Arduino avr-stub debugging
OP #7481054
Gerade bin ich über "avr-stub" gestolpert. Damit ist es scheinbar möglich, einen Atmega328 ohne Debugger zu debuggen:
https://docs.platformio.org/en/stable/plus/debug-tools/avr-stub.html
https://www.youtube.com/watch?v=7wx27FcluMg
Weis jemand, wie der Mechanismus genau funktioniert? Wird hier bei jedem Breakpoint das Flash umprogrammiert?
#7481429
Und nicht nur einmal
The flash memory is overwritten often when debugging with flash
breakpoints. The flash memory in the Atmel AVR MCUs used in Arduino
should survive about 10 thousand rewrites. When breakpoint is
inserted or removed, part of the memory needs to be rewritten.
To make things worse breakpoints are inserted and removed not only
when you actually insert/remove a breakpoint in the IDE but also
automatically when you continue from a breakpoint (the original
instruction needs to be restored and executed) and also sometimes
when you step through the code the debugger will insert temporary
breakpoint, for example to stop the program after stepping over
a function.
In worst case you, you can expect one write to flash memory for
each step/continue click you do in the IDE. This seems scary but
it is still usable and similar to using the debugWIRE hardware
on-chip debugger module.
Ein gutes Argument für ATmega im DIL-Gehäuse mit Sockel :) Das meinen die doch nicht ernst? Das ist doch eine Demo "gdb stub funktioniert auch auf ATmega"? Interessant, keine Frage, aber benutzbar?
