Wo ist in meiner Berechnung der Fehler?
OP #7669329
ich habe mir ein kleines Programm geschrieben. "Eigentlich" macht es auch das was es soll.
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET     -1
#define SCREEN_ADDRESS 0x3D
#define pv_max_volt 40
#define pv_adc_steps 1023
#define bat_max_volt 14
#define bat_adc_steps 1023
float pv_volt_per_step = (pv_max_volt * 100 ) / pv_adc_steps;
float bat_volt_per_step = (bat_max_volt * 100 ) / bat_adc_steps;
int pvPin = A1;
int batPin = A2;
23
int pvAdcVal = 0;
24
int batAdcVal = 0;
25
26
float pvval = 0;
27
float batval = 0;
28
29
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
30
31
void setup() {
32
  Serial.begin(115200);
33
  pixels.begin();
34
35
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
36
  if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
37
    Serial.println(F("SSD1306 allocation failed"));
38
    for(;;); // Don't proceed, loop forever
39
40
41
42
43
44
void updateDisplay() {
45
  display.clearDisplay();
46
47
  display.setTextSize(1);
48
  display.setTextColor(SSD1306_WHITE);
49
  display.setCursor(0,0);
50
  display.println(F("SolarInfo v1.0"));
51
52
  display.setCursor(0,17);
53
  display.println(F("PV In:"));
54
55
  display.setCursor(65,17);
56
  display.println(pvval);
57
58
  display.setCursor(100,17);
59
  display.println(F("Volt"));
60
61
  display.setCursor(0,34);
62
  display.println(F("PV Store:"));
63
64
  display.setCursor(65,34);
65
  display.println(batval);
66
67
  display.setCursor(100,34);
68
69
70
  display.setCursor(0,54);
71
  display.println(F("PV"));
72
73
  display.setCursor(57,54);
74
  display.println(F("Store"));
75
76
  display.display();
77
78
79
void loop() {
80
  pvAdcVal = analogRead(pvPin);
81
  batAdcVal = analogRead(batPin);
82
83
  pvval = (pv_volt_per_step * pvAdcVal) / 100;
84
  batval = (bat_volt_per_step * batAdcVal) / 100;
85
86
  updateDisplay();
87
  //pixels.setPixelColor(0, pixels.Color(20,0,0)); // Moderately bright green color.
88
  //pixels.show();
89
  delay(1000);
90
91
Erklärung:
Ich setze zuerst Feste werte
Danach berechne ich darauf viel V ein ADC Wert beträgt
In der Loop dann die Berechnung
Wenn der ADC Wert nun 0 ist, dann bekomme ich auch 0V. Allso richtig. Ist dieser aber max, also 1023, dann ist pvval 30.69 Volt
durch #define pv_max_volt 40 müsste das ganze jedoch 40Volt sein.. Irgendwie, gehen da 10 Volt "verloren".
Kann mir wer da helfen?
#7669344
Bei der Berechnung macht der Compiler die Berechnung als Ganzzahl, und schneidet alles nach dem Komma ab. Erst dann wird die Zahl bei der Zuweisung in eine Float gewandelt. Gib mal pv_volt_per_step aus.
Lösung dürfte sein ein Define als float zu definieren: #define pv_max_volt 40.0
OP #7669347
Super perfekt. Genau das war es. Super. vielen vielen Dank.
#7669352
Wenn man die Berechnung in Integer packt, ist das ganze wesentlich schneller und kleiner, wenn der Controller nicht gerade eine FPU hat. Dazu kann man die Skala ja vorausberechnen (40/1023=0,0391) und den Wert z.B. als 391 speichern, passt in einen uint_16 (geht man über "scale=4010000/1023" muss es ein uint_32 sein!). Dann "ADCscale", was maximal 1023*391=399993 ergibt (ein uint_32), was man einfach als "39,9993" mit eingefügtem Komma ausgeben kann. Wenn das zuviele Nachkommastellen sind, kann man die auch einfach weglassen, eine Division ist unnötig.
#7669357
Wenn Du auf float umsteigst, kannst Du die /100 und *100 gleich weglassen. Entweder alles mit Integern - oder mit Floats, dann aber richtig.
Ich würde - da 40000/1024=39,0625 - alles int16 in Millivolt rechnen. Oder (wenn die 40V-full-scale-Auflösung nicht ausreicht) mit int32 in Mikrovolt: 40000000/1024=39062,5
Außerdem sind beide xxx_adc_steps 1024 und nicht 1023.
#7670728
und wenn es platzsparender sein soll, gleich alles in centiVolt mit 2 Nachkommerstellen rechen oder in deziVolt mit einer Nachkommastelle. Milli- oder Micro-volt gibt eh der ADC meist nicht her. (vorgetäusche Auflösung) Rechnen tut man mit Konstante als int16 +- oder uint16 und ausgeben durch Komma einsetzen als Text.
#7671317
Joachim, im Prinzip hast Du recht, aber um auf einigermaßen genaue Zenti-Volt zu kommen, muss man den Faktor, mit dem man den ADC-Wert multipliziert, genauer angeben, als dass 16 Bit beim Produkt ausreichen (z.B. (1023 * 313) >> 3 = 40024 braucht 19 Bits). Man kann also, um z.B. auf 40V bei ADC 1023 zu kommen, mit 39 multiplizieren, das trifft es ziemlich genau, aber die umliegenden Schritte liegen dann 2,5% auseinander: 1023 * 38 = 38874 1023 * 39 = 39897 1023 * 40 = 40920 Man kann das Ergebnis nach der Multiplikation korrigieren, indem man den ADC nach rechts schiebt, um "Nachkomma-Bits" zu erlangen: 1023 * 39 + (1023 >> 3) = 40024 Dann könnte man gleich ganz ohne Multiplikation schreiben: wert = adc << 3; // *8 wert += wert << 2; // *32 wert -= adc; // *(-1) wert += adc >> 3; // *0,125 Was einer Mul mit 39,125 (bei 1023 40024, also 40,02) entspricht. So hätte man es früher gemacht, der Code ist halt nicht so leicht wartbar. Aber noch effektiver (kleiner und schneller) kann man es nicht rechnen (16 shifts und 6 adds mit 8 Bit).
