Forum: Mikrocontroller und Digitale Elektronik I2C @ STM32L476RG
von Christian (christian_m346)
Ich versuche auf einem STM32L476RG ein EEPROM via I2C anzusprechen.
Leider scheitere ich aber offenbar bereits an der grundsätzlichen
Konfig. der I2C-Schnittstelle:
void config_i2c(void) {
  //Initialize PB13 and PB14 as SCL and SDA respectively:
    RCC->AHB2ENR |= RCC_AHB2ENR_GPIOBEN;
    //Configure PB13 as SCL:
      GPIOB->AFR[1] &= ~(GPIO_AFRH_AFRH5);
      GPIOB->AFR[1] |= ((uint32_t)GPIO_AF4_I2C2) << GPIO_AFRH_AFSEL13_Pos;
      GPIOB->MODER |= GPIO_MODER_MODER13_1;
      GPIOB->OTYPER |= GPIO_OTYPER_OT13;
      GPIOB->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR13;
    //Configure PB14 as SDA:
      GPIOB->AFR[1] &= ~(GPIO_AFRH_AFRH6);
      GPIOB->AFR[1] |= ((uint32_t)GPIO_AF4_I2C2) << GPIO_AFRH_AFSEL14_Pos;
      GPIOB->MODER |= GPIO_MODER_MODER14_1;
      GPIOB->OTYPER |= GPIO_OTYPER_OT14;
      GPIOB->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR14;
24
25
  //Initialize the I2C interface for master mode:
26
27
    //Make sure HSI16 clock is turned on.
28
    RCC->CR |= RCC_CR_HSION;
29
    while(!(RCC->CR & RCC_CR_HSIRDY));
30
31
    //Select HSI16 clock as I2C2 clock.
32
    RCC->CCIPR |= RCC_CCIPR_I2C2SEL_1;
33
34
    //Enable the clock for the I2C interface.
35
    RCC->APB1ENR1 |= RCC_APB1ENR1_I2C2EN;
36
37
    //Disable the I2C peripheral.
38
    I2C2->CR1 &= ~(I2C_CR1_PE);
39
40
    //Configure timing for "Fast-mode".
41
    //(See Table 236 of the Reference Manual "RM0351, Rev 9" for the values.)
42
    I2C2->TIMINGR =
43
      (0x1u << I2C_TIMINGR_PRESC_Pos) +
44
      (0x9u << I2C_TIMINGR_SCLL_Pos) +
45
      (0x3u << I2C_TIMINGR_SCLH_Pos) +
46
      (0x2u << I2C_TIMINGR_SDADEL_Pos) +
47
      (0x3u << I2C_TIMINGR_SCLDEL_Pos);
48
49
    //"Stop" and "Restart" will be generated by software.
50
    I2C2->CR2 &= ~(I2C_CR2_AUTOEND);
51
52
    //Configure 7-bit addressing and set slave address.
53
    I2C2->CR2 &= ~(I2C_CR2_ADD10);
54
    I2C2->CR2 &= ~(I2C_CR2_SADD);
55
    I2C2->CR2 |= (NV_RAM_DEVICE_ADDRESS << 1)&0xFEul;
56
57
    //Enable the I2C peripheral.
58
    I2C2->CR1 |= I2C_CR1_PE;
59
60
Wenn ich dann versuche, erst einmal einfach eine "Start Condition" zu
generieren, passiert genau gar nichts. Das heisst, ich sehe auf dem
Oszi. rein gar nichts auf den zwei Leitungen.
void do_some_magic(void) {
  //Set transfer dir. "write".
  I2C2->CR2 &= ~(I2C_CR2_RD_WRN);
  //Configure number of bytes to be written.
  I2C2->CR2 |= 1 << I2C_CR2_NBYTES_Pos;
  //Generate "Start Condition".
  I2C2->CR2 |= I2C_CR2_START;
  while(I2C2->CR2&I2C_CR2_START); //<-- HIER DREHT ES "FOREVER"
  return;
Was muss ich noch "enablen", "clearen" etc. oder was sonst ist falsch?
von Harry L. (mysth)
Su solltest HAL nutzen!
Funktioniert einfach und spart enorm Lebenszeit.
Mit HAL funktioniert es übrigens. Hätte ja auch sein können, dass es an
der Hardware, Verkabelung, Pull-ups etc. liegt. Das tut es aber nicht.
Und ich will hier jetzt eben keinen HAL.
von Wilhelm M. (wimalopaan)
zumindest beim Setzen des MODER der GPIOB scheint mit ein "clear" vor
dem "or" der Bits zu fehlen. Denn das "or" setzt zwar das schon gesetzte
Bit. Jedoch musst Du aus dem "analog mode" raus.
Benutze das CMSIS Macro: MODIFY_REG (mit der richtigen Maske).
Falls das Senden mal geklappt hat, solltest Du hier I2C_ISR_TXIS
verwenden.
Das löst das Problem. Vielen Dank.
