ESP8266 Wemos D1 mini DeepSleep issue
OP #7757202
Hello,
I have some issue with my Wemos D1 Mini going to deep sleep.
Here is my code
void setup() {
  Serial.begin(115200);
  delay(100);
    pinMode(LED_BUILTIN, OUTPUT);  // Initialize the LED pin as an output
   unsigned long startTime = millis();  // Record the start time
  while (millis() - startTime < 30000) {  // 30,000 milliseconds = 30 seconds
    Serial.println("Loop is running...");
    digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (LOW is the voltage level because the LED is active LOW)
  delay(1000);                      // Wait for 1 second
  digitalWrite(LED_BUILTIN, HIGH);  // Turn the LED off (HIGH voltage level turns it off)
  delay(1000);
  Serial.print("Sleep");
  // Send data over WiFi or to the cloud here (e.g., MQTT or HTTP request)
  // Sleep for 1 hour (1 hour = 3600e6 microseconds)
23
  ESP.deepSleep(10e6);
24
25
26
void loop() {
27
  // Will not run in deep sleep mode
28
I connected D0 with RST with a wire but there is no wake up of the board
here is the output on serial
{$$��|�l�|�d�c|����s�c�b��gg�$og���cx��dsl{d8�o��l��bg�|�l��c��gn�l��d`�gd`'{���gcl {ۓ'bd`�b��d{�`�g�Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Loop is running...
Sleep{dd��|�l�|�l�c|����s�c�c��og�doo���cx��dsd{$
Whe is my code fault? or iss the wemos d1 minir faulty?
Gast #7757208
Try a delay after deepSleep:
ESP.deepSleep(10e6); delay(100);
This is a workaround for a known bug in some firmware revisions.
If that does not help, check/replace the flash memory chip. Fake "D1 mini" boards (not from Wemos) are often equipped with cheaper components. One of them might be a wrong flash chip (e.g. CT 580A-UGLI is known to be incompatible to the deep sleep mode).
Gast #7757452
Alexander schrieb:
Ist das so ein urban myth? was soll ein delay bewirken das nie angesprungen wird?
Wie gesagt ist das Workaround. Problem war (soweit ich mich erinnere), dass der Chip ohne das Delay manchmal nicht in den DeepSleep Modus geht. Es gab dazu mal ein Statement von Espressif, das ich leider nicht wieder finden konnte.
https://www.esp8266.com/viewtopic.php?p=58665#p58665 https://forum.arduino.cc/t/esp-8266-deep-sleep-reset-problem/975963 https://werner.rothschopf.net/microcontroller/202311_esp8266_deepsleep_en.htm https://forum.arduino.cc/t/esp-deep-sleep-mode-on-wemos-d1-not-wake-up/1213624/5 https://www.esp8266.com/viewtopic.php?p=84925