#7671803
cV mit zwei Nachkommastellen kannst du besser als 100µV Ganzzahl rechnen. Das spart die Float-Rechnerei, deren Dynamik wegen der begrenzten Auflösung eines ADC gar nicht sinnvoll, allenfalls bei Denkfaulheit bequem ist ;-)
Schon bei einem 10Bit ADC, bei man ein Ergebnis mit 3 gültigen Stellen erwartet, reicht die direkte Angabe des LSB in Einheiten von 100µV allerdings nicht.
Persönliche Seite #7671897
Joachim B. schrieb:
Johann L. schrieb:
Nicht automatisch, z.B. auf ATmega328:
uint32_t Division: ca. 615 Cycles float Division: weniger als 500 Cycles
und was ist mit flash und sram Verbrauch, manchmal ist es nicht die Geschwindigkeit die bremst, sondern das der SRAM ausgeht oder weniger in den FLASH paßt.
Ja natürlich. Ich wollte nur zeigen, dass "float ist immer und überall schlechter als int" nicht automatisch zutrifft. Wirklich nachmessen tut wohl keiner.
Zum Beispiel ist u64 Division in manchen Beispielen schneller als u32 Division für die gleichen Eingaben (mit avr-gcc).
#7673299
Um noch die Grundlagen für das eigentliche Verständnisproblem nachzureichen:
Ein 10-Bit ADC unterteilt seinen Messbereich in 1024 gleichgroße Bereiche. Der Rückgabewert von "analogRead" ist die "Nummer" des Bereichs, in dem der Messwert liegt. Die übliche (im Datenblatt genannte) Umrechnungs-Formel (mit 1024) berechnet daraus die Spannung für die "untere Kante" vom Bereich. Nicht den Mittelpunkt vom Bereich und auch nicht die obere Kante.
Nein.
ADC-Wert von 0 bedeutet: Spannung liegt zwischen 0V und 0.039V. ADC-Wert von 1 bedeutet: Spannung liegt zwischen 0.039V und 0.078V ... ADC-Wert von 1023 bedeutet: Spannung ist größer als 39.96V
Wenn du nun so tust, als hätte dein 10-Bit ADC nur 9.9986 Bits (also: Als würde der nur 1023 Bereiche unterscheiden können) stimmt die Rechnung halt nicht mehr mit der Hardware überein, du kriegst aber an den Grenzen schönere Zahlen angezeigt...
Kann man machen, wenn man sich im klaren ist was man tut.
#7673544
Nur kann man sich oft genau 0,nix dafür kaufen. Ich hatte mich auch lange mit Rundungsfehlern und Überläufen abgeplagt. Dann hatte ich die Nase voll und benutze einfach float. Selbst bei Software-FP ist das fast nie ein Flaschenhals. Z.B. für die Anzeige von Meßwerten ist eine Rate von 2..5 Werten/s ergonomisch. Darüber lacht jede FP-Lib nur.
#7673561
Dein Problem liegt in der Berechnung von pv_volt_per_step. Aktuell berechnest du pv_volt_per_step wie folgt:
Dabei teilst du pv_max_volt durch pv_adc_steps, jedoch multiplizierst du es zuerst mit 100, was zu einem falschen Wert führt. Du solltest einfach pv_max_volt durch pv_adc_steps teilen, ohne die Multiplikation mit 100:
float pv_volt_per_step = pv_max_volt / pv_adc_steps;
Hier ist die angepasste Version deines Codes:
#include <SPI.h>
#include <Wire.h>
float bat_volt_per_step = bat_max_volt / bat_adc_steps;
int pvPin = A1;
int batPin = A2;
23
int pvAdcVal = 0;
24
int batAdcVal = 0;
25
26
float pvval = 0;
27
float batval = 0;
28
29
30
31
void setup() {
32
33
  // pixels.begin(); // Auskommentiert, da nicht benötigt
34
35
36
37
38
39
40
41
42
43
44
45
  display.setCursor(0, 0);
46
47
48
  display.setCursor(0, 17);
49
50
51
  display.setCursor(65, 17);
52
53
54
  display.setCursor(100, 17);
55
56
57
  display.setCursor(0, 34);
58
59
60
  display.setCursor(65, 34);
61
62
63
  display.setCursor(100, 34);
64
65
66
  display.setCursor(0, 54);
67
68
69
  display.setCursor(57, 54);
70
71
72
  display.display();
73
74
75
void loop() {
76
77
78
79
  pvval = pv_volt_per_step * pvAdcVal;
80
  batval = bat_volt_per_step * batAdcVal;
81
82
  updateDisplay();
83
  // pixels.setPixelColor(0, pixels.Color(20,0,0)); // Auskommentiert, da nicht benötigt
84
  // pixels.show(); // Auskommentiert, da nicht benötigt
85
  delay(1000);
86
Durch diese Anpassung wird pvval bei einem ADC-Wert von 1023 korrekt 40 Volt ergeben.
