_t brightness = 1;
29
30
void setup()
31
32
33
34
/* Converts a color from HSV to RGB.
35
 * h is hue, as a number between 0 and 360.
36
 * s is the saturation, as a number between 0 and 255.
37
 * v is the value, as a number between 0 and 255. */
38
rgb_color hsvToRgb(uint16_t h, uint8_t s, uint8_t v)
39
40
    uint8_t f = (h % 60) * 255 / 60;
41
    uint8_t p = (255 - s) * (uint16_t)v / 255;
42
    uint8_t q = (255 - f * (uint16_t)s / 255) * (uint16_t)v / 255;
43
    uint8_t t = (255 - (255 - f) * (uint16_t)s / 255) * (uint16_t)v / 255;
44
    uint8_t r = 0, g = 0, b = 0;
45
    switch((h / 60) % 6){
46
        case 0: r = v; g = t; b = p; break;
47
        case 1: r = q; g = v; b = p; break;
48
        case 2: r = p; g = v; b = t; break;
49
        case 3: r = p; g = q; b = v; break;
50
        case 4: r = t; g = p; b = v; break;
51
        case 5: r = v; g = p; b = q; break;
52
53
    return rgb_color(r, g, b);
54
55
56
void loop()
57
58
  uint8_t time = millis() >> 4;
59
60
  for(uint16_t i = 0; i < ledCount; i++)
61
62
    uint8_t p = time - i * 8;
63
    colors[i] = hsvToRgb((uint32_t)p * 359 / 256, 255, 255);
64
65
66
  ledStrip.write(colors, ledCount, brightness);
67
68
  delay(10);
69
Es tut sich rein gar nichts am LED streifen. Habt ihr Tipps?
