1 |
mein Header
2 |
#ifndef __MYPNGDEC__
3 |
#define __MYPNGDEC__
4 |
5 |
6 |
#include <Arduino.h>
7 |
#include "FS.h"
8 |
#include "SD.h"
9 |
#include "SPI.h"
10 |
#include <TFT_eSPI.h>
11 |
#include <pngdec.h>
12 |
13 |
#define MAX_IMAGE_WIDTH 320 // Adjust for your images
14 |
15 |
16 |
17 |
18 |
class PngClass {
19 |
public:
20 |
void InitPngLib(TFT_eSPI tft );
21 |
void listDir(fs::FS &fs, const char * dirname, uint8_t levels);
22 |
void DrawPng(int x, int y,const String PngName);
23 |
24 |
private:
25 |
TFT_eSPI * _tft;
26 |
File pngfile;
27 |
PNG _png;
28 |
int xpos;
29 |
int ypos;
30 |
void * pngOpen(const char *filename, int32_t *size);
31 |
void pngClose(void *handle);
32 |
int32_t pngRead(PNGFILE *page, uint8_t *buffer, int32_t length);
33 |
int32_t pngSeek(PNGFILE *page, int32_t position);
34 |
String readFile(fs::FS &fs, const char * path);
35 |
void pngDraw(PNGDRAW *pDraw);
36 |
37 |
38 |
#endif
39 |
40 |
mein C++ File
41 |
#include "MyPngLib.h"
42 |
43 |
void PngClass::InitPngLib(TFT_eSPI tft )
44 |
45 |
_tft = tft;
46 |
//SPIClass spi = SPIClass(VSPI);
47 |
48 |
Serial.println("**********************************************************");
49 |
Serial.print("MOSI: ");
50 |
Serial.println(MOSI);
51 |
Serial.print("MISO: ");
52 |
Serial.println(MISO);
53 |
Serial.print("SCK: ");
54 |
Serial.println(SCK);
55 |
Serial.print("SS: ");
56 |
Serial.println(SS);
57 |
58 |
59 |
//if (!SD.begin(SS, spi, 80000000))
60 |
if (!SD.begin(SS))
61 |
62 |
Serial.println("initialization failed!");
63 |
64 |
65 |
Serial.println("initialization done.");
66 |
listDir(SD, "/", 0);
67 |
68 |
69 |
70 |
71 |
72 |
void PngClass::listDir(fs::FS &fs, const char * dirname, uint8_t levels)
73 |
74 |
Serial.printf("Listing directory: %s\n", dirname);
75 |
76 |
File root = fs.open(dirname);
77 |
if (!root) {
78 |
Serial.println("Failed to open directory");
79 |
return;
80 |
81 |
if (!root.isDirectory()) {
82 |
Serial.println("Not a directory");
83 |
return;
84 |
85 |
86 |
File file = root.openNextFile();
87 |
while (file) {
88 |
if (file.isDirectory()) {
89 |
Serial.print(" DIR : ");
90 |
Serial.println(file.name());
91 |
if (levels) {
92 |
listDir(fs, file.path(), levels - 1);
93 |
94 |
} else {
95 |
Serial.print(" FILE: ");
96 |
Serial.print(file.name());
97 |
Serial.print(" SIZE: ");
98 |
Serial.println(file.size());
99 |
100 |
101 |
102 |
103 |
104 |
105 |
void * PngClass::pngOpen(const char *filename, int32_t *size)
106 |
107 |
Serial.printf("Attempting to open %s\n", filename);
108 |
File _pngfile = SD.open(filename, "r");
109 |
*size = _pngfile.size();
110 |
return &pngfile;
111 |
112 |
113 |
void PngClass::pngClose(void *handle)
114 |
115 |
File _pngfile = *((File*)handle);
116 |
if (_pngfile) _pngfile.close();
117 |
118 |
119 |
int32_t PngClass::pngRead(PNGFILE *page, uint8_t *buffer, int32_t length)
120 |
121 |
if (!pngfile) return 0;
122 |
page = page; // Avoid warning
123 |
return pngfile.read(buffer, length);
124 |
125 |
126 |
int32_t PngClass::pngSeek(PNGFILE *page, int32_t position)
127 |
128 |
129 |
130 |
return pngfile.seek(position);
131 |
132 |
133 |
//=========================================v==========================================
134 |
// _pngDraw
135 |
136 |
// This next function will be called during decoding of the _png file to
137 |
// render each image line to the _tft. If you use a different _tft library
138 |
// you will need to adapt this function to suit.
139 |
// Callback function to draw pixels to the display
140 |
void PngClass::pngDraw(PNGDRAW *pDraw)
141 |
142 |
uint16_t lineBuffer[MAX_IMAGE_WIDTH];
143 |
static uint16_t dmaBuffer[MAX_IMAGE_WIDTH]; // static so buffer persists after fn exit
144 |
_png.getLineAsRGB565(pDraw, lineBuffer, PNG_RGB565_BIG_ENDIAN, 0xffffffff);
145 |
_tft->pushImageDMA(xpos, ypos + pDraw->y, pDraw->iWidth, 1, lineBuffer, dmaBuffer);
146 |
147 |
148 |
149 |
void PngClass::DrawPng(int x, int y,const String PngName)
150 |
151 |
xpos = x;
152 |
ypos = y;
153 |
154 |
int16_t rc = _png.open(PngName.c_str(), pngOpen, pngClose, pngRead, pngSeek, pngDraw);
155 |
if (rc == PNG_SUCCESS) {
156 |
_tft->startWrite();
157 |
Serial.printf("image specs: (%d x %d), %d bpp, pixel type: %d\n", _png.getWidth(), _png.getHeight(), _png.getBpp(), _png.getPixelType());
158 |
uint32_t dt = millis();
159 |
if (_png.getWidth() > MAX_IMAGE_WIDTH) {
160 |
Serial.println("Image too wide for allocated lin buffer!");
161 |
162 |
else {
163 |
rc = _png.decode(NULL, 0);
164 |
_png.close();
165 |
166 |
_tft->endWrite();
167 |
// How long did rendering take...
168 |
Serial.print(millis()-dt); Serial.println("ms");
169 |
170 |
171 |
172 |
173 |
174 |
175 |
String PngClass::readFile(fs::FS &fs, const char * path)
176 |
177 |
Serial.printf("Reading file: %s\r\n", path);
178 |
File file = fs.open(path, "r");
179 |
if(!file || file.isDirectory()){
180 |
Serial.println("- empty file or failed to open file");
181 |
return String();
182 |
183 |
Serial.println("- read from file:");
184 |
String fileContent;
185 |
while(file.available()){
186 |
fileContent+=String((char)file.read());
187 |
188 |
Serial.println(fileContent);
189 |
return fileContent;
190 |
