Forum: Compiler & IDEs String Array bestehend aus Arrays Hilfe
von Micha (Gast)
Hallo ich hoffe ihr könnt mir helfen. habe schon einige Beträge dazu
gelesen, doch irgendwie kapier ich's nicht.
Allso, ich möchte auf einem Grafik LCD einen Text aus geben .
Das Zeichen besteht aus Pixeln die ich über SPI dem LCD sende.
Mein erster Ansatz war:
set_Portb(PA4);
SPDR = 0b00000000;
while(!(SPSR & (1<<SPIF)));
SPDR = 0B00000000;
SPDR = 0B11111110;
SPDR = 0B00010000;
SPDR = 0B00010000;
SPDR = 0B00010000;
SPDR = 0B11111110;
SPDR = 0B00000000;
SPDR = 0B00000000;
wait (500);
Damit wird jedes Pixel in jeder Zeile einzeln gesetzt!
Alao: SPDR = 0B11111110; setzt im Display 7 Pixel.
Dann habe ich in meinem C Buch nachgeschaut und Arrays entdeckt:
Also habe ich Buchstaben aus 8 X 5 Zeichen entwurfen und in Arrays
gespeichert:
char Leer[5] = {0x00,0x00,0x00,0x00,0x00};
char Ohm[5] = {0x5C,0x62,0x02,0x62,0x5C};
char A[5] = {0x7E,0x11,0x11,0x11,0x7E};
char B[5] = {0x41,0x7F,0x49,0x49,0x36};
char C[5] = {0x3E,0x41,0x41,0x41,0x22};
char D[5] = {0x41,0x7F,0x41,0x41,0x3E};
char E[5] = {0x7F,0x49,0x49,0x49,0x49};
char F[5] = {0x7F,0x09,0x09,0x09,0x01};
char G[5] = {0x3E,0x41,0x41,0x49,0x7A};
char H[5] = {0x7F,0x08,0x08,0x08,0x7F};
char I[5] = {0x00,0x41,0x7F,0x41,0x00};
char J[5] = {0x20,0x40,0x41,0x3F,0x01};
char K[5] = {0x7F,0x08,0x14,0x22,0x41};
char L[5] = {0x7F,0x40,0x40,0x40,0x40};
char M[5] = {0x7F,0x02,0x06,0x02,0x7F};
char N[5] = {0x7F,0x06,0x08,0x30,0x7F};
char O[5] = {0x3E,0x41,0x41,0x41,0x3E};
char P[5] = {0x7F,0x09,0x09,0x09,0x06};
char Q[5] = {0x3E,0x41,0x51,0x21,0x5E};
char R[5] = {0x7F,0x09,0x19,0x29,0x46};
char S[5] = {0x26,0x49,0x49,0x49,0x32};
char T[5] = {0x01,0x01,0x7F,0x01,0x01};
char U[5] = {0x3F,0x40,0x40,0x40,0x3F};
char V[5] = {0x1F,0x20,0x40,0x20,0x1F};
char W[5] = {0x7F,0x20,0x18,0x20,0x7F};
char X[5] = {0x63,0x14,0x08,0x14,0x63};
char Y[5] = {0x07,0x08,0x70,0x08,0x07};
char Z[5] = {0x61,0x51,0x49,0x45,0x43};
Nun muß ich nur noch schreiben, um z.B.: ein OHM Zeichen anzuzeigen:
for (count = 0; count<5; count++)
SPDR = Ohm[count];
Bis hierher geht das Super !!!!!!!
Nun wäre der nächste schritt eine Zeichenkette ausgeben.
Also habe ich mir gedacht.
Ich erstelle ein Array mit dem Text den ich ausgeben will z.B.:
char text[6] = {H,A,L,L,O};
char *zeiger
zeiger = text;
for (count1 = 0; count<5; count++)
zeiger = Text[count1];
set_Portb(PA4);
SPDR = zeiger[count];
Also laut meinem C buch zeigt der Zeiger auf das Array text.
Also: solte doch im Zeiger durch zeiger = Text[count1];
Das Zeichen H stehen.
H ist ja auch ein Array deshalb solte doch die zweite Schleife alle 5
Hex senden. Läst sich nicht compilieren!
2. Idee:
int text[] = {H,A,L,L,O};
int zeiger[5];
zeiger[count1] = text[count1];
set_Portb(PA4);
Läst sich nur Compelieren wenn ich den String als Int anlege ??
Kömmt müll bei raus.
Wie könnte man das noch machen ?
Geht es mit mehrdimensionalen Arrays ?
Vielen Dank für jede Hilfe erklärung
von Karl H. (kbuchegg)
> gespeichert:
OK.
> SPDR = Ohm[count];
Gut. Damit hast du mal die Funktionsfähigkeit deiner Ausgabe
getestet.
Nein, das ist nicht der nächste Schritt.
Der nächste Schritt ist es, eine Ausgabefunktion für ein einzelnes
Zeichen zu schreiben, wobei das Zeichen nicht wie in deinem Ohm-
Beispiel von vorne herein feststeht.
