suche für die Reparatur meines Fluke DMM einen (bezahl- und lieferbaren) Sicherungswiderstand oder eine Bezugsquelle, Werte siehe Überschrift. Alternativ 2 x 470 Ohm mit 500V, 1 Watt oder weniger - oder 3 x 330Ohm 350V etc. Muss halt endeffektlich ins Multimeter passen.. (mit Google bin ich schon durch)
Wieder mal ein Beitrag der Hilfe erbittet, aber weder den Gerätetyp nennt, noch die Fluke Ersatzteilnummer!
Handelt es sich um den 1k 2W SicherungswiderstandFluke 474080? Den hat Fluke öfters eingesetzt. Schwierig verfügbar!
part number 474080 is a Resistor Fixed Wire Wound Induct with NSN 5905011134820 and manufactured by Fluke Corporation Anfragen: https://www.asap-supplychain.com/nsn/quote/fluke-corporation/5905011134820/474080/ https://nexelec.com/FLUKE-474080/
https://www.eevblog.com/forum/blog/eevblog-1424-fluke-23-multimeter-repair/ Fluke 474080, IRC/TT SPH series "General Purpose Failsafe Molded Wirewound Resistor" Fluke 832550, "1k fusible 1% MF 100ppm fuse/flmprf" I think it's a Fluke custom Dale/Vishay part, high voltage.
On the Web people are using NTE Inc. F2W210 "fusible power oxide" but no specs on the part really, for fusing current or voltage :-- Who knows if it is a safe replacement.
1 |
at >16X power (32W) in 60 seconds or less. Meh.
A few years ago I acquired a surplus lot of 10 of the 474080 resistors. There are no substitutes that I'm aware of and people are using inferior parts to make these repairs. IIRC the NTE one is 300V and fusible but not flameproot, the other one I don't know the details of but obviously 500V is a deal killer. Fluke also specifies 1% and 100ppm TC. I've fixed meters that have obviously been hit with some pretty high energy and the correct Fluke resistor stops the damage. Repairs without it are just gam_bling that it the same thing won't happen again.
https://www.diyaudio.com/community/threads/fluke-73-repair.165040/ emfiehlt Dale CMF-65, es gibt auch CMF-70 mit 2W, sind aber nicht flame-proof: https://www.vishay.com/docs/31018/cmfind.pdf
Ich würde zwei FRN 470R 0,5W mit einen dritten auf 1% korrigieren und riskieren, dass die früher durchbrennen. Geht die Genauigkeit überhaupt in einen Teiler im DMM ein? https://de.rs-online.com/web/p/durchsteckwiderstande/2671761 Die FRN gibt es auch in 1 und 2W, vielleicht kennt einer eine Quelle. https://docs.rs-online.com/59f9/0900766b8002759f.pdf
wieso, es gibt doch nur EIN Fluke ;-))))
Jau. https://de.wikipedia.org/wiki/Wale#/media/Datei:Humpback_whale_fluke_(2).jpg
Wow, blank polierte Glaskugel.
leider alles nicht hilfreich:
- alle relevanten Daten zum Sicherungswiderstand stehen in der Titelzeile.
- wurde in div. Fluke verbaut, der genaue Typ ist egal.
- eigtl wollte ich Fluke überhaupt nicht nennen
- der genaue Ohmwert, sounsoviel Watt (<2) und ppm sind wurscht
- zusammenstückeln wegen der Spannung hab ich schon selbst vorgeschlagen
- alle genannten Artikel kenn ich schon, Googlen kann ich selber, steht auch schon oben.
- Fluke braucht man nicht zu fragen, ich schrieb bezahlbar.
- und "schwierig verfügbar" ist auch nicht hilfreich.
Dann wähle unter Vishay mit dem dortigen Programm
Joule Wizard (Der blau hinterlegte)
den leistungsmäßig und spannungs mäßig passenden Widerstand, Dort Dan den direkten link auf die Typen anklicken.
Die bestellst du Dan (Sample Programm, oder gegen Geld bei RS,mouser, etc.)
warum fragst du dann?
versuch die Frage nochmal zu lesen und zu verstehen und antworte dann mal hilfreich.
muss ich nicht, Frage gelesen und verstanden, dann frage doch nicht nach Fluke sondern nenne Daten die Dicke und Länge vom R oder baue dir den selber!
Du hast schon mehr hilfreiche Antworten bekommen, als deine hingerotzte Frage verdient hätte.
Bei soviel Ignoranz kann man eigentlich nur antworten:
"Da gibts doch bestimmt was von Pollin"
..könnte sein. Hast n Link dazu?
und haben sich jetzt alle ausgekotzt oder geht noch einer?
Wo bleiben die forumstypischen Hater??
