Forum: Test Formatierung
Announcement: there is an English version of this forum on EmbDev.net. Posts you create there will be displayed on Mikrocontroller.net and EmbDev.net.
von Al. K. (alterknacker)
;kleine Weihnachtsbastelei
#no_data ;EE-Prom wird beim Dowload nicht überschrieben
#PicAxe 20m2
;Pin Beschreibung
; PICAXE 20M2
;                               +---v---+
;                           Vdd |1    20| Vss
;                   serial in   |2    19| A.0  serial out (out A0)
;          Touch/ADC/In/Out C.7 |3    18| B.0 In/Out/ADC/Touch/SRI
;                        In C.6 |4    17| B.1
In/Out/ADC/Touch/SRI/SRQ/pwm
;          hpwmA/pwm/In/Out C.5 |5    16| B.2 In/Out/ADC/Touch
;              hpwmB/In/Out C.4 |6    15| B.3 In/Out/ADC/Touch
;hpwmC/pwm/Touch/ADC/In/Out C.3 |7    14| B.4 In/Out/ADC/Touch/hpwm D
;         Kb Clk/pwm/In/Out C.2 |8    13| B.5 In/Out/ADC/Touch/I2C/sda
; Kb Data /Touch/ADC/In/Out C.1 |9    12| B.6 In/Out/ADC/Touch/hserin
;           hserout/In/Out  C.0 |10   11| B.7 In/Out/I2C/clk
; PICAXE 20M2
;                     +---v---+
;            (+)  Vdd |1    20| Vss  (-)
;                 RxD |2    19| A.0 TxD   (out A0)
;         poti    C.7 |3    18| B.0
;         Taster  C.6 |4    17| B.1 Weih_Baum
;         Taster1 C.5 |5    16| B.2 Laterne_Weis
;                 C.4 |6    15| B.3 Laterne_Green
;                 C.3 |7    14| B.4 HPWM D/Kerze in Mitte
;                 C.2 |8    13| B.5 Feuer_Rot
;          RESERV C.1 |9    12| B.6 Feuer_Green
;         rESERVE C.0 |10   11| B.7 Feuer_Blau
;Pin defination
symbol Feuer_Blau =B.7
symbol Feuer_Green=B.6
symbol Feuer_Rot  =B.5
symbol Kerze  =B.4   ;B.4 HPWM D/Kerze in Mitte
symbol Laterne_Green  =B.3 ;
symbol Laterne_Weis  =B.2
symbol Weih_Baum  =B.1
dirsB    =%11111111
anf:
let pinsB   = %00000000
pause 2000
let pinsB   = %11111111
pause 2000
goto anf
ohne Codeformat
code
#PicAxe 20m2
;Pin Beschreibung
; PICAXE 20M2
;                               +---v---+
;                           Vdd |1    20| Vss
;                        In C.6 |4    17| B.1
; PICAXE 20M2
;                     +---v---+
;Pin defination
dirsB    =%11111111
anf:
pause 2000
pause 2000
goto anf
/code
Mit   Code   /Code
#PicAxe 20m2
;Pin Beschreibung
; PICAXE 20M2
;                               +---v---+
;                           Vdd |1    20| Vss
;                        In C.6 |4    17| B.1 In/Out/ADC/Touch/SRI/SRQ/pwm
23
24
25
26
27
; PICAXE 20M2
28
;                     +---v---+
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
;Pin defination
45
46
47
48
49
50
51
52
53
54
55
56
dirsB    =%11111111
57
58
anf:
59
60
pause 2000
61
62
63
pause 2000
64
65
66
goto anf
Mit
In der Formatierung ist auch ohne  Code in der Vorschau  alles richtig,
das führt natürlich  zu Irrtümern und Fehlern.
Man sollte dies vielleicht so schreiben, natürlich ohne "-"
" [c-od] "    "[/c-ode]°
wenn die eckigen Klammern mitgeschrieben werden sollen.
alterknacker
Beitrag #7534932 wurde von einem Moderator gelöscht.
von Rene K. (xdraconix)
Formatierung hier Bold:
Dies geht
Test: *Dies geht nicht.*
von Manfred P. (pruckelfred)
Auch Fettschrift genannt, Deutsch ist aus der Mode?
> Dies geht
Ich glaube, dass das auch nicht geht, Komma direkt hinter dem Stern.
Es lohnt nicht, die Formatierung ist hier seit eh und je Zufall.
von Lotta  . (mercedes)
Mal sehen, ob die Tilde immer noch durchstreicht:
~Lotta~