Dazu, veränderst du erst mal dein Zeichensatzarray in ein 2-d
Array. Die eine Dimension gibt dir die auszugebenden Codes,
die andere Dimension ist der Code des Zeichens das auszugeben
ist.
Wenn du also ein Zeichen ausgeben willst, dann nimmst du den
Code für dieses Zeichen her und interpretierst ihn als die
Zeilennummer in deinem 2D Array und kriegst so die Zeile in
der die 5 Codes stehen, die du ans Display schicken musst.
Im Grunde kannst du deinen eigenen Code erfinden, aber es ist
sehr viel simpler, wenn du einen gängigen Code benutzt. Der
ASCII Code ist zb so einer. Einfach mal nach ASCII googlen.
ASCII gibt dir die Umsetzung der Codezahlen von 0 bis 127 zu
Buchstaben und sonstigen Zeichen, also genau das was du brauchst.
char Zeichensatz[128][5] =   // 128 Zeichen, 5 Displaycodes pro Zeichen
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x00
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x01
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x02
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x03
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x04
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x05
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x06
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x07
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x08
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x09
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0A
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0B
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0C
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0D
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0E
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x0F
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x10
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x11
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x12
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x13
23
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x14
24
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x15
25
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x16
26
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x17
27
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x18
28
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x19
29
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1A
30
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1B
31
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1C
32
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1D
33
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1E
34
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x1F
35
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x20  = Leerzeichen
36
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x21
37
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x22
38
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x23
39
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x24
40
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x25
41
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x26
42
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x27
43
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x28
44
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x29
45
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2A
46
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2B
47
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2C
48
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2D
49
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2E
50
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x2F
51
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x30   = '0'
52
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x31   = '1'
53
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x32   = '2'
54
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x33   = '3'
55
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x34   = '4'
56
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x35   = '5'
57
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x36   = '6'
58
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x37   = '7'
59
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x38   = '8'
60
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x39   = '9'
61
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3A
62
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3B
63
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3C
64
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3D
65
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3E
66
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x3F
67
  { 0x00,0x00,0x00,0x00, 0x00 },     // 0x40   = '@'
68
  { 0x7E,0x11,0x11,0x11,0x7E },      // 0x41   = 'A'
69
  { 0x41,0x7F,0x49,0x49,0x36},       // 0x42   = 'B'
70
  { 0x3E,0x41,0x41,0x41,0x22},       // 0x43   = 'C'
71
  { 0x41,0x7F,0x41,0x41,0x3E},       // 0x44   = 'D'
72
  { 0x7F,0x49,0x49,0x49,0x49},
73
  { 0x7F,0x09,0x09,0x09,0x01},
74
  { 0x3E,0x41,0x41,0x49,0x7A},
75
  { 0x7F,0x08,0x08,0x08,0x7F},
76
  { 0x00,0x41,0x7F,0x41,0x00},
77
  { 0x20,0x40,0x41,0x3F,0x01},
78
  { 0x7F,0x08,0x14,0x22,0x41},
79
  { 0x7F,0x40,0x40,0x40,0x40},
80
  { 0x7F,0x02,0x06,0x02,0x7F},       // 0x4D = 'M'
81
  { 0x7F,0x06,0x08,0x30,0x7F},
82
  { 0x3E,0x41,0x41,0x41,0x3E},
83
  { 0x7F,0x09,0x09,0x09,0x06},
84
  { 0x3E,0x41,0x51,0x21,0x5E},
85
  { 0x7F,0x09,0x19,0x29,0x46},
86
  { 0x26,0x49,0x49,0x49,0x32},
87
  { 0x01,0x01,0x7F,0x01,0x01},
88
  { 0x3F,0x40,0x40,0x40,0x3F},
89
  { 0x1F,0x20,0x40,0x20,0x1F},
90
  { 0x7F,0x20,0x18,0x20,0x7F},
91
  { 0x63,0x14,0x08,0x14,0x63},
92
  { 0x07,0x08,0x70,0x08,0x07},
93
  { 0x61,0x51,0x49,0x45,0x43},       // 0x5A = 'Z'
94
  { 0x00,0x00,0x00,0x00,0x00),
95
96
97
98
An der Stelle ... musst du noch Zeilen einsetzen um die restlichen
Zeichen bis hoch zum Code 0x7F einsetzen (das sind dann 128 Zeichen)
Dann brauchst du erst mal eine Funktion um ein einzelnes
Zeichen auszugeben.
Wie gesagt: Du nimmst den Code für das Zeichen und siehst
damit in der Tabelle nach welche 5 Zeichen für diesen Code
auszugeben sind
void put_char( char character )
  unsigned char count;
  for( count = 0; count<5; count++ )
    SPDR = Zeichensatz[character][count];
    while( !(SPSR & (1<<SPIF)) )
Soweit so gut. Du kannst jetzt einzelne Zeichen ausgeben.
zb. so
int main()
  put_char( 'H' );
  put_char( 'A' );
  put_char( 'L' );
  put_char( 'L' );
  put_char( 'O' );
  while( 1 )
Stell sicher, dass das funktioniert!
Dann gehst du erst mal her und ergänzt die fehlenden Zeichen
in der Zeichensatztabelle. Such dir eine ASCII Tabelle im Web
und geh die Zeichen durch.
