Need help with reading from i2c bus
OP #7752291
Andreas B. schrieb:
https://letmegooglethat.com/?q=python+i2c
General you should learn the programming language before what you want to use. This forum is not a programming service.
This is my try but the result this wrong
#!/usr/bin/python3
import smbus
import requests
import time
bus = smbus.SMBus(1)
address = 0x0F
x = bus.read_i2c_block_data(address, 0xD0,3)
voltagein = x[2] <<8 | (x[1])
#print (x[1])
#print (x[2])
voltagein_string = "%i" % voltagein
print  (voltagein_string)
bus.close()
del x
del bus
OP #7752326
Matthias S. schrieb:
Try:
> voltagein  = (x[0] * 256) + x[1]
This prints 2 times the same value
address = 0x0F
x = bus.read_i2c_block_data(address, 0xD0,2)
print ("x")
print (x)
#voltagein = (x[1]<<8) | (x[0])
print ("voltage in")
print (voltagein)
bus.close()
del x
del bus
time.sleep(2)
address = 0x0F
x = bus.read_i2c_block_data(address, 0xD1,2)
print ("x")
print (x)
#powerextern = x[0] | (x[1]<<8)
powerextern = (x[0] * 256) + x[1]
23
pwerextern_string = "%i" % powerextern
24
print ("powerstring")
25
print (pwerextern_string)
26
bus.close()
27
del x
28
del bus
x
[208, 137]
voltage in
x
[209, 132]
powerstring
Beitrag #7752374 wurde von einem Moderator gelöscht.
OP #7752397
Martin L. schrieb:
Hmmm schrieb:
Martin L. schrieb:
x [208, 137]
Martin L. schrieb:
x [209, 132]
Seems like the first byte is always the command. What does your debug output look like after reading 3 bytes?
> [sudo] password for openhabian:
> x
> [208, 126, 20]
> voltage in
> 53374
> x
> [209, 159, 20]
> powerstring
> 53663
address = 0x0F
x = bus.read_i2c_block_data(address, 0xD0,9)
print ("x")
print (x)
voltagein = (x[2]<<8) | (x[1])
#voltagein  = (x[1] * 256) + x[2]
print (voltagein)
bus.close()
del x
del bus
time.sleep(2)
address = 0x0F
x = bus.read_i2c_block_data(address, 0xD1,9)
print ("x")
print (x)
powerextern = (x[3]<<8) | x[2]
#powerextern = (x[0] * 256) + x[1]
23
24
25
26
bus.close()
27
del x
28
del bus
x
[208, 110, 20, 1, 105, 20, 0, 0, 0]
voltage in
x
[209, 143, 20, 1, 105, 20, 0, 0, 0]
powerstring
OP #7752398
Hmmm schrieb:
Martin L. schrieb:
[208, 126, 20]
powerextern = (x[2] * 256) + x[1]
Das sollte rauskommen
* S.USV solutions              *
* www.s-usv.com                *
* Model: Advanced              *
* Firmware Version: 2.61       *
* Software Version: 2.40       *
* Hardware Version: 2.2        *
* Mail notification: Disabled  *
* Timed Boot: Disabled         *
* Boot time: 00:00:00          *
* Timed Shutdown: Disabled     *
* Shutdown time: 00:00:00      *
* Fri Oct 11 18:18:54 2024     *
* Powering Source: Primary     *
24
* Charging circuit: OFFLINE    *
25
* Charging current: 300 mA     *
26
27
* Voltage in: 5.23 V           *
28
* Battery capacity: 100.00%    *
29
* Battery voltage: 4.20V       *
30
* Power Battery: 000.00 mA     *
31
* Power Extern: 1259.00 mA      *
32
33
* Shutdown timer: -1           *
34
* Autostart:  enabled          *
35
* Sleep timer: 1               *
36
37
OP #7752408
Hmmm schrieb:
Martin L. schrieb:
voltage in 5230
5230 mV = 5.230 V
The device seems to send the command byte followed by the low byte and the high byte of the value, so just use (x[2] * 256) + x[1] in both cases.
there is no difference between the commands
address = 0x0F
print ("x")
print (x)x
[208, 132, 20]
voltage in
x
[209, 126, 20]
powerstring
print (voltagein)
bus.close()
del x
del bus
time.sleep(2)
24
25
address = 0x0F
26
x = bus.read_i2c_block_data(address, 0xD1,3)
27
print ("x")
28
print (x)
29
#powerextern = (x[3]<<8) | x[2]
30
31
32
33
34
35
bus.close()
36
del x
37
del bus
x
[208, 132, 20]
voltage in
x
[209, 126, 20]
powerstring
(Firma: matzetronics) #7752452
There are 3 bytes in the response. First byte is the command and can be ignored. The second byte is the LSB and the third byte is the MSB. So
voltage = (x[2] * 256) + x[1]
and
voltage = (x[2] << 8) | x[1]
should give the same results
