STM32WL kein Signal auf MISO-Leitung bei SUBGHZ SPI
OP #7909988
Ich versuche, eine SPI-Kommunikation mit dem integrierten LoRa-Transceiver des STM32WL einzurichten. Die NSS,MOSI und SCK-Datenleitungen scheinen zu funktionieren, jedoch erhalte ich keine Rückmeldung des LoRa-Transceivers auf der MISO-Leitung.
Mein Code ist der folgende:
 void SUBGHZSPI_DebugEnable(void) {
  RCC->AHB2ENR |= (1U << 0);    //enable GPIO-A
  GPIOA->MODER &= ~(3U << 8);    //reset PA4
  GPIOA->MODER |= (2U <<   8);    //set PA4
  GPIOA->MODER &= ~(3U << 10);  //reset PA5
  GPIOA->MODER |= (2U << 10);    //set PA5
  GPIOA->MODER &= ~(3U << 12);  //reset PA6
  GPIOA->MODER |= (2U << 12);    //set PA6
  GPIOA->MODER &= ~(3U << 14);  //reset PA7
  GPIOA->MODER |= (2U << 14);    //set PA7
  GPIOA->AFR[0] &= ~(15U<<16);  //reset AF of PA4
  GPIOA->AFR[0] |= (13U<<16);    //set AF13 of PA4
  GPIOA->AFR[0] &= ~(15U<<20);  //reset AF of PA5
  GPIOA->AFR[0] |= (13U<<20);    //set AF13 of PA5
  GPIOA->AFR[0] &= ~(15U<<24);  //reset AF of PA6
23
  GPIOA->AFR[0] |= (13U<<24);    //set AF13 of PA6
24
25
  GPIOA->AFR[0] &= ~(15U<<28);  //reset AF of PA7
26
  GPIOA->AFR[0] |= (13U<<28);    //set AF13 of PA7
27
28
  GPIOA->OSPEEDR |= (3U << 8);  //set output speed for PA4 to HIGH speed
29
  GPIOA->OSPEEDR |= (3U << 10);  //set output speed for PA5 to HIGH speed
30
  GPIOA->OSPEEDR |= (3U << 12);  //set output speed for PA6 to HIGH speed
31
  GPIOA->OSPEEDR |= (3U << 14);  //set output speed for PA7 to HIGH speed
32
33
34
35
36
void SUBGHZSPI_init(void) {
37
38
      RCC->APB3ENR |= (1<<0); // enable SUBGHZ SPI
39
40
      SUBGHZSPI->CR1 |= (1 << 9); // SSM
41
      SUBGHZSPI->CR1 |= (1 << 8); // SSI
42
43
      SUBGHZSPI->CR1 &= ~(7 << 3);
44
      SUBGHZSPI->CR1 |= (1<<3); // baudrate (1MHz)
45
46
      SUBGHZSPI->CR1 |= (1<<2); // Master
47
      SUBGHZSPI->CR1 &= ~(1<<10); // full-duplex
48
49
      SUBGHZSPI->CR2 |= (1<<12); // FIFO threshold 8bit
50
51
      SUBGHZSPI->CR1 |= (1<<6); // enable SPI
52
ich rufe diesen code dann vom main.c auf:
while(1) {
    PWR->SUBGHZSPICR &= ~(1 << 15); // NSS low
    while (!(SUBGHZSPI->SR & (1 << 1))); // TXE
    *(__IO uint8_t*)(&SUBGHZSPI->DR) = 0x13;
    while (!(SUBGHZSPI->SR & (1 << 0))); // RXNE
    uint32_t status = SUBGHZSPI->DR;
    PWR->SUBGHZSPICR |= (1 << 15); // NSS high
Ich kann daten senden und diese ebenfalls mit meinem logic level analyzer verifizieren, aber die MISO-Leitung bleibt dauerhaft auf "high" (siehe Anhang)
Kann mir jemand sagen, was fehlt oder was ich falsch mache? Danke im Vorraus
Persönliche Seite #7910156
Harry L. schrieb:
Ich sehe da z.B. und u.A. keine Clock-Initialisierung.
Genau, und RCC_CSR_RFRST wird nicht gelöscht, RCC_CSR_RFRSTF wird nicht geprüft.
Harry L. schrieb:
ST hat da viel Arbeit investiert, und das funktioniert.
Die Ansteuerung des Modems ist tatsächlich relativ komplex, was von der SubGHz_Phy-Middleware implementiert wird. Außerdem enthält diese so diverse Workarounds für die verschiedenen Hardware-Bugs, und auch Software-Implementationen für Whitening und lange Pakete (> 255 bytes).
Leider ist die Middleware dennoch relativ verbuggt, dies muss man erst einmal selbst bereinigen damit sie funktioniert. Das ist schon ein gewisser Aufwand, aber immer noch viel weniger als das alles komplett von Null auf neu zu implementieren. Was im Übrigen genau das ist, was die RadioLib macht.