Weiter gehts:
Jetzt bist du bereit, dir eine Funktion zu machen, die einen
kompletten Text ausgeben kann. Du kannst dazu die bereits
funktionierende put_char Funktion benutzen
void put_string( char* text )
  while( *text ) {
    put_char( *text )
    text++;
Benutzt wird diese Funktion zb so
int main()
  char Text[] = "WELT";
  put_string( "HALLO " );
  put_string( Text );
Und dann liest du dir nochmal das Kapitel über Arrays in deinem
Textbuch durch.
von Micha (Gast)
erstmal Vielen Dank!
Werde das gleich mal morgen ah heute ausprobieren.
Das der ASCII code, sich aus 5 mal 8 bit reihen zusammensetzt wusste ich
nicht!
Schreibe Morgen ob es geklappt hat.
Gruß, Danke , Gute Nacht :-)
von Rolf Magnus (Gast)
> ich nicht!
Das tut er auch nicht. Aber die Buchstaben, die du entworfen hast,
setzten sich so zusammen. Irgendwie muß aber der ASCII-Code in deinen
Zeichencode konvertiert werden. Dazu dient die Tabelle, bei der du den
ASCII-Code direkt als Index verwenden kannst, um zu deinem dazugehörigen
Zeichencode zu gelangen.
von Micha (Gast)
Vielen Dank hat alles super geklappt.
Nur verstehe ich nicht woher der Compiler oder MC weiß das nach ASCII:
 put_char( 'H' ); das an der stelle 72 dez Steht.
Eigentlich dürfte das doch nicht funktionieren!?
Ich müste doch eigentlich  put_char(72); schreiben um dann im
Zeichensatz: SPDR = Zeichensatz[character][count]; die Zeile 72
auszugeben.
Woher weiß der MC das H gleich der Code aus Zeile 72 ist ????
von Stefan E. (sternst)
Weil 'H' und 72 das Selbe sind. Denke daran, dass ein µC sowas wie
Buchstaben gar nicht kennt. Er kennt nur Bitfolgen, also Zahlen.
Z.B. bei einem "HALLO" steht im Speicher die Zahlenfolge:
72 65 76 76 79 0
von Micha (Gast)
Ja gut, aber der Compiler muß den ASCII code kennen. Weil H könnte ja
auch irgend eine andere Zahl sein.
das heißt dann das der ASCII überall gilt. Also wenn ich Zeichen eingebe
wird jedes Zeichen einer Zahl zugeordnet. Welche Zahl zu welchen Zeichen
wurde einmahl im ASCII festgelegt. Richtig ?
Das ist ja extrem praktisch, ich hatte schon angst das ich das alles
selber definieren muß.
Nochmal Vielen Dank an alle. Ist ne super Seite.
von Sven P. (Gast)
Hastu soweit richtig verstanden. Pass trotzdem auf, weil ASCII
englischer Natur ist. Umlaute beispielsweise können - je nach
Zeichensatz - an verschiedenen Stellen stehen.
von Johannes M. (johnny-m)
Wenn der Parser des Compilers ein in Hochkommata eingeschlossenes
Zeichen sieht (z.B. eben 'H') oder einen aus mehreren Zeichen
bestehenden Ausdruck in doppelten Hochkommata (also einen String, z.B.
"Hallo!"), dann interpretiert er diese Zeichen automatisch als
ASCII-Zeichen und ersetzt sie intern durch die entsprechenden
Binärcodes. Bei dem String fügt er zusätzlich am Ende einen
Nullterminator an, der das Ende des String kennzeichnet
Richtig. ASCII heißt American Standard Code for Information Interchange,
und der wurde irgendwann einmal festgelegt. Allerdings sind im Prinzip
nur 128 Zeichen dort definiert (7-Bit-ASCII). Die Erweiterungen auf 8
Bit sind nicht eindeutig festgelegt (z.B. bei vielen alphanumerischen
LCDs aus Fernost eine Auswahl japanischer Schriftzeichen. Umlaute sind
auch, wenn überhaupt vorhanden, in der zweiten Hälfte zu finden). Gerade
das kann (je nach verwendetem Display) dazu führen, dass eben z.B.
Umlaute nicht korrekt wiedergegeben werden, weil das Display einen
anderen Zeichensatz verwendet. Die Ziffern, "normale" Buchstaben und
Satzzeichen sind aber überall gleich.
> Na gut, aber der Compiler muß den ASCII code kennen.
Ja.
> Weil H könnte ja auch irgend eine andere Zahl sein.
Richtig.
Naja, nicht überall. Nur ein kleines gallisches Dorf... ach nee, das war
eine andere Geschichte ;-)
Sagen wir mal so: ASCII und darauf aufsetzende Kodierungen sind sehr
weit verbreitet.
> Also wenn ich Zeichen eingebe wird jedes Zeichen einer Zahl zugeordnet.
Richtig.
> Welche Zahl zu welchen Zeichen wurde einmahl im ASCII festgelegt.
Es wird vom Compiler festgelegt, der in diesem Fall ASCII verwendet.
